Question about Zebra Designer Pro for PC
Zebra Designer Pro v1.01 - installing on Windows 7
I would install v1.01 of Zebra Designer Pro on Windows 7, it is ok with the installation, I give it Windows 7 drivers, but it asks continously to add a driver and the program doesn't open anymore.
3 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: , I want install Zebra
The Zebra 7.2 driver for Win 7 is last item in right column. Click on Zebra:
http://www.seagullscientific.com/aspx/thermal_95.aspx
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 29, 2010
SOURCE: During install of Zebra Design
I had the same exact problem, here is the fix:
1. Switch to Windows XP's Classic view in the Control Panel to turn off Themes. try using/installing the software
2. If this does not work, stop the Windows 'Themes' service. Then try the software again.
Posted on Jan 15, 2011
I need drivers Eltron Zebra P310CM for Windows 7
Hi I solve this problem with a program called CardFive this program provides several drivers inside when you install it in Windows 7. I install CardFive 6.3. Note. this program don´t install a printer driver in Devices and Printers in Windows 7, only provides you a interface to print cards with your Eltron p310 and you can choose other printer models discontinued. My printer interface is parallel and works in Windows 7 With CardFive 6.3 pro.
Jan 14, 2011 | Zebra Eltron P310 Thermal Printer
, I want install Zebra LP 2824 in laptop HP DV6 Windows 7, 64 bit. But no funciona.when run an cartel say "this program requires that you install a designer printer driver. please click "add...
Thanks, Joe
Dec 29, 2010 | Zebra Eltron LP 2824 Thermal Printer
During install of Zebra Design Pro v2 on Winddows XP Proffesional V2002 SP 3 get "Exception EAccessViolation in module nbars.dll at 00099DD0. Access violation at address 008C9DD0 in module 'nbars.dll'....
Sep 23, 2010 | Zebra Designer Pro for PC
Zebra Designer Pro Key
Zebra Designer PRO is an additional charge that must be purchased separately.
Mar 06, 2010 | Zebra LP 2844 Thermal Printer
Please help me find a driver for zebra 160S supporting Windows XP
Go to zebra.com and download the ZUD - (Zebra Universal Driver) - not the Zebra Designer Driver. Run the setup utility and install the driver for the 105SL and choose the port for your 160S. You may have to change the driver properties for firmware versions X.10 and earlier - I do not think that this feature is supported in the Designer Driver. The main point here is that if you can't find support for your specific model, install another model that supports the same features and print language. In your case, the 140XiIIIPlus has thermal transfer and runs on ZPL (Zebra Printer Language) just like your 160.
Jan 29, 2010 | Zebra Printer 140-751-00000
We are transferring our data files to a new pc and will like to know whether we need to install a software to work with our TLP2742. If so, is there an online downloadable software?
You can download the correct driver for this printer for all Windows Operating Systems from the following Zebra Support link
http://www.zebra.com/id/zebra/na/en/index/drivers_downloads/drivers/results.html?productType=7
Select the Zebra Universal Driver v5.5.7.25 as the printer driver. This covers around 50 different models but includes the TLP2742.
You can also download the designer and setup software as they should also work with the TLP2742
Oct 09, 2009 | Zebra Eltron TLP 2742 Thermal Label...
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
I have Thermal Zebra Printer TLP2824, I have installed it and
download.....http://www.barcodesinc.com/free-barcode-font/
free barcode font for programs. copy into c:/windows/fonts
it will install into that folder, and just select that font in VB6 application before printing
May 27, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Slow Printing on Zebra Z4M
An unorthodox solution is to install an old driver. Another solution is to use with Codesoft the driver from www.seagullscientific.com, and with Zebra Designer, the Zebra Designer driver. If the printer is connected to the serial port, speeds up communication.
Roberto Martinez
Mar 30, 2009 | Zebra Z4M Printer
Zebra Designer Pro for PC Logo
1,462 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
