Question about Dryers
My whirlpool dryer Model #LGQ9858PWO is not drying what is wrong
Master_Tech
  • 770 Answers
SOURCE: dryer doesn't dry
no but are you sure your replacement parts are correct the cycle stat is usally running about 140 - 160 temps did you switch the high one and the cycling wires or parts?
Posted on May 12, 2008
SOURCE: dryer slow to dry
Take the vent off the back of the dryer and dry a load unvented too make sure you don't have an obstruction in the line too the outside. If still takes too long too dry you might have a bad operating thermostat located on the blower housing it is a 4 terminal thermostat.
Posted on Jul 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
Posted on Mar 26, 2009
garing
  • 998 Answers
SOURCE: HEAT WORKS FOR AWHILE THEN STOPS
coils on gas control get hot and stop working you will need to change them...thumbs up
Posted on Aug 10, 2009
  • 2694 Answers
SOURCE: Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Posted on Apr 05, 2010
Testimonial: "Thanks so much, that solved the problem. We could not believe the amount of lint that came out of the tubing!"
I have a whirlpool dryer Model # LEB6000PQ0 It seems to be heating sometimes, but not all the time. Could that be a heating element, or something else? We have to dry a load several times...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 24, 2011 | Whirlpool Dryers
I have a whirlpool dryer model #len 2000pgo and my wash doesnt get dry but dryer gets warm ...not hot like it should. what could be wrong???
Is this a gas or an electric dryer as the model number doesn't match any dryer and depending on gas or electric it can be very different things that are wrong. The gas dryer will probably need a new set of coils but I need to know what kind of dryer it is to narrow down the exact problem. Please let me know and I would be glad to help you fix this as fast as possible.
May 23, 2008 | Whirlpool Dryers
Whirlpool model 5700 not drying, no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 19, 2010 | Whirlpool Dryers
I have a Whirlpool commercial dryer model number LEQ7030KQ1. I will wash a load a clothes in the wash machine and they will come out so they are as spun dry as they can get. The problem I experience is...
Did you mean that you need to press manually to have the drying done well, if so the program settings is what is wrong?
Does a good timing setting work on the set?
Please clarify more.the fault you are.experiencing.
Sep 28, 2010 | Whirlpool LEQ7030KQ Electric Dryer
Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Dec 16, 2009 | Whirlpool Dryers
Whirlpool model no LEB6200KQ0 will only dry on the Very Dry Cycle. I have to run on the timer dry 3 to 4 times to get the clothes dry.
Judging from the model number, this is an electric dryer. There can be several things wrong with it. I would start with the vent. Make sure it is not clogged (especially at the end) or kinked behind the dryer. Also, check your breaker. Electric dryers can run with one half of the 220v breaker tripped. Try switching the breaker to the off position and then back on. That may solve your problem, but if it returns, you will need a qualified electrician or appliance service tech to see where the problem is originating. If neither of these help, you will need a tech to see whats going on inside the dryer. hope this helps
Nov 09, 2009 | Whirlpool LEB6200 Electric Dryer
Aug 10, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer stops working after 2 minutes into cycle
If it is new, is it not under warranty?
does it run ok on air dry? Is there good air flow?
post your answers in comments
May 14, 2017 | Whirlpool WED9500T Electric Dryer
I have a whirlpool dryer model #len 2000pgo and my wash doesnt get dry but dryer gets warm ...not hot like it should. what could be wrong??? its electric
Your venting plays a huge part here.Do you want to be 100% sure about the vent ,ok,for just ONE load remove the vent hose from the dryer keep atleast 3 feet clear for the air to exit dryer.Now select TIMED dry cycle for 60 minutes.Start dryer and make sure your in a heat setting (not air fluff).The normal load should dry in 60 min,If it does than you now you have a block in the venting.
Dryers Logo
55 people viewed this question
Top Dryers Experts
