Question about Garmin GPSMAP 176C GPS Receiver
Batteries last only 20 minutes?
Hi, I use brand new 2000 NiMH batteries in my GPSmap 176C, which I use for my camera as well. They are fully functional. Nevertheless after 20 minutes the Garmin warns of empty batteries and shuts down some seconds later.
I am punching in waypoints and so the backlight is on for all the 20 minutes. The GPS is set into simulator mode to save energy (since I am inside anyway). Any idead if this battery sucking is normal or what I could do? PC connections doesn't work because I have not the right sonnector.
Thanks!
  • yorick_obean Jan 21, 2009
    Thanks so much for trying to help me. Unfortunately, the GPSmap 176C doesn't offer to choose from a a battery type - nor can I hokk it up to a computer for an update (due to the lacking connector at the PC. But thank you anyway!
NiMH batteries work on less voltage than Alkaline batteries, so the unit thinks the batteries are low when they are just the wrong type, put Alkaline batteries in {and turn off the backlight if possible} and you will get your 8 hours of use.
Posted on Jun 16, 2009
  • 50 Answers
Most Garmin GPS's will let you change the type of battery you use (Alkaline or NiMH) in your setup/system menu. Choosing the correct type should improve the effectiveness. Also a firmware update is always recommended in helping the overall unit run smoothly.
Posted on Jan 21, 2009
All batteries run out of power real quick. I can only shoot 20 pictures with a brand new set of batteries with my EX-FH20. Both alkaline and NIMH batteries die within minutes
What you need is HIGH RATING cells and so try and get NI-MH with rating over 2000mA or a higher grade along with a good rechargable unit and your cells will last longer than using low type cells.
Sep 03, 2011 | Casio ADC100 AC Adapter AC Adapter Battery...
Battery indicator reads empty when batteries are fully charged
It looks like your question was cut short... all I see is "Battery indicator reads empty when batteries are..."
With my experience with the Pentax *ist DL, I think the problem is probably that brand new batteries still show "empty" on the indicator.
Chances are that you are not using the CR-V3 camera batteries in your *ist DL. I have tried 2400mAh NiMH rechargable batteries and brand new alkaline batteries in an attempt to save money.
Neither lasted anywhere near as long as the CR-V3 batteries! While you may be paying $15-$20 for two CR-V3 batteries, they last a LONG time!
One of the advantages of DSLRs (and digital cameras in general) is that you save money by no longer buying film and paying for developing/prints. But, even at $20 for two CR-V3 batteries, I save money! I am able to take several hundred photos on a pair of batteries (I think the manual says 500+) instead of $10-$15 ($2-$7 for film + $8 dev/print) for every 24-36 photos!
May 29, 2010 | Pentax *ist DL Digital Camera
Need repair 176C GPS ok using plug power but battery damaged internal batt connection and will not turn on using int batt device is in NY buddy has few bucks & not wanting to buy new
I have done repairs to similar thing, what I have done, is get a "Pack" of batteries, with leads on them, similar to a cordless phone battery, but the same voltage as the ones the GPS uses, now, solder the wires onto the correct terminals. or the circuit board, make sure you rid every trace of corrosion too.Your good to go.
Feb 23, 2010 | Garmin GPSMAP 176C GPS Receiver
NIMH Battery goes off after 20 shots for Nikon Coolpix L01
the camera takes just about any AA pair of batteries ... lithium will give you the most pictures .. your NiMH batteries should last longer unless they are old .. you may have one weak battery ... you can try a pair of standard alkalines to see if there is something wrong with the camera .. if those work ok then you need a new set of NiMH ... there is a new type out called "eneloop" .. they are just like normal NiMH except they dont go dead when you store them .. even after a year they are still charged .. with normal NiMH batteries as they age they will self discharge in 2 weeks or so .. so you have to charge them just before you use them ..otherwise they go dead on their own .. if you charge them then not use them for a week then you will not get nearly as many pictures ... the eneloop batteries fix that .. you can also recharge them many more times than standard NiMH batteries .. they cost about the same ..
Oct 06, 2009 | Nikon Coolpix L1 Digital Camera
The GPSmap 176c does not turn on. I have put in new batteries and cleaned the metal parts of the battery receptors
Do you use rechargeable batteries? The 176C seems to be extremely picky about the voltage. I had the same problem. Afer changing to non-rechargeable batteries, everything works fine again. Not great for the environment, but for my bearings.
Jul 12, 2009 | Garmin GPSMAP 176C GPS Receiver
Will not power on
Did you use rechargeable batteries? The Garmin seems to be extremely picky about enough voltage. I had good rechargeables which I use in my foto flashlights, but they did not suffice for the Gamin. Simple non-rechargeable batteries ones solved my problem. Not good for the environment, but for my bearings...
Apr 21, 2009 | Garmin GPSMAP 176C GPS Receiver
S9500 : rapid battery discharge
Check your focus control on the left side of the camera is not set to "continual focus" CF, as this will constantly adjust focus and run your battery down quickly.
Also NiCd batteries are not very useful -use Nickel Metal Hydride (NiMh) which last longer and don't suffer from memory effects. These batteries don't reach full capacity until after a number of recharge/drain cycles.
Mar 10, 2008 | Fuji FinePix S9500 Zoom Digital Camera
OBSCENELY short battery life in PowerShot A40 :-(
You need to use Nimh battery specifically designed for digital
camera use with high ampacity usage.
Jan 05, 2008 | Canon PowerShot A40 Digital Camera
Garmin GPSMAP 176C GPS Receiver Logo
127 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
