Question about Price Pfister Ashfield Single Control Lavatory Faucet ...
What shower handle is compatable with price pfister 7105 valve
blueextc3221
  • 15935 Answers
SOURCE: my price pfister tub valve leaks
there is an o-ring inside the valve that seals. It has failed. They should sell a rebuild kit where you bought it, or dis-assemble, and take the failed oring in to have it matched to a new one.
Posted on Dec 26, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Price Pfister ashfield collection shower single lever.
This sounds like a proper with your water heater. If you just installed this new shower head. First take it off and make sure that the hot water valve is opening fully if that checks out then go to the water heater and make sure the pipes check out ok and also that the heater is ok. Try putting a water heater blanket on it. Also try getting some pipe cover and cover the hot water line so on really cold days or not you will have warmer water
Posted on Feb 13, 2009
SOURCE: I have a price Pfister Marielle kitchen faucet.
There is an o-ring around the valve body inside the outer shell. This needs replacing -- sometimes you can match these at hardware stores.
Shut water off, remove handle, pull up outer shell, you'll see the o-ring.
More info, let me know.
Charlie
Posted on Aug 28, 2009
Testimonial: "Thank you...problem solved :-) No more leaks. "
  • 112 Answers
SOURCE: I have a price pfister
You have to turn water off to shower and remove handle then cartridge lock ring then there are two washers and srpings that can be popped out with small screwdriver.Lowe's has replacement springs and washers ,be sure to mark position cartridge was because that is very important to reinstall the same way it came out.
Posted on Jun 12, 2011
SOURCE: set water temp
remove the handle, find the plastic disk with teeth, pull out disk and turn to left for hot, right for cold, set disk back in place, then replace the handle, repeat as necessary.
Posted on Feb 22, 2012
How do I remove a Pfister Marielle metal lever handle?
Bear with me, please. Adjust the temp at the physical valve?
Interesting at the least. Never seen or heard of that. They come up with something new everyday. I'm going to follow this for my own benefit. Thank you. And good luck. - Ned
Jul 23, 2014 | Price Pfister Home
Set water temp
Feb 22, 2012 | Price Pfister Plumbing
I need a replacement cartridge # 17196-0100k for a single handle price pfiser shower valve. where can i order one?
I have a single handle price pfister shower valve Model 17196-0100k .No cold water.It's coming hot on both sides.
Mar 28, 2011 | Price Pfister R89-7PC0 Chrome Portland...
Shower head slow drip when valve close
You need to rebuild the cartridge. There are small o rings inside and dirt and other particles in the water tear them.
TAPE OVER THE DRAIN UNTIL FINISHED.
Turn off the water, pull the handle, unscrew the retaining portion of the bezel usually with thumb traction ribs. THe whole plactic part pulls out. Take this with you to a plumbing place, and likely you can get one for free...
Alternatively, you can call Price Pfister, and they well likely send what you need to your door...probably for free...
Mar 08, 2011 | Price Pfister R897EBK Brushed Nickel...
I have a Price Pfister Model no. 808 DK00 single handle bath tub/shower faucet. I am only getting hot water coming out when the handle is turned on. This problem just started. It was working fine for about...
It's likely that you have some sediment that has accumulated in the cold water valve and has clogged it. The model number you have cited above is only for the trim (rather than for the valves behind it). Assuming that you have a Price Pfister valve, they don't have built in filters, so you're probably going to have to either clean or replace the valve.
Sep 17, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Swaping Pfister Shower leaver handle
it must be the same model number,most models come in different colors and styles.
Feb 27, 2009 | Price Pfister 01-111 Shower Head, Tub...
Price Pfister Ashfield Single Control Lavatory Faucet ... Logo
591 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
