Replacement belt required for Beogram 2000 turntable.
3 Suggested Answers
  • 122 Answers
SOURCE: belt drive replacement B&O Beogram 1000, type 5203 turntable
length approx 30mm shorter than old one, knock out pin on shaft to take platter off.more often than not the motor runs slow after repair,if its a round style ac motor htey cant be fixed.
Posted on Jan 11, 2010
  • 122 Answers
knock pin out.make sure idler assy moves freely away from motor shaft.
I have a Bang&Olufsen Beogram
Similar to most Beogram 1800, the RX 2 featured record sizing by weight. When Play was selected, the centre part of the platter would raise gently, with only just enough force to lift a 45RPM single. An LP would be too heavy to lift, so the mechanism would set itself to 45RPM and 18cm if the record lifted, 33RPM and 30cm if it did not. The speed control keys could then be used to override the choice for non-standard records. The parts could also detect if a record was not present, and prevent the turntable being activated
Just put lp on and it should work
Jul 08, 2008 | Audio Players & Recorders
Beogram 1100 not turning
If your platter runs off of a belt then the belt would need to be replaced after many years especially if its been in storage. Another thing is, if you can see the motor with the flywheel on it, it is a good idea to spray just a little WD-40 down the shaft to free up the motor and just let it run for several hours after the table was sitting dormant for so long.
Apr 26, 2014 | Audio Players & Recorders
The turntable motor runs but the turntable doesn't spin i'm not sure if the belt is on incorrectly or what help please. Sony ps-lx250h turntable
most platters are secured with a c clip in the middle --gently prying it off should allow the platter to be removed--than a little dexterity is required to reattach the belt to the pulley and around the bottom of the platter--if the belt is broken or stretched you can pursue a replacement at mcm electronics .com
Sep 04, 2010 | Sony PS-LX250H Turntable
B&O Beogram 2000 turntable arm won't go down
Check to see if there is a cueing lever that is holding the arm in the up position.  If no cueing lever and it has worked recently then something has happened to the changer mechanism.  Open the bottom and look to see if there is an obvious problem like something stuck or broken.  You may be able to make the mechanism go through its cycle slowly by rotating the platter with your  hand so you can see where it is getting stuck.
May 30, 2009 | Bang and Olufsen Beosound 2000 Shelf...
Belt drive replacement B&O Beogram 1000, type 5203 turntable
May 09, 2009 | Philips gemini TT-02 MK2 Turntable
Beogram 1800 wont play the record!!
possibly some kind of obstruction inside.
I had something similar with my turntable, and it had a dirt dauber nest inside it!
no kidding.
Dec 03, 2008 | Audio Players & Recorders
Sylvania stereo Model sc241w
Sounds like the belt broke off, if so, you must replace the belt with the proper replacement belt. If it is a Quartz Lock system, it will be very pricey to fix. If so, it's best you take it to a professional if it is a Quartz Lock system, they are very delicate systems and require careful repair.
Hope this helps!
Jul 13, 2008 | Technics SL-1200MK5 Turntable
 Grubhead
Grubhead
