Question about HP Office Equipment & Supplies
Hp color laserjet 3700 error 49. - HP Office Equipment & Supplies
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
  • 21 Answers
SOURCE: HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Posted on Jan 07, 2010
SOURCE: i have message error in printer hp laser color
you have replaced the dc controler, reseated the connections to it and checked the cables
Posted on Feb 04, 2010
SOURCE: Model - HP Laserjet P2055dn. Issue - 49 Err
I had the same problem. The source of this problem, the USB printer port is broken, then I use network configuretion. The poblem is solve.
Posted on Jun 02, 2010
SOURCE: error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Bueno, el error 79 en mi caso se presentó con el servidor de impresion, tienes que limpiar los trabajos en cola y luego reiniciar la impresora.El error 49 indican que es con un problemas de fax o con scanear en Mac OS X, en todo caso hp support tiene los pasos a seguir.
Posted on Jul 26, 2010
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
How to fix hp color laserjet cp4525 error code 49.4B03
Disconnect all usb and network cables and cycle the power. If the printer comes to ready then chances are you do not have a "hardware issue". Most common cause of 49 errors is out of date firmware. If you search the tips I have posted there is a detailed one on how to upgrade firmware.
Sep 02, 2014 | HP "color laserjet enterprise cp4525dn...
Error 49 hp laserjet 400 color m475dw
HI there, this seems to be an issue with the network if you do have a boxee try disconnecting it and check if thats the issue you need to contact boxee or try updating you router hardware .it may also occur if an apple TV is connect .
Make sure if you do ahve a Boxee you need to assign it to the network as it would send multiple packet data which would lock the printer which in turn makes it to reboot
Apr 05, 2013 | HP LaserJet Pro 400 color MFP M475dw -...
Hp color laserjet cm1017 mfp 49 service error showing in disply screen and restart the printer
Aug 15, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
49 service error
This error was already asked before, i will link to that article:
49 service error
Jul 11, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
Maximum file size for printing on the hp color laserjet 5500n - having issues with pdf files
If you are getting 49.XXXX error codes while printing PDF files, you can try upgrading the machines firmware.
This seems to be a common "PDF file printing" problem with the LaserJet 4250.
Oct 25, 2010 | HP Color LaserJet 5500 Printer
I have message error in printer hp laser color 3700 say that "59.99 error"
Feb 03, 2010 | HP Color LaserJet 3500 Printer
35 people viewed this question
Seeker5211
Seeker5211
