Question about 3Com Switch 5500G-El 24-Port 10/100/1000 (3CR1725091US)
Haw to make factory default to switch 3com 5500g
I wont make factory default or reset to switch 3com 5500g
3 Suggested Answers
SOURCE: inherited 2 switches 3com 4228g (3c17403) password problem
I haven't worked with these switches but generally settings such as ip address and factory defaults can be set through the Console Interface (CLI). You will need a null-modem cable to access this and a terminal client (Windows Hyperterminal works).
Hope that helps
Posted on Jan 01, 2009
  • 9 Answers
SOURCE: 3com superstack 3 switch 3300 reset himself randomaly need a solution
take it to the 4s garage, if you want to find out the problem by yourself,you first have some professional tool , there are some diagnostic that always can figure out the problem i can show you: www.xcardiag.com/
Posted on Apr 12, 2012
3com AP 7250 - how do i reset it to factory defaults if i don't have the admin password ?
It will have a reset button on it, hold it down for ten seconds and it should reset the router to factory.
Mar 12, 2012 | 3Com Wireless LAN Access Point 7250...
Hi, I have two VM citrix servers that i have load balanced using windows NLB. My users are on a different subnet so I have the load balancing configuration set to Multicast mode. (I have a second nic in...
I have not worked with 3Com switches only Cisco, but I thought I would post this as I found it when googling:
multicast routing-enable pim
on the vlan interfaces:
interface Vlan-interfacex
ip address ***.***.***.*** ***.***.***.***
igmp enable
pim dm
Those commands should help you get multicasting to work. notice, Vlan-interfacex means you will have to do it for each Vlan you created. Some switches do not include multicast support in their base models but make you buy additional licenses to enable it. Cisco is like that, not sure about 3Com.
Chris
Sep 08, 2011 | 3Com Switch 5500G-EI (3C17261) Network...
How do I reset the switch?
select restore factory default in administration tab or push reset button
Jan 18, 2011 | 3Com Baseline Switch 2948-SFP Plus 48-Port...
Reset a switch
Please login in Switch usign Default ip
then in last menu they give one option reset switch as factory default setting please click on this.
May 10, 2010 | NetGear GSM712 Managed Gigabit Ethernet...
Default password is incorrect or reset doesn't work
The default ip is 192.168.1.1
default user-name and password for the 5 models of 3com are as follows.:
1.
3com default ip: 192.168.1.1
username: n/a
password: admin
or
2.
user-name: adminttd
password: adminttd
or
3com default ip 192.168.1.1
user-name: admin
password: n/a
or
user-name: n/a
password: PASSWORD
OR
5
user-name: root
password: !root
ok try
this
Note that at time you will need to set your local ip of your pc from which you are acess the device to the same range...
That is for example 192.168.1.10
Good luck
uttam
Feb 26, 2010 | 3Com 2816-SFP Plus (3c16485-us) 16x1000...
How to reset it?
Open your browser and enter the 3Com URL configuration address
http://192.168.1.1
Then go to the Menu Screen and select Reset to Factory Defaults.
When to change the rouer's wireless settings then you will also need to apply these changes to your wireless card in the computer so it can connect to the 3Com router.
Feb 10, 2010 | 3Com 3CR858-91 Office Connect Cable/DSL...
3012 3com router
Just find the "reset" button that can be pressed by paperslip and this will reset router back to factory settings
Sep 14, 2009 | 3Com RTR 3012 Router (3c13612-us)
How to recover old password on 4300 switch?
you manually RESET your device by pressing the "reset" button at the back. it will be reset to factory setting with the default password loaded.
Regards!
Jul 13, 2009 | 3Com 3C17100 /RETAIL3COM SUPERSTACK III...
Inherited 2 switches 3com 4228g (3c17403) password problem
Hope that helps
Dec 31, 2008 | 3Com SuperStack 3 4228G (3C17304-US)...
3Com Switch 5500G-El 24-Port 10/100/1000 (3CR1725091US) Logo
324 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
