Question about HP Compaq Presario V2000 Notebook
Not going on.
When switch on, processor fan runs and stops after one second. all the indicators are going on but system couldn't.
the whole thing happen when i watching a dvd movie on my note book the RAM blocked. the desktop showd a strucking lines and i forcely off the system by manually switch off
  • 104 Answers
Change the ram
Posted on Aug 01, 2009
Fan noise...nothing else
Try re seating the processor. The socket 775 pins are notorious for needing to be correctly seated. This applies to the socket 771 as well.
Jun 27, 2013 | Dell Precision Workstation 670 PC Desktop
I have a Compaq Presario S4000V that is giving me repeating long beeps when I turn it on. The beep may go 10 or 20 seconds and then pause for about 5 seconds and then do the same thing again.
Hello
Usually this kind of beep code is an indication of a cpu or processor heat problem.
Make sure the processor fan is running by opening up the case and looking at it.
Also try claening out the inside of the pc,you can use a can of compressed air and a vacum cleaner for this.If the processor fan is not working get a new one,it should always be on when the pc is on.
Mar 10, 2011 | HP Compaq Presario S4000V (P8655P#ABA) PC...
HP stops giving input to mnitor, have to reboot whole system.
that is problem of processor when processor is overheated it do so there is a white heat sink compound between processor and heatsink detach heat sink and apply new heat sink compound on the processor and look properly that heatsink is firmly fixed to processor or not .it may problem of fan if fan is rotating with low frequency then also it happens replace new fan the frequency of fan can be seen in setup
Apr 03, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Why does my PC fan run continuesly?
Usually, there are two fans on a desktop PC. Some computer have three.
One cools down the power supply and it may be quite noisy after a while because the dust in the fan. The second one is to cool down the processor and usually it doesn't stops, it only changes its speed according the heat.
If there is a third one, it will stop when the temperature is cool enough for the system.
Only on notebooks the processor fan stops completely after a while to save some energy.
Sep 30, 2009 | HP Compaq Presario Media Center SR1750NX...
The small fan does not want to run, it runs for a few seconds and stops, my computer keeps rebooting
when the fan stops 2 things are happening 1 the bios sences no rpm speed from the fan or the processor heats up to quickly and the safety in the bios will shut it down. try moving the fan connector to the case fan connector then go into the bios and change the fan settings. this is only a temp fix the fan stopping tells me that the onboard cpu fan regulator is going out and this is a precurser to more problems to the board going out. also just to be certin check the power supply 4 years ago i came across this in a gateway it was weird.
Jun 29, 2009 | Iwill KK400 Motherboard
Remove heat sink,make cpu body.
IF I UNDERSTAND WHAT YOU ARE TRYING TO SAY I BELIEVE I UNDERSTAND MOST ENOUGH TO SAY YOU HAVE VERY SERIOUS PROBLEM AND NEED TO STOP EVERYTHING RIGHT NOW UNTIL YOU FIX CPU!! YOU HAVE SERIOUS OVERHEATING PROBLEM AND ARE PROBABLY CLOSE TO KILLING YOUR WHOLE SYSTEM!! A PENTIUM 4,3GHZ PROCESSOR PUTS OUT A LOT OF HEAT AND THAT IS WHY THE HEAT SINK MELTED, BUT YOU CAN'T RUN WITHOUT REPLACING IT WITH SOMETHING ELSE BETTER THAN WHAT YOU HAD THAT DIDN'T WORK! THIS IS WHY THE WHOLE SYSTEM IS SHUTTING DOWN. IT IS SAYING, IT IS WAY TO HOT TO RUN AND WE ARE GOING TO SHUT DOWN BEFORE WE BURN UP!!! YOU MUST GET MORE COOLING INTO YOUR CASE AND ONTO THAT PENTIUM PROCESSOR AND GET MORE HEAT OUT OF THE CASE. YOU MAY NEED TO ADD ADDITIONAL FANS OR VENTS, BUT YOU HAVE TO REPAIR THE DAMAGE BEFORE YOU RUN THIS MACHINE OR YOU WILL FRY IT!! THE MOTHERBOARD CAN'T TAKE THE HEAT EITHER! REPLACE THE HEATSINK WITH AN ALUMINUM ONE, NOT THAT PLASTIC ONE FROM DELL, AND MOUNT A FAN ON TOP IF NEED BE. YOU HAVE TO THINK COOOOL!!! YOU HAVE THE POWER, BUT IT ISN'T GOING TO DO YOU ANY GOOD IF IT GOES UP IN SMOKE! I'VE BUILT TO MANY MACHINES TO SEE ONE FRY FOR OVERHEATING. YOU SHOULD HAVE AT LEAST FOUR FANS IN THAT CASE, NO COUNTING THE ONE ONE THE VIDEO CARD OR THE ONE IN THE POWER SUPPLY.
DO IT RIGHT AND SHE WILL LOVE YOU FOR IT AND PURR LIKE A KITTEN! NEED HELP-REPLY TO: ARCLIGHT1217
Nov 08, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
My Processor is switched off after switch on the machine
The CPU cooler may be stopped up-- not working. That causes the processor to shut down se-f-protecting against excess heat. Check the cooling fan first.
Feb 17, 2008 | Intel Pentium 4, 3.06 GHz Pentium 4...
Clock will run down to 1 second of the minute and microwave will stop
The surge probably didn't cause this. This common error indicates a problem in the convection damper circuit. It may be a defective damper switch, damper motor, or a jammed damper door. I have attached a drawing of a typical damper system. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Sep 21, 2007 | Dacor PCOR30 Convection/Microwave Oven
HP Compaq Presario V2000 Notebook Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
