Question about Dryers
My dryer heats then displays e64 and shuts off
If we let it sit and cool we can restart and after the second run it usually dries the close by the time it errors again.
Daniel S
  • 4323 Answers
SOURCE: I was drying and the
Hi
Error code E64 means Heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and “cancel” buttons simultaneously for 3 seconds. If the error appears again then you’ll need to check heater coils and connections for open circuits. Use a multimeter to check the heater element, use Rx100 setting on the multimeter. It should display 30-33 K ohms as the resistance. If it is less than this or exceeds this limit then the element has gone bad and you would need to replace the element. Hope this helps...
Daniel
Posted on Sep 13, 2010
protek480
  • 1714 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
  • 1564 Answers
SOURCE: Dryer heats up but doesn't dry clothes...
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
Posted on Sep 12, 2012
  • 156 Answers
SOURCE: Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Posted on Feb 28, 2008
huuum
  • 750 Answers
SOURCE: Dryer won't stay on.
tc7059d4.jpg9729365.jpg3403fe5.jpgThe wiring diagram for your dryer is shown in the first image below. A thermal fuse is normally in the circuit to the igniter on many gas dryers. I recommend checking this fuse. On dryer model 11073032102, you can access this fuse by _unplugging the dryer, shutting off the gas supply,_ and removing the bottom front service panel as shown in the second image below. On some Kenmore dryers, you have to remove the back panel to access the thermal fuse. The thermal fuse is located on the blower housing . The third image shows the location and replacement procedure. To test the thermal fuse, remove at least one wire (with the dryer still unplugged) and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms (continuity). If you measure infinite resistance (open), then the thermal fuse is blown and will need to be replaced.NOTE: If the thermal fuse is blown, check the venting for your dryer. Restricted exhaust venting can cause the thermal fuse to blow.
thank You Huuum
Please remember to leave a solved rating before you sign off!
Posted on Jan 23, 2009
My danby dryer keeps shutting off and turning on and the clothes take forever to dry
GOD IS STILL GOOD !!!!
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Sep 09, 2014 | Danby DCD5505W Electric Dryer
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Dishwasher restarts a new programme after finishing previous
try to reset program..... hold off button for 2 seconds or so..... until it turns completely off....
it this won't help, try to disconnect it from outlet..... wait few minutes,... connect it back to wall and try again
Jan 13, 2014 | AEG Dishwashers
Dryer electrolux indicates code E64
you will have to take the front panel off. first unplug the dryer then there will b two screws in back that hold top on, once screws r out the top will slide back allowing to lift up. there r 4 screws that hold the touch/display panel on. unplug and remove. there r another 4 screws under that panel that hold the front panel and there 2 more when u open door about as high the lint screen. once all screws r out u should b able to see heater. if not remove all other necessary components. it will b at the bottom left. remember this usually the cause of a heater failure is a clogged or restricted vent. tall tell sign close took a long time to dry.
Feb 16, 2013 | Electrolux EWMED65HSS Electric Front Load...
My frigidaire dryer is showing an e64 error code dryer works sometimes ?
The unit is displaying this code because the heater's circuit is open. A professional is needed to check the heater coils and connections for any open circuits. Replace the heater and/or wiring connected and then retest.
Dec 18, 2012 | Frigidaire Dryers
Dryer will stop heating after ten minutes...
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Apr 28, 2012 | Dryers
Dry will not start, you let it sit and it turns on for a few seconds then shuts off and will not start again
What your describing is a defective motor that the bearing on the motor are very tight...what happens when the bearing are tight on a motor is that it will start for a few minutes then the motor will get very hot and shutoff until its cool and restart only to quickly shutoff again when it get too hot and that continutes. Th eremedy that the motor would need to be replaced.
GENE
Oct 16, 2011 | Frigidaire GLGT1031C Dryer
The dryer is new and its not drying at all. also ths cooling system light is on?
Usually the reason is the exhaust vent in the wall leading to the outside of the house is heavily restricted with lint or other debris. Pull the exhaust vent out of the wall and run the dryer to see if the load dries normally. If it does, you will need someone to clear out the exhaust vent to resolve the drying issue.
The cooling light is a display that tells you what will be happening during the cycle. When it flashes, the dryer is in the cooling mode and is continuing its operation but with no heat. That usually lasts about 10 to 15 minutes.
Good lucj
Oct 04, 2010 | LG DLE2301 Electric Dryer
Dryers Logo
1,171 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
