Question about Alpine Car Audio & Video
Subwoolfer how do i go by sending my subin andgettingit repaired
    Problem Solver:
  • 10 Answers
You can call Sound Repair 321-690-0808 for estimate.
Posted on Jan 28, 2009
My amp turns on but dosent make my subwoolfers sound.why?
Are the RCAs connected to the stereo? Are the speakers connected to the amp?
Sep 22, 2010 | PPI2240 Car Audio Amplifier
I have model1156 8x21 @1000yds binocular that needs repair. send me a price and address to send it without case
If you are in the U.S., kindly send the binocular without the case to the following address:
Attn: Repairs
8500 Marshall Dr.
Lenexa, KS 66214
Also, kindly print and fill this form and send it along with the package.
For more details and instructions, kindly refer to this article:
Hope this helps. Thanks for using FixYa.
Sep 14, 2010 | Sport & Outdoor - Others
My computer is not recognizing my Max V8 Mp6 player made in China? HHHHHHHHHEEEEEEEEEEEEEELllllllllllllppppppppppp
click on safely remove toolbar on task bar then you connect again then you can see in your task bar not recognized click on that and you can see there are ten ports one port is given in dark black color click on that with mouse right side and repair then take form usb and take video player in mp6 an connect again and take removal disk m you can see your mp6 folder on your computer this will work on windows xp you can take any experiment if you can known it take yahoo answers and type it hope you enjoy bye
by subin
Jan 30, 2010 | Motorola Audio Players & Recorders
I have a similar issue as "Alan" 11/1/09. No blinking green light or display for the longest time, then it finally comes on. Hold in the power button, count to 30, sometimes it will start blinking... just...
brinz97, Yes, to your ?.. Do this first!! Turn it off and subin a working monitor. Place 940MW in safe place! Now check to see if it is still covered by Samsung warranty. The next thing for you to investigate will be YOUTUBE!! If you haven't been there yet, you sure are missing a ton of stuff on typical repairs of lcd monitors!!! Only you can make the decision to spend $12 and fix it yourself or $40-$100 to contract out the work! A very good clue was when you stated "great picture...when it comes on" !! This leads me to believe that a simple repair to the "switch-mode-power-supply" is all that is needed. It could be as easy as resoldering 1 "frosty/cold" solder joint or replacing 4 to 6 "electrolytic filter capacitors" that have failed prematurely!! To view some of these goto or any of the sites that deal with BAD capacitors. Here is the advice you need. I say "If you are able to effect a repair for less than $15, then also think about getting a new one also with the $ saved!!! Then you will also have a working SPARE unit on-hand. If you need more help get back here to fixya with another post to your original. or I'm 12fixlouie
Nov 10, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Need dimensions for 12' 450watt IMPP Subwoolfers for proper air space
Subwoofers differ in only one way. You get an "Open Air" and a "Closed air" subwoofer, That being said, you'll have to check on your magnet which one you have to make the boxes for that sub. If it is an "Open air" Subwoofer, you should see a "wire mesh" or "grid" in the centre, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.
If it is a "Open air" sub, your boxes should be sealed with silicone, and no ports are to be cut in your box.
With "Closed air" subs, you should have 2 ports below your sub and the port sizes should be around 50mm in diameter. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 200mm, depending on the frequency of bass you require.
On a 12 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 27 liters, meaning that you will end up with a box of 16 inches high, x 16 inches wide, x 16 inches deep. Or 320mm high, x 320mm wide, x 320mm deep.
Oct 14, 2009 | Car Audio & Video
Windows start up repair keeps comming up every time i start it up
Try getting teh Windows Disk & run the windows repair utility.. this will fix any errors with the opearting system.
Note : Windows repair will not delete files however you might require to reload your drivers ...
Mar 23, 2009 | Dell Inspiron® 1501 (N11157) PC Notebook
Sending attachments in Outlook 2003
Have you tried the repair option in Outlook? From the help menu, you can choose Detech and Repair. Also, you can choose to repair all of Microsoft Office from the Control Panel, Add and Remove Programs, find Microsoft Office, and click change. Then You can choose to repair.
Jan 26, 2009 | Microsoft Office Professional 2007 Full...
Cd stuck in my 2002 venture
The only way to address this is to pull the changer out and send it out for repair, the loading mechanism has failed, make sure to send a note that you want the CD's back from the repair shop. Don't go through the dealer, they send it out to an authorized GM electronics repair center same as you will have to do, one diff, they double the repair bill.
Nov 25, 2008 | 2002 Chevrolet Venture Passanger
Part # for aspire 5043 motherboard
There are a few motherboard this series:
MB.AA101.001RF - Refurbished Main Board AB2 V128 w/MDM&Cable
MB.AA101.002RF - Refurbished Main Board AB2 V64 w/MDM&Cable
MB.ADX01.001RF - Refurbished Main Board AB2.UMA w/MDM/Cable/RTC
MB.ADX01.001 - Main Board Ab2 UMA w/Mdm/Cable/Rtc - Repair Flow Only (repair flow. send failty motherboard in advance)
MB.AA101.001 - Main Board Ab2 V128 w/Mdm&Cable LF - Repair Flow Only (repair flow. send failty motherboard in advance)
MB.AA101.002 - Main Board Ab2 V64 w/Mdm&Cable LF - Repair Flow Only (repair flow. send failty motherboard in advance)
other guy asked for aspire 5100 motherboard, look here
Nov 22, 2008 | Acer Aspire 5100 Notebook
Car Audio & Video Logo
26 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
