Question about Microsoft Visual Basic 6.0 for PC
I want to add a calendr in my vb form when i clicked on perticular date that gies me the report which already stored in my database which has stored how many person are entered on perticular date please help me to slove this problem thank you
  • rahulmandwal Jan 21, 2009
    my computer of c
    President:
  • 392 Answers
I suggest you this URL:
http://www.codeproject.com/
You will get your answers there simply. This websit eis the source of .NET programming like C#, VB, J#, ASP and ....
enjoy it!
Posted on Feb 02, 2009
How to print database in vb
To Print a Database you would require to create a Report. There were many ways of creating reports in Visual Basic 6.0. Hereby I am giving you an example of Data Report.
Printing a Data Report
Printing a data report can be accomplished in one of two ways. The user can click the Print button that appears on the data report in Print Preview mode (using the Show method), or you can programmatically enable printing using the PrintReport method. If an error occurs during printing, trap it in the Error event.
Choosing to Display a Print Dialog Box
When printing a report programmatically, you have two choices: to print by displaying the Print dialog box, or by printing without displaying the dialog box.
To display the Print dialog box
  1. Add a CommandButton to a Form.
  2. In the button's Click event, place the following code.
DataReport1.PrintReport True The Print dialog box allows the user to select a printer, print to file, select a range of pages to print, and specify the number of copies to print.
Note Printers must be installed on the computer in order to present a choice of printers.
Printing Without a Dialog Box
In some cases, you may wish to print the report without user intervention. The PrintReport method also gives you the option of selecting a range of pages to print, either all, or a specified range.
To print without displaying the dialog box
  2. In the button's Click event, place the following code:
DataReport1.PrintReport False
Or, to specify a range of pages to print, use the code below:
DataReport1.PrintReport False, rptRangeFromTo, 1, 2
Mar 11, 2014 | Microsoft Visual Basic 6.0 for PC
How to make the library managment project with VB.Net & using MS Access as for database.& please help me out what code should I use for making that project?
firstly you have to create a database and in that you have to create tables as per your requirement.
secondly, create forms in vb and connect the database, as per your requrement. it is not possible to give all the codes. use some e-books.
Nov 19, 2009 | Computers & Internet
How to create crystal report in asp.net with vb script code
You can open the Crystal Report (should be installed with Visual Studio first) after you designed your database, then you have to connect the Crystal Report to the right database (the one which you store financial information in your case), then you can create your report easily by putting the desired variables and designs. Then you have to call for that report with a code within visual basic.
Apr 15, 2009 | Computers & Internet
Put a calander
You can get your answer easily in http://www.codeproject.com/ by a simple search.
Enjoy it!
goodluck
Jan 21, 2009 | Microsoft Visual Basic 6.0 for PC
How to print picture wiht crystal report 8.5 using ms access ?
I am not sure if I understand your question correctly but here goes..
if you want to click on a link within crystal report and them show the picture you can use OLE..
in the tools menu click on OLE, select "Create From File" ,
select the object type eg: MS bitmap.
Select Link
Browse to folder where the image exists. and select it
you can now select a Icon or leave as is and it will display the image name..
Clikc OK
now when you run CR if you click on that link it will open and display the image..
if you just want to add a Image to CR
in the Tools Meni select Insert, Picture browse to the folder where the image is stored and select it then click OK and it will be displayed
I hope this helps
Jan 17, 2009 | Computers & Internet
How to add columns(Vertical) only in Msflexgrid from database table using VB.
you have to open your current project in VB then go to "add references" (its somewhere in the menu bar) then go find microsoft acess and add it as a reference. then go to object browser and you'll find all the functions you need to interface between your project in VB and MS Access.
good luck !!!
Dec 30, 2008 | Computers & Internet
C90 epson printer "appears" Cannot be used error
1/ first of all please , don't forget change , date vacate , , date , please ( yes sir ) , ,
2/ begin , adjustment , will go up this window comes to , click already at , Accept ,
3/ , click already at , Perticular adjustment mode ,
4/ click at , Waste ink pad counter , to strip [ zone blue ] , then press , ok ,
5/ already will go up a window , Waste ink pad counter , click at , check , clip_image010.jpg
6/ press , ok ,
7 / click already at , lnitiailzation ,
8/ press , ok ,
9/ last step , press , ok , then close , then open again , only ( yes sir ) , ,
Dec 17, 2008 | Epson AcuLaser C900 Printer
Accessing data
Dear reader
Place an ADODC control on your form in VB.
In the properties of the ADODC control goto the TAB General.
click "Use Connection String. With the button Build you can point to your database.
Thats it.
With the following code you can connect to db:
With Adodc
.RecordSource = "SELECT * From YOURTABLE"
.Refresh
End With
Now you have the table in the adodc control.
you can now do this:
Label1.caption = Adodc.Recordset!YOURFIELD
YOURTABLE = the name of your table in the database.
YOURFIELD = the fieldname in YOURTABLE you want to show.
Kind regards Fred.
Jul 04, 2008 | Microsoft Office Access 2003 (077-02871)...
View Reports
Hi, There a couple of different way you could do this and I have put two lots of VB code below that you can modify and use. Firstly you create the Combobox list by choosing the option that you will type the values yourself, you then type in all your report names on each line. After that you can then go to the VB code editor and paste my code in and modify it by changing my report names, (Customers) etc to your report names. Make sure you choose the Combobox and the On_Click option in the VB editor to paste the code into.  I like the first method better which checks the value of the Combobox and then opens the corrosponding report in the maximised form. The second method does the value check before running an assigned macro to open each report. With this you must first assign macros to each report in Access.  Remember each of these bits of code must be placed between the "Private Sub" heading and the "End Sub" ending, and change the "Combo23" name to reflect your combobox too. If you need a hand just email me.
First Method
If Combo23.Value = "Customers" Then
    DoCmd.OpenReport "Customers", acViewPreview, acWindowNormal
    DoCmd.Maximize
ElseIf Combo23.Value = "Customers 1" Then
    DoCmd.OpenReport "Customers1", acViewPreview, acWindowNormal
    DoCmd.Maximize
ElseIf Combo23.Value = "Customers 2" Then
    DoCmd.OpenReport "Customers2", acViewPreview, acWindowNormal
    DoCmd.Maximize
End If
Second Method
   DoCmd.RunMacro "Macro1"
   DoCmd.Maximize
    DoCmd.RunMacro "Macro2"
    DoCmd.Maximize
    DoCmd.RunMacro "Macro3"
    DoCmd.Maximize
End If
Oct 28, 2007 | Computers & Internet
Microsoft Visual Basic 6.0 for PC Logo
171 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
