Question about Plumbing
Delta bathroom faust leak from the handle. I replaced everything but the cartridge but still leaks. Another problem is That I can't seem to put the cartridge back in. I tried everything.
  • 234 Answers
SOURCE: Leaking Delta bathroom facet
Is this single handle?If so, you need a allen wrench to take handle okk.But come to think about it you get the tools with the repair kit.
Posted on Mar 13, 2009
  • 659 Answers
SOURCE: how do i disassemble Delta Innovations Centerset
So I believe based on what you are writing, it's a double handle style faucet. So you loosened the set screw that holds the handle on which is located near the top of the handle close to where you would grab. I would totally remove it from the handle just to make sure its not catching on a burr. If you have pulled and it will not come off, you will have to use a handle puller. Your local hardware store should carry them for less than $10. When you see the puller, it will be self explanatory on how to use it. Sometimes the handles can be hard to remove especially if they haven't been removed in a long time. Worst case is that you will have to cut the handle off and replace both the stem and the handle. That can be a little more costly. Hope this helps.
Posted on Mar 21, 2009
  • 297 Answers
SOURCE: Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
Posted on Jul 24, 2009
SOURCE: Problem taking the top cover off the Rohl R77V3SPN one handle faucet
With a small flat blade screwdriver, carefully remove the red and white plastic button on the front of the faucet. Turn off the water supply. Then, raise the handle like you're turning on the water and move the handle slowly left and right until you can see an Allen screw through the hole where the button was. With the correct size Allen driver, remove the screw and the handle will come off the faucet.
Posted on Aug 29, 2009
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
My Delta faucet leaks and they don't sell washers for it. Single handle model.
Everything wears out with time. Try going straight to the manufacturer.
May 18, 2013 | Delta Plumbing
Leaking faucet
Remove the handles. See if the chrome slip nuts holding the stems in are corroded. If they are, the cartridges may not be fully seated or the o -rings that seal around the cartridges may need to be replaced. If either of these is the case you can tell for sure by turning the stems to the on position with the handles removed and looking for water seeping around the cartridge. If none of the above is the cause then check to see if the aerator (screen on the spout) is loose or corroded sending a light spray back towards the faucet body that looks like a leak. If this is the case remove and clean the aerator, then reinstall it making sure not to cross thread it. If none of the above, replace the faucet. Be sure to call Delta first before replacing because they have a lifetime warranty and you just might get your faucet for free!
Apr 05, 2013 | Delta Faucet Delta 2530-24 Innovations...
Moen 2 handle bathroom faucet is leaking out of base of the left handle
There is a plastic retainer not with two tabs used for removal. You will need a removal tool to get this retainer off. Any plumbing supply that carries Moen should have this tool.
After removing the retainer nut, the cartridge pulls right out. Good luck!
May 23, 2017 | Moen Kingsley Two Handle Bathroom Sink...
How do yor remove a shower control to fix leaking water does not turn off complete I took out screws but can,t seem to pull off the handle
handle has a plastic lid that pops/pries off and has a screw under it. Make sure to turn off the water supply to the bathroom or house before you pull out the cartridge.
Sep 27, 2010 | Delta & Single Handle Shower Faucet
I have 5 of these faucets in my home that was built only 2 years ago. All of these faucets leak from the spout. I have replaced cartridges and they still leak.
Did you replace the seats and springs under the cartridges, Delta part number RP4993. These are the more important parts to replace when your Delta faucet is dripping from the spout.
Sep 03, 2010 | Delta Faucet 2578LHP/H277 Leland 4''...
How do I replace a single handle Delta mixer??
You would have to open up your drywall, cut and re-solder a new single handle faucet. An easier approach could be to shutting off your water supply, draining the lines in your bathroom from someplace below, and then trying to fix the bad soldered joint if you know how to do so.
I hope this helped.
May 25, 2010 | Delta & Single Handle Shower Faucet
Water leaks from the shower head. I have a delta
You may want to replace the ball or cartridge whichever the case may be. Also be sure to use Genuine Delta parts as they will hold up much better than the aftermarket parts. I hope this helps.
Oct 28, 2009 | Delta T13420 Chrome Classic Single Handle...
Slow leak old delta
The brass cap unscrews and yes there are replacements. You can find them at any home improvement store.
Sep 14, 2009 | Delta & Single Handle Shower Faucet
Mar 13, 2009 | Plumbing
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
