Bush a146cdw leaking
Leaking from underneath, opened pump filter to clean and water keeps flooding out
  • 1294 Answers
SOURCE: leaking....front door won't close
Carefully look at the door gasket to see if any irregularity in seal. Could be problem with door seal; or you could easily change door mechanism thru a spare part shop quoting your model and spare-part No or "door mechanism"
Posted on Apr 12, 2007
Washer_tech
  • 164 Answers
SOURCE: leaking water from underneath.
sounds like several problems. sounds like your boot stem/ seal is leaking and possibly the tub bearing is rusted. I generally replace both at the same time as long as the machine is apart anyway. As for the squealing and tub slamming to a stop, that is your brake package and bearing have dried and/or rusted and need to be replaced
Posted on Dec 26, 2007
Lumpy816
  • 246 Answers
SOURCE: My washing machine keeps leaking from the bottom
We have not heard back on this in about a week. I'm presuming It's been repaired?
Posted on Jun 21, 2008
  • 1462 Answers
SOURCE: indesit washing machine flooding when filling
if you washed coins, it is quite possible you have breached outer tub with them.
Posted on Sep 05, 2008
venexcsd
  • 1185 Answers
SOURCE: I have had the same problems with draining the water
Looks like you did not get a seal on the hoses
Need to take them off again and if they are distorted use Instant Gasket or something similar to create a seal as well as the clips
Posted on Jul 02, 2009
My dishwasher will not drain completely
Most likely, the drain pump is clogged or the filter for the main pump is clogged with goo. If, during the drain cycle, water is just "peeing" into the drain line or sink drain, something is clogged. Broken glass, food, bones, etc., can find a way into the main pump mech or into the drain pump. You didn't specify what model washer you have but check the round removable filter found in a lot of Frigidaire dishwashers. Yours could be square, rectangular, etc. Get the users manual if you need help finding out how to clean the filter! Remember, if water can't move freely through the filter, your washer won't spray strongly either. Also, dishwashers will not drain out every drop of water--they will drain past where you can see the water but there will always be a small puddle of water in the motor. This keeps the seals moist and prevents dry-rotting, cracking and leaking.
Aug 18, 2015 | Frigidaire Dishwashers
How do i remove the top of a bush a146cdw
Before calling an engineer, there could be too much water pressure causing the water to splash over the sides of the draw. Try and remove the draw and give the channels a clean out., there is usualy a clip that needs to be pressed either under the draw or inside it.
Oct 03, 2014 | Washing Machines
What causes a pool pump motor to overheat
Blocked or clogged water input line
Sucking air from a leak, not enough water thru system
Excessive debris in strainer baskets
Filter needs to be backwashed
Filter needs new sand or new cartridge
Filter needs to be taken apart and "fingers" cleaned
Filter Pump Impeller is obstructed
Filter motor is in-correctly wired
Filter motor bushings need replacement
Filter motor bearings are worn
Filter motor is "shot"
Apr 16, 2013 | Emerson Pool & Spa
How do i get my filter out of my bush a127ldw washing machine got E03 error am working my way through your list but cant get filter out
Water inlet filters
On the tap part of your machine's water inlet
hose and at the ends of water inlet valves, there
are filters to prevent entrance of the dirt and
foreign materials in the water to the machine. If
the machine is unable to receive sufficient water
although your water tap is fully opened, these
filters should be cleaned.
x Remove the water inlet hose.
x Remove the filters found on the water inlet
valves by using a pincer and wash thoroughly
with a brush. (1)
x Clean the filters of the water inlet hoses
located on the tap side by removing manually
together with the seal. (2)
x After you clean the filters, you can fit them
the same way as you have removed them.
Pump filter
The pump filter system elongates the life of your
pump, which is used to drain the dirty water. It
prevents lint to enter the pump. Cleaning of your
pump filter in every 2-3 months is
recommended. To clean your pump filter:
x Open the kickplate's cover, by pulling the
handle. (2-A & 3-A)
x Before opening the filter cover,place a cup in
front of the filter cover to prevent flow of the
remaining water in the machine.
x Loosen the filter cover by rotating it counter
clockwise and drain the water. (4-A)
x Remove the foreign materials from the filter.
x Check for the rotation of the pump manually.
x After you have cleaned the pump, fit the filter
cover by rotating clockwise.
x Put the kickplate cover into place.
x Do not forget that if you do not fit in the filter
cover properly, it will leak water.
Jan 21, 2013 | Washing Machines
Leaking water
check ur water inlet valve the coild may be bad do a live test and test for ohms as well
Oct 14, 2012 | LG WM0642H Front Load
Water leaks past the water pump filter gasket reseating the filter does not stop the leaking lg tromm Front Loading Washer
I regularly clean my filter of slime and debris (after not even realizing this needed to be done and having my pump give out of me). TWICE I have awoken to a flooded basement due to leaks in the filter area:
The first time, the plastic stopper was not in the small rubber drain hose properly and had popped off.
The second time, I had cleaned the gasket, inserted it tightly like I always do, and awoke to another flood! I thought perhaps the rubber gasket on the filter was on wrong, but it was fine. I inserted it tightly several times and water still poured out! It turns out there was a small stone lodged in the thread of the receiving end of the filter causing there to be a bad seal. Lesson learned. Another $2000.00 worth of flooring ruined.
May 15, 2010 | LG WM-1832C Front Load Washer
Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Mar 26, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Leaking water
Your waste pump might not be clearing the water from the machine. When you open the machine, is there a visible pool of water at the bottom? Check that your waste pipe isn't blocked, and check and clean the filter basket underneath the bottom dish tray.
Apr 04, 2009 | Dishwashers
Diplomat 8352 water not draining caused kitchen floor to flood
your pump is obstructed. take out pump and clean it out. Your filter might be plugged too. As soon as it floods it also can be a leaking hose from the pump.
just open the machine and you will see the pump straight away.
Not difficult
Apr 26, 2008 | Dishwashers
Water flooding out
Hi KellyW,
The dishwasher drain hose may be clogged.  When the dishwashr starts up can you hear the water running into the Sink faucet drain. If not inspect the hose that attaches to the Sink Drain for restrictions.  Also in the bottom of the dishwasher you should have a filter.  If this filter is clogged you cannot expel water.  Clean the filter.
Oct 23, 2007 | Asko D1776 Stainless Steel Built-in...
Open Questions:
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
