Changing developer in afficio 450
Wat wil the best procedure or step to follow after replacing developer in afficio 450... wat to be run in service mode...
  • 1 more comment
  • thraser
    thraser Jan 26, 2009
    hi mrbonz i olridy chnge developer of my copier afficio 450 but the copy is stil not equal its faded... in tinkz my copier dont supply toner in developer unit...bcuz wen it hapen i push the toner and it return in good copy agen and after 50 to 100 copy faded agen or lighter copy in some area...?? can u help me wat to do??
  • thraser
    thraser Jan 27, 2009
    Yup i perform first the sp mode b4 i make a copy....but 50 to 100 copies onli i made and its faded agen just like the problem b4 i change the dev.... wat is the sensor at the bottom of the dev. unit...?? becuz i have a guez maybe itz the sensor of the toner supply???
  • thraser
    thraser Jan 28, 2009
    oki i olridy check the sp5-106 it is in default... the sp2 -207 is oki the toner bottle is turning... so it can be the TDS... wat is TDS is der a way can be fix diz without replacing...???
  • 42 Answers
Preform SP 2-801 then 2-805.That will do it!
Posted on Jan 21, 2009
  • 1 more comment
  • Hadley Hudson Jan 26, 2009
    When you changed dev. did you run these sp modes right after or did you make a bunch of copies before you ran sp 2-801.It is a must that when you replace run this WHEN installing other wise the toner drop rate will not be correct.Let me know!
  • Hadley Hudson Jan 27, 2009
    Ok,first check ADS level - SP5-106 should be set at default ( 3 ).Then check if toner bottle is turning by SP2-207.Open door and place a piece of paper in the door interlock to see if the bottle is turning.If it is, the TDS you saw at the bottom of the dev. unit is probably bad.Replace and run your SP modes for replacing dev..Hope this help's!
  • Hadley Hudson Jan 28, 2009
    TDS=Toner Density Sensor .No, it can't be fixed.They are either good or not,and the sensor you saw under the developer unit is the sensor in question.This sensor detects the correct amount of toner in the dev. to make a copy.I can check and see if I still have one of those for that older model if you like.
Afficio450 replace new developer unit wat procedure to be follow?
No, the 450 is just one of those machines that seem to have PCQ no matter what you do. Given light copies, I'd replace the drum for sure and make sure your ID sensor isn't covered with toner. Dust covered optics will also cause light copies on this model.
Jul 25, 2009 | Office Equipment & Supplies
Afficio 450 developer type 4 or type 5
This machine takes Part Number "887733: Developer Type 5"
Hope this helps.
Jul 05, 2009 | Ricoh Office Equipment & Supplies
Changing developer unit in afficio 450
Remove PCU, remove development unit, remove cover (2 plastic C-clips) remove filter, remove development roller (2 shoulder bolts). Clean roller and empty all developer. Pour in new developer, re-assemble unit. Reinstall drum and Development unit. Place a small piece of paper between the PCU and toner entrance hole to prevent used toner from entering dev. unit during calibration. Perform SP2-801. Remove paper form dev. unit
Apr 24, 2009 | Ricoh Aficio 450 Copier
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Afficio 450 is der a sensor in toner supply
Do you know how to calibrate the toner/developer sensor?
Jan 26, 2009 | Ricoh Aficio 450 Copier
Afficio 450 olridy change developer but the copy is stil faded
There are two service codes that you need to run 2801 and 2805 after you put the developer in the machine.
Press the yellow button on the copier. press 107 on the keyboard. Press and hold the clear button. Then run the service codes.
You have to run the codes first after changing the developer. You might have to replace the developer again to get the correct mixture.
Change the developer in afficio 450
To remove the Dev. unit.
1. Open the right upper cover and front cover.
2. PCU. (☛ 3.11.1)
NOTE: Spread paper on a clean flat surface that is free of pins, paper clips,
staples, screws or any other metal objects.
3. Loosen [A] (! x1)
4. Rotate bracket [B] left.
5. Development unit [C]
NOTE: Pull slowly to avoid scratching or nicking the development roller.
6. Set the development unit on the spread paper.
7. If you are temporarily installing a used development unit for test purposes,
perform SP2-220 and 2-802-1 after installation (☛ Chapter 5, “Service Tables)
Replacing the Dev. material.
1. Development unit (☛ 3.12.1)
2. Remove the development roller (☛ 3.12.3)
3. Empty toner [A]
4. Turn drive gear [B] to ensure that no developer remains in the unit or on the
developer roller.
NOTE: Dispose of the used developer in accordance with local regulations.
Work carefully to avoid scratching or nicking the development roller.
5. Pour approximately 1/3 of the developer [C] evenly along the length of the
development unit.
6. Rotate the drive gear [D] to work the developer into the unit. Repeat [C] and [D]
until all toner is in the unit and level with the edges.
7. Reassemble the development unit
8. Cover the toner entrance hole [A] with a piece of paper.
9. Install the development unit in the machine.
10. Turn on the main power switch, make sure that the machine has warmed up,
then perform the TD sensor initial setting using SP 2-801.
NOTE: When performing this setting, cover the toner entrance hole with a
piece of paper. This prevents used toner falling from the PCU into the
development unit during the TD sensor initial setting and interfering
with the Vref setting (toner density reference voltage).
11. After performing the TD sensor initial setting, remove the sheet [A] from the development unit.
This is how you replace and reset (calibrate) the new Dev. material.
Jan 20, 2009 | Office Equipment & Supplies
Afficio 450 seeting
Auto setting. If you are getting light copies, you might need the developer replaced as well.
Aug 21, 2008 | Office Equipment & Supplies
When developer goes bad you use more toner for one thing, but the main sign is a gray background in your copy. The print should be black but appears to be gray. The ricoh 350/450 was always noted to leak toner and developer as it runs. Check your machine and see if you see any small piles of toner, which also has developer in it, in the machine. Ther are small seals made of felt that need to be replaced if you have this problem. These seals rub against the drum sides....Good luck.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Rico afficio 450
Dev. initialize should only be done when replacing dev.otherwise it will not add the correct amount of toner to the dev.Replace developer and run sim.2-801 in service mode.
Jul 19, 2008 | Ricoh Aficio 450 Copier
90 people viewed this question
