Question about RCA F32450 32" TV
A32B43W Power Problem
I have a 32" Zenith A32B43W set. When Power is pressed either on the remote or on the set itself, the relay clicks on then off immediately. This happens most of the time with the set never coming on. Every once in a while the relay stays on and the set works fine. We think this happened during a lightning storm... Is it a relay problem or something bigger?
    Genius:
  • 1,139 Answers
The relay is part of the overcurrent circuit. This denotes a problem in the HV power supply. Try to resolder the relay just in case the it has a cold solder joint. If this does not help get a schematic and a multimeter and check to see if the voltages around the power supply seciton of in order. If you do not have a background in electronics please take the set to a TV repair shop.
Posted on Sep 16, 2007
SOURCE:
Zenith a27b41w won't turn on. It just clicks whether using the remote or the button on the tv
Probably a power supply problem. The click could be a relay closing
Nov 04, 2012 | Televison & Video
The Zenith Digital TV Converter DTT900 needs reprogramming
1) While pressing & holding down the TV POWER button, press CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on or off. 2) Release the TV POWER button when your TV is turned on or off. *Each press of the channel button sends a manufacturer code (1-45) to your TV, one after the other. Note: You may have to do this every time you change or remove the battery, as the remote will reset itself to the default code.
Nov 25, 2009 | Televison & Video
I plug it in and I hear a clicking inside over and over and the power light blinks then goes solid the clicking stops a sec then it repeats the cycle again. Doesn't matter what I press just keeps doing the...
that clicking noise is a relay. there seems to be some problems with the power supply. it is not getting enough voltage. possible capacitors gone bad. inside power supply
Oct 31, 2009 | Zenith C32V37 32" TV
My zenith tv picture is bigger then screen
keep the tv ON.then with your remote control pointing it towards the tv press -------- # -------- this button for more then 5 to 10 secods.
to reset.this is if you have orignal remote.
Apr 03, 2009 | Zenith A32B43W 32" TV
Remote will not communicate with television
What kind of television are you trying to program the Zenith Remote to? If it is a Zenith TV, it should work after replacing the batteries. If not, the remote returns to the factory default to the Zenith Code. If you changed the batteries cuz the unit would not function, the remote itself may be defective. Replacements are still available at a ZENITH dealer at a nominal cost.
Apr 02, 2009 | Televison & Video
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
Watching TV and then POP!
ok, your tv is still on repairable condition,smoke that came out from your unit due to an ic that burned,I'm sure it's the vertical ic replaced with a new one.same part number.
Oct 23, 2007 | Zenith A32B43W 32" TV
Power button
No, you cannot disconnect the power switch. A defective power switch will not make the set turn on and off by itself, because the power relay is actually controlled by the microprocessor. The microprocessor in your set is trying to start the set but immediately detects a fault somewhere and shuts the set back off. This can be a difficult problem to solve and the set should be serviced by a qualified tech.
Aug 17, 2007 | JVC AV-32D305 32" TV
My tv will not turn on.
First of all, forget about the remote and see if the TV functions normally using the buttons on the front of the set itself. If the TV will not power on with the power button on the set itself, then something is wrong inside the TV. If the set works fine from the front buttons but no longer responds to that remote, then the remote has either gone bad or was accidently set to a different brand. In this case, look for the original book that came with the remote (or TV if it is the original remote) and follow the instructions for setting the remote back to Zenith. Try that and post your results here.
Aug 09, 2007 | Zenith C27A24T 27" TV
RCA F32450 32" TV Logo
47 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
