Question about Cell Phones
How to insert a memory card into nokia ce0434?
Raysagem
  • 1017 Answers
SOURCE: Nokia N70 wont acknowledge memory card?
Note: This device uses a Reduced Size Dual Voltage
(1.8/3V) MultiMediaCard (RS-MMC). To ensure
interoperability, use only dual voltage RS-MMCs. Check
the compatibility of an RS-MMC with its manufacturer or
provider.
Use only compatible Reduced Size MultiMediaCards
(RS-MMC) with this device. Other memory cards, such as
Secure Digital (SD) cards, do not fit in the memory card
slot and are not compatible with this device. Using an
incompatible memory card may damage the memory card
as well as the device, and data stored on the incompatible
card may be corrupted.
You cannot use the memory
card if the door of the
memory card slot is open.
Format a memory card
When a memory card is reformatted, all data on the card
is permanently lost.
Some memory cards are supplied preformatted and others
require formatting. Consult your retailer to find out if you
must format the memory card before you can use it.
To format a memory card, select Options > Format mem.
card
. Select Yes to confirm. When formatting is complete,
enter a name for the memory card, and select OK.
Posted on Apr 03, 2008
mohammed387
  • 1952 Answers
SOURCE: Memory Card is not accessible in my N-72 mobile phone.
take the memory card out of the phone and then try all of the options to reset to factory defaults etc and if it is related to the memory card it will just give you an error message of some description to state that it cant erase the memory card because you do not have one
Posted on May 25, 2009
chieandtin
  • 17 Answers
SOURCE: how can i insert memory card into nokia 7100
Nokia 7100 Supernova is a low-to-mid-end phone in slider form factor work on Tri-band GSM network. It features TFT262k colors, FM radio, Bluetoothmag-glass_10x10.gif 2.0, USB 2.0, Opera Mini browser, Flash Lite 2.1.1, MicroSD card slot and 1.3 MP camera
yes, it has a micro SD card slot, u can see it ussually on d side of the phone it looks like a small thin square hole. then u can insert the SD card to the slot.
IF YOU THINK THIS ONE IS A HELP. VOTES ARE VERY MUCH APPRECIATED :))
Posted on Jul 26, 2009
  • 312 Answers
SOURCE: On my Nokia N70, my phone memory card is not
first connect your memory card to a card reader and check wehther it is recognising...if no,sorry to tell you this, your memory card is currupted. formating is the only one way to get bak your memory card...hope this will helps you...thank you...
Posted on Oct 15, 2009
SOURCE: MEMORY CARD PROBLEM in NOKIA
Memory card is not working in my nokia 2730 classic device, even if i insert other mem.card which is working in other phones, the memory card option is not seen in my nokia 2730c device.Can any 1 assist me to fix this problem??!!!!.
Thank you.
Posted on Jan 05, 2011
Nokia ce0434
Remove the batter case, remove the battery, pull the sim card slot gently, pull out the sim card.
Jul 11, 2014 | Nokia Cell Phones
I am getting no memory card inserted
Remove your battery
insert your memory card
insert your battery
Power On.
if still no memory card inserted
Replace your memorycard
something wrong with your memory reader (parts of cellphone)
Jan 19, 2013 | Nokia N73 Cellular Phone
I frget my mobile nokia ce0434 unlock code please give me a master code
There is no model like ce0434 in Nokia Phone.You need to specify the model correctly.You can Unlock Nokia Phones from security lock using default code ...Try 12345 or 0000 or 1234 or 1234 if these default code not works means get the master reset code from the site
Mobile-unlocker.com/nokia-dct-master-code-service/rs2wp10/and reset from security lock.
Jun 13, 2012 | Cell Phones
I have nokia CE0434. So, what is the security code of nokia CE0434
Please send me the security code for this IMEI #359747045234708
am Merie
Nov 15, 2011 | Nokia 1650 Cell Phone
Nokia 6120c mmc problem insert memory card pls help me
Just Visit it now & enjoy i hope solved your problem its tested plzz share this http://bestmobiletrick.blogspot.com/2013/12/nokia-6120c-memory-solution-jumper.html see now
Apr 18, 2011 | Nokia 6120 classic Cellular Phone
MEMORY CARD PROBLEM in NOKIA 2730 classic!!!!!! Memory card is not working in my nokia 2730 classic device, even if i insert other mem.card which is working in other phones, the memory card option is not...
Thank you.
Oct 20, 2010 | Nokia 2730 Cell Phone
I forget my security code of nokia ce0434
You may try default phone and security code to remove
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
Sep 07, 2010 | Nokia 1650 Cell Phone
I have re-inserted my memory card of Nokia N73. but is showing "memory card not inserted"
ur memory card may damaged or used password in memory card. pls check other phone to confrm
Jan 11, 2010 | Nokia N73 Cellular Phone
Where do i have to insert the memory card in Nokia 6600?
Hi and welcome to FixYa,
The SD memory card is inserted underneath the battery below the SIM card. The same lock the holds the SIM card also locks the memory card.
Good luck and thank you for using FixYa.
Apr 09, 2009 | Nokia 6600
Phone memmory not storing numbers
hi there try to reset your phone enter this code *#7780# or *#7370#....
Feb 18, 2009 | Nokia 6500 Slide Cellular Phone
Cell Phones Logo
96 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
