Question about Casio TV-900 2.3 in. Handheld Television
Feb 17, 2009 - how can I use casio tv-900?
I can not find anyone who has a converter for my Casio TV-900. What do I do? How am I able to continue using it after Feb 17? Can I send it back to you to be modified? Can I trade it in on a tv that will work?
Thank You.
donna sebastian
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    Have you been hiding under a rock for the last 4 years? You need a digital converter which won't work if you don't have an ANT port.
I just tried mine and i have no signal on the vhf setting but i do get channels on the uhf
Posted on Dec 20, 2009
My Casio handheld LCD color tv-900 wont turn on and no audio. I tried new batteries but no help occurs..
Actually this device is hard to repair. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 17, 2017 | Casio Televison & Video
Can I conveRt an analoge signal to digital for Casio tv
The need depends on what country you live in. In the US,Canada,and Mexico there are no longer any analog TV signals Everything broadcast over the air is digital. A digital to analog converter is available so older TV's without a built in digital tuner can be used.
Feb 12, 2015 | Casio Ev-4500 4" Lcd Color Television...
Is it possible to convert my casio portable tv 970 2.3" to digial
radio shack has a adapter part # 278267 which converts the antenna coax cable to 1/8 or 3.5mm jack for the external antenna input my casio tv-970 works with a digital converter box
Mar 06, 2011 | Casio 2.3 Color Handheld Television...
Hi i have the same problem
Hi i am waiting for my answer. or do you you know what converter we need for our Casio TV - 970 thanks from Pete.
Sep 23, 2009 | Casio TV-970 2.3 in. Handheld Television
Digitial reception for casio 980
You won't. Because the unit isn't likely to have an coaxial external cable input, there is no simple way to achieve this. Full-size sets not equipped for digital signals can accept the down-converted signal from a converter box that receives the digital signal and converts it to NTSC standards for older sets. Direct reception of the new signal requires an ATSC tuner and there is no way to provide that for your hand-held. It would be possible to use the output of a converter box clipped onto the antenna of your Casio and see the channels the converter box can receive but your hand-held wouldn't be very portable anymore. Sorry-
Aug 20, 2009 | Casio TV-980 2.3 in. Handheld Television
Will my handheld tv work after feb
Hello lavillavicto,
Look at you owners manual if the tuner format is ATSC (digital standard) then it's ok, if it is NTSC (analog standard) then it will not work. My experience tells me that the answer to your question is no, because most of these units were made with NTSC tuners. I know this is not what you want to hear but it is the truth.
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Dec 28, 2008 | Casio EV-550 2.5 in. Handheld Television
Digital converter box
Only if you have an ANTENNA jack.
Dec 24, 2008 | Casio TV-900 2.3 in. Handheld Television
Are there converters 4 hand held casio 880B
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
If your antenna has flat 300 ohm wire connections, you'll need a balun (Radio Shack catalog # 15-1297, about $8) to connect it to the coaxial cable that goes to the Antenna (RF in) jack on the converter box.
I’ve tried 2 different converter boxes with the handheld TV, and they both work well: Insignia (Best Buy’s house brand, same as Zenith) and RCA (from Target, same as Venturer), so any government coupon-eligible converter box should work.
A few other tips:
1. I always turn on the converter box before I turn on the TV. The cpnverter box seems to take control better that way.
2. When I turn on the TV, the tuner doesn’t automatically go to channel 3 or 4 (where it should be set when using a converter box), and the picture quality is poor. If I use the tuner on the TV to get to channel 3 or 4, the picture quality is vastly improved. I have to do that every time I turn on the TV.
3. Placement of the antenna is very important. I like to watch my handheld TV when I'm on the computer, and the reception is better the further away from the computer the antenna is located. I'm actually using a 6' coaxial cable for the antenna, but I could also have used 2 shorter cables with a coupler that has an F jack at both ends (Radio Shack catalog # 278-304, about $3).
If your battery-operated TV does not have an external antenna jack, instructions for connecting it to a converter box can be found at
http://www.digitaltvtrainer.com/national/showme-battery-tv-converter
There are a few battery-operated converter boxes available, but for do-it-yourselfers, this web page also contains instructions for building a 12-volt converter box power supply.
Nov 11, 2008 | Casio TV-980 2.3 in. Handheld Television
Casio 2.3
The analog to digital only applies to television sets that are operating off of a rabbit ear or out door antenna that picks up local stations, or cable television without the cable box/receiver. If you have satellite television or cable with the receivers, your televisions will continue to work after the analog to digital transition.
Aug 24, 2008 | Televison & Video
Casio TV-900 2.3 in. Handheld Television Logo
536 people viewed this question
Top Casio Televison & Video Experts
Henry  Thomas
Henry Thomas
Brian Sullivan
Brian Sullivan
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
