Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
Network not Joining the Domain using Windows XP
I have two Computers,one a client & the the other a server, But the Client Running on Windows XP does not seem to be able to detect the Win2003 Server Domain. What Can I do to Solve this
  • 3 more comments
  • o_kattambo Jan 21, 2009
    Via the Local Area Network
  • bburley May 11, 2010
    XP Home or XP Pro?
    XP Home cannot connect to a domain without a patch.
  • Ed Deguzman
    Ed Deguzman May 11, 2010
    Sound like you tried to set it up, so how did you set up the client and the server (what IP protocol, static or dhcp, ethernet configuration, etc, etc) ?
  • Kirk May 11, 2010
    have you made sure that the domain they both belong to is the same and have you set the correct protocal in the adapter settings
  • Ed Deguzman
    How are you connecting to the server ?
  • 3 Answers
Man why dont you just reformat your server and make it Windows Xd and solve your problem.
Posted on Sep 03, 2009
What are all the basic knowledge one should have before starting to work in Microsoft Dynamics AX?
For Dynamics AX certification, I recommend system administrators who are preparing to deploy Microsoft Dynamics AX to be familiar with general industry practices related to reliability, scalability, availability, performance optimization, security, and monitoring of the network infrastructure and applications. The basic components of Microsoft Dynamics AX include Application Object Server (AOS), database server, model store, and Microsoft Dynamics AX client. To work efficiently with these Microsoft Dynamics AX components, you must understand the following Microsoft technologies:
· The Windows Server operating system - used to deploy the Microsoft Dynamics AX server components.
· The Windows client operating system - used to deploy the Microsoft Dynamics AX Windows client.
· The Microsoft .NET Framework.
· Windows Server Terminal Services.
· Advanced network management in an environment that uses Active Directory Domain Services.
NetCom Learning can help you gain expertise in working over the base components and in this environment professionally and you can gain complete understanding of the entire AX toolset and data management process for the effective functioning and administration of diverse domains, including finance, manufacturing, human resource management, customer relationship management, supply chain management, and logistics.
Feb 13, 2018 | Microsoft Computers & Internet
Tip
Server 2003 & client configuration
<p><span>Some days before I have done a job on Windows Server 2003 Enterprise edition & Client XP. It is departmental food court. In the office room of the restaurant have a system which will be Server system and main domain. There was another 8 system in every department of food <span> </span>with printer for billing.I</SPAN><br> <p><span>Windows Server 2003 includes a mission critical Windows Server operating system, such as security, reliability, availability, and scalability.</SPAN><br> <p><span>You have to install DNS server for DC without DNS the client computers wouldn't know which one is DC.You can host DNS on a different server than DC.</SPAN><br> <p><span>Before Starting the DC installation process you need to make sure the <span> </SPAN>following points</SPAN><br> <p><span> </SPAN><br> <p><span>1)You have installed Basic windows server 2003 installation</SPAN><br> <p><span>2)Make sure you have assigned a static ip address to your server</SPAN><br> <p><span><span> </SPAN>Now start DC and DNS Setup process</SPAN><span></SPAN><br> <a><span> </SPAN></A> <span><span>Domain Controller</SPAN></SPAN><span></SPAN> <span>Active Directory is a huge topic in itself. While DCPROMO is easy to run, planning of both the physical and the logical structure is the key to a trouble free active directory. </SPAN> <p><span>Domain controllers do not have to be your most powerful machines, however they must be reliable and always available to answer logon requests. </SPAN><br> <a><span>DNS (Domain Name System)</SPAN></A><span><span> </SPAN></SPAN><span>Role</SPAN> <p><span>Once DNS is setup, it runs itself thanks to the new dynamic component hence DDNS. TCP/IP knowledge plus understanding of how DNS works is essential when troubleshooting connectivity problems.</SPAN><br> <p><span>DNS enables client machines to resolve servers IP addresses. Once the client finds the server, Active Directory uses LDAP to locate services like Kerberos, Global Catalog that clients request.</SPAN><br> <a><span>Print Server Role</SPAN></A><span></SPAN> <p><span>In my experience there is a contrast between the software settings which are easy to configure and the hardware which constantly need for attention e.g. paper jam, 'out of toner'. Check list for print server:</SPAN><br> <p><span></SPAN> <br> <p><span>Printer Priority</SPAN><br> <p><span>Network Printers</SPAN><br> <p><span></SPAN><br> <p><b><span>Client Configuration :- </SPAN></B><span>After</SPAN><span><span> Installation of Windows Xp give the IP Add on TCP/IP of IPV4.If you want to manually configure DNS server addresses, click</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Use the following DNS server addresses</SPAN></b><span><b><span>,</SPAN></B></SPAN><span><span> and then type the preferred DNS server and alternate DNS server IP addresses in the</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Preferred DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>and</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Alternate DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>boxes. After all job try to ping each other. I'm trying this and it also pinging. Files and data also can be shared through it.</SPAN></SPAN>
on Feb 15, 2011 | Computers & Internet
How to use network inventory ? what is it requirment ?
Installed Windows server 2000/2003/2008 on server PC
Set IP address as 192.168.0.1
     Subnet address : 255.255.255.0
     Gateway :  Blank (only if you use router)
      Primary DNS  : 192.168.0.1
      Secondary DNS : Blank
Set up the server as Domain Controller plus DNS server.Here is the link on how to
1) http://www.visualwin.com/AD-Controller/
2)http://www.ssw.com.au/SSW/Standards/DeveloperInstallationNetworkSetup/Windows2003_01DomainControllerSetup-InstallingActiveDirectoryandDNS.doc
Client setting
Set IP address as 192.168.0.2
Here is the link on how to join the domain
1) http://www.petri.co.il/joining_a_domain_in_windows_xp_pro.htm
2) http://www.windowsnetworking.com/articles_tutorials/wxpjoind.html
Client Operating system must be windows xp pro,2000 professional,Vista ultimate etc
Dec 24, 2009 | HP Pavilion DV5234US Notebook Laptop
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
So you verified ICMP traffic isn't blocked and it appears the servers allow the netBios traffic to pass.
On the client machine, check to make sure the windows print and file sharing is installed and the machine isn't blocking netBios traffic.
Make sure TCP ports 137,139, and 445 are open on the xp machine and any devices in between.
It's acting like the TCP data is being blocked by the client machine.
HTH,
-Aaron
Sep 28, 2009 | Microsoft Windows XP Professional
This is an excerpt from a MS Technet page for error 53:
Resolutions: 1) if it is domain environment, check your WINS; 2) if it is peer-to-peer workgroup, enable NetBIOS over TCP/IP; 3) make sure the machine is running; 4) make sure file and Printer Share enabled on remote computer; 5) make sure client for ms networks is enabled on local computer; 6) make sure you type the correct name. 7) Make sure no firewall running or any security setting.
Pay close attention to #s 4 and 5 - I suspect XP pro might not be open enough.
Sep 28, 2009 | D-Link NetDefend DFL-700 Firewall
Slow login problem on domain
It could be the clients dont have sufficient hard ware specs ..... or there is a script that is running for the log in that could cause the delay...?? there could be the two ways to handle it... so you need to trouble shoot where the problem lies first then dig in deeper... :0
Jul 29, 2008 | Microsoft Windows Server Standard 2003 for...
Difference between DNS and WINS
WINS is Windows Internet Naming Service, a system that determines the IP address associated with a particular network computer. This is called name resolution. WINS supports network client and server computers running Windowsand can provide name resolution for other computers with specialarrangements. Determining the IP address for a computer is a complexprocess when DHCPservers assign IP addresses dynamically. For example, it is possiblefor DHCP to assign a different IP address to a client each time themachine logs on to the network.
__________________________________________________
DNS, a.k.a Domain Name System is a database system thattranslates a computer's fully qualified domain name into anIP address.Networked computers use IP addresses to locate and connect to eachother, but IP addresses can be difficult for people to remember. Forexample, on the web, it's much easier to remember the domain namewww.amazon.com than it is to remember its correspondingIP address (207.171.166.48). DNS allows you to connect to anothernetworked computer or remote service by using its user-friendly domainname rather than its numerical IP address. Conversely, Reverse DNS(rDNS) translates an IP address into a domain name.
Jul 20, 2008 | Microsoft Windows Server Standard 2003 for...
Title
hi,
the difference between workgroup and the domain is
workgroup is a peer to peer network, no centralised administration and security is less.
domain is a client/ server network, administration will be done by domain and is more secure.
ramana
sys admin
Jul 02, 2008 | Microsoft Windows Server Standard 2003 for...
Ristricted logging onto server when server is off
Hi
Thanks for the background info, this makes it easier for me to see what you need.
You need to disable your guest account if you havnt already done so.
The user is logging on with a cached version of the logon information, this is useful for when the server goes down but not in your case as you need to prevent this.
Another worrying aspect is that you allow all your users to log on using the same password. Very bad from a security aspect anyhow. It is better to change at least every 30 days. If they moan they will get used to it soon enough.
Go into group policy again and computer configuration>windows settings>security settings>local policies>security options and look for interactive logon:number of previous logons to cache - set this to 0. If the domain controller is not available and the logon info is not cached they cannot logon to domain.
Group policy can be overruled at the client end if they have admin priviledges so you may have to set this on the client pc also. But you need to test to see if it is required there. I have not used that particular policy but it should be ok just on the server. Your users dont have admin rights do they? Anyway good luck. You can set this by applying it to an OU or domain wide but if you want to target just this one pc then maybe if you put it in its own ou and apply it just there.
You need to create new policies rather than modifying the domain one and keep each policy for specific purposes so that applying them to ou's is easier, ie internet options policy, firewall policy, working hours policy etc.
Regards
Julie
Mar 26, 2008 | Computers & Internet
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
303 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
