Maytag bravos XL washer leak - Washing Machines
MNfisherman
  • 11896 Answers
SOURCE: Maytag Bravos washer leaks.
Either the valves are leaking themselves or tub is leaking. Most likely the water valves.
Posted on Oct 24, 2009
hattonhall
  • 349 Answers
SOURCE: My Maytag Bravos washer is
Water shroud punctured. Do not use machine.
Highvoltage+Water risks electrocution.
Posted on Oct 25, 2009
  • 56 Answers
SOURCE: Any problems with Maytag Bravos mvwB750w?
you would be better off with a front load. they (bravos) dont sell all that well and probably wont be around too long
Posted on Feb 07, 2010
sonicboomele
  • 1557 Answers
SOURCE: We just bought a Maytag Bravos washer. We were
it should be very tight if you look down the middle of the adjitator it should have a aloy screw that should be done up very tight
Posted on Apr 24, 2010
  • 4 Answers
SOURCE: How reset clean washer reminder on Bravos washer
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset this indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Posted on Aug 11, 2010
Fabric softener not dispensing. Water floods over the top and leaks out to floor
The dispenser should be removable. It uses syphon method to drain. Take it out and clean it.
Apr 11, 2016 | Maytag MVWB850YW Bravos XL HE White Top...
Why is the washer slowly leaking water into the back of tub between washes?
There is grit in the water valve holding it open just enough to allow the water to seep by. You should get a filter system for your washer and replace the water valve, Grit is not covered by most warranties.
Mar 13, 2016 | Maytag Bravos XL 4.6 cu. ft....
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to repairclinic.com and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
Jun 19, 2015 | Maytag Washing Machines
LEAKING SMALL AMOUNT OF WATER UNDER FRONT LEFT CORNER OF WASHER. LEAKS WHENEVER WATER GOES INTO THE DETERGENT DIPENSER.WHAT IS THE CAUSE?
Get a level and check the level of the machine. The front should be slightly higher than the back and even left to right.
Jun 02, 2015 | Maytag MVWB850YW Bravos XL HE Top Load...
My washer leaks small amount of water on the floor in front area of machine.
the overflow hose may have disconnected? a line hose may be worn and frayed. check ur water pump hose lines etc
Jan 15, 2015 | Maytag 4.6 Cu Ft. Granite Bravos XL HE Top...
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Water leaking from the bottom of my maytag bravos washer
Depending upon the age of your washer, the pump may have begun leaking
Apr 21, 2013 | Maytag Bravos MTW6600T Top Load Washer
Washing Machines Logo
1,566 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
