Denon AVR-4802 multi-zone problem.
I can't get sound out of my rear speakers when the amp assignment is switched to multi-zone. I suspect it has to do with the volume in the zone but have no way to adjust it other than the menu options: variable, -40, 0. The original remote is long gone. I've been using a Harmony 670 but I can't find a multi-zone volume adjustment on it. Unless anyone has the solution my next step is to find a dealer and try to ''learn'' the commands.
I had the same questions and still can't believe there isn't more information on the topic. It's crazy how much marketing Denon devotes to their Multi-Zone features yet offers very little reference materials on the actual set up. I guess most customers don't use the fearture? Here you go:
-The Multi-Zone on the Denon 4802 is analog only. If you are running digital coax or fiber you will have to run a second line that's analog (eg RCA red/white) from the source to the Denon in order for the signal to to make it to the Zone 2 speakers (regardless if it's Pre-Amp out or direct connect to the Zone 2 speakers from the multi/SB speaker outs. Regarding the Harmony question, I had the same problem with my Harmony 880 and wasn't able to find an answer after multiple searches. Luckily I figured it out when I deleted the receiver from the Logitec device list and started over. Connect the remote to your computer, launch the Logitec Harmony Remote Software, click the Devices tab, hit the Add Device, pick the device type & manufacturer from the drop down list, enter "AVR-4802" under Model and finally hit the Next button in the lower right corner of the UI. The next page solves the Harmony Zone 2 control problem. You will see a message "To use your device in additional zones/rooms, click the checkbox...." Make sure Room 2 is checked (mine was not), update the remote and you're done. The Harmony Device menu you will now contain a second receiver icon called "receiver 2." Hit "device" on the Harmony, choose "receiver 2" and you will gain control over Zone 2 including volume.
Steve
Posted on Jun 04, 2010
    Scholar:
  • 93 Answers
Are you running a 5.1 surround sound setup? Be sure you set amp assignment to surround speakers Not Rear surround speakers, this is disabled when multi zone is assigned to 2 zone setups
Posted on Jan 26, 2009
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Sep 03, 2011 | Denon AVR-1905 Receiver
I have a denon avr-4802 receiver. I am looking to purchase new speakers for this system, but don't want to put too much into the speakers. Will the speakers from a denon s-302 work on this receiver? ...
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Denon-S-302-Home-Theater-Systems-manual/id/7046dj484/t/2/
http://www.retrevo.com/support/Denon-AVR-4802-Receivers-manual/id/363ag815/t/2/
Page 10. The S-302 uses a proprietary D-Sub25 system cable to the DSW-S302 subwoofer. Don't know if or why it has more than 2 active conductors. The other speakers have removable cable ends so they might work just fine.
Apr 24, 2011 | Denon AVR-4802 Receiver
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
Selecting a Blu-Ray Player
If Denon blu ray has coaxial or optical out for audio, then your Denon receiver will process this signal and will give you 7.1 out sound.
Jan 24, 2009 | Denon AVR-4802 Receiver
Back speakers with av denon 1908
Plug your rear 5.1 speakers into the surround speaker connections. Be sure to use the AVR 1908 set up menu to set rear speakers (not an amp assign). Hope this helps.
Jan 03, 2009 | Denon AVR-1908
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Itunes assigned to CD stereo outputs to zone 1 but not zone 2
Ron Digital audio will only reproduce in the surround area you will have to connect using analog connections in order to get that sound in the 2nd zone
Dec 14, 2008 | Denon AVR-2807 Receiver
Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
Jul 14, 2008 | Denon AVR 3808Ci Receiver
449 people viewed this question
 Grubhead
Grubhead
