Question about Frigidaire FEF366 Electric Kitchen Range
What dose a thermal fuse protector look like? I have a frigidaire range my stove top works, but my oven has no functions working.
  • Official Brand Answer
  • 4,342 Answers
Hello Jason Nicholls - From what you have described it sounds like the unit has a faulty element(s) or could possibly be experiencing a wiring issue with the EOC. Try resetting the oven by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately to properly diagnose the unit.
Posted on Jan 14, 2013
  • 833 Answers
SOURCE: My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Posted on Dec 13, 2007
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
rockitman187
  • 2559 Answers
SOURCE: Surface of stove heats very hot when oven is on.
This is normal and designed to do so.
Posted on May 15, 2009
SOURCE: Frigidaire Gallery Series ES340 ceramic-top range:
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
Posted on Sep 05, 2010
My frigidaire stove made a loud pop while oven was on and then lost power....stove top elements working stove clock not working tested fuse, and changed it still not working
Thank you for your post, friend!
I understand that your Frigidaire range made a loud pop while in operation and lost power. I noticed you stated that the stove top is working and you have changed out the control board but the oven is not working. It could be a possibility that your terminal block or wiring harness has shorted. I would recommend contacting a professional technician to come out and perform a diagnosis and repair on your range. This will help to avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Feb 24, 2015 | Frigidaire Kitchen Ranges
Have error message on my ne fiigidaire gallery gas range...error Sd...oven will not work and timer etc will not function properly
Some stoves have an override on the oven side... oven pilot light must be lit or it will go to safe mode. if it is an auto light then check the fuse usually located up by the top left side on bk of stove.
Jan 02, 2015 | Frigidaire Gallery 30" Self-Cleaning...
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
My burners work on the stove but the clock, and over buttons will not come on, so I'm unable to turn on the oven. I have a Frigidaire model FEF366EMC
Check for a blown thermal fuse protector. Located on the back wall of the oven behind a sheet metal cover. Disconnect power and you can ohm it out.
Jun 27, 2010 | Frigidaire FEF366 Electric Kitchen Range
All stove top elements and oven wont work
Go to your home circuit/fuse panel and reset the fuse or circuit breaker for the range.
Dec 30, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Sep 17, 2008 | Frigidaire FGFB75D Gas Kitchen Range
Frigidaire Electric Range ES200/300
there is sometimes a thermal fuse inside the caseing might have to take the top off if not then you will need a new timer be safe and unplug
Jun 15, 2008 | Frigidaire PLEB27T9DC Electric Double Oven
Frigidaire es300
you could have a power problem.. the stove will still work with half the power..like the burners on top will work. if thats not it. the wirers could be crossed or you may have a thermal cutout thats bad. but when the tco is bad broil and bake should not be working.. hope this helps
Feb 27, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire FEF366 Electric Kitchen Range Logo
63 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
