Question about Microsoft Visual Basic 6.0 for PC
In vb to create help file in vb
    President:
  • 392 Answers
I suggest you this URL:
http://www.codeproject.com/
you will get your answers there, simply by a search, this website is the source of .NET programming.
Enjoy it!
Posted on Feb 02, 2009
How we can create module in the project
it depends on how you define "module". Defining VB .NET modules is simply done by writing:
Module YourModuleName
' TODO : Add your code
End Module
Is that what you meant? There is also a template available in the new file dialog under the VB category. Calgary Website Design Firm Agua Web
Jan 25, 2014 | Microsoft Visual Basic Professional...
My vb proj.works in my pc bu not in the org. for it has been made
You should use Package & Deployment wizard (its there in visual studio 6 only under menu)
Create a package, include all dependencies, include database file (i guess you are using msaccess)
Once the package is created, go to Deployment wizard, to include the package created, you'll then get one Setup (as usually softwares are packaged)
If you go like this, you dont have to worry about the dependencies in your project or any runtime lib that might required.
It will work anywhere where you install your software like u usually install others.
Hope this helps.
Thanks.
Mar 18, 2009 | Microsoft Visual Basic 6.0 for PC
Delete blank rows in excel using visual basic
have you tried to read in one file and write back in excel format only the non-blank rows?
Mar 11, 2009 | Sony Playstation 3 (PS3) Console
Create an excel file using VB6.0
Use PDF-in-a-box. Create your file in excell, embedd their given applet code in VB and it will automatically be importedas a PDF file using your excel template.....sodeep
Mar 04, 2009 | HP Pavilion dv6000z Notebook
Time ocx
try this
http://www.snapfiles.com/help/missingfiles.html
or try this also
http://www.visual-basic.com.ar/vb-ocx-files.htm
http://www.bigresource.com/VB-Created-activex-ocx-but-browser-wont-load-DEl2srDlaG.html
it might help u good luck
Jan 27, 2009 | Microsoft Visual Basic 6.0 for PC
How to integrate LS2208 handheld scanner in vb.net
you have to change it to IBM handheld mode and install opos drivers from symbol. then use pos.net to connect to them.
Some computers requires to create some config files to connect through hardware address. It took me like 6 month to figure out but now it works
Nov 06, 2008 | Symbol LS2208 Handheld
VB setup/packaging
I would suggest the visual studio installer. It is great for Visual Basic installs and it will package all the components your app uses automatically by scanning the project for dependencies. Highly recommended.
Aug 02, 2008 | Computers & Internet
Stand alone vb programme
yaa you can use the Setup Wizard from your VB for your project. It will make a setup for your project and will put all the runtime required files in a same folder, with your project executable with a setup.exe file. Copy all these files in any device like CD,DVD, Flash memo etc, in a same folder. And run this setup on any computer to which you want to install it.
Then your project will run on that computer.
Thanks
Iqbal
Mar 31, 2008 | Computers & Internet
Pls hepl me wit Excel VB integration
you can use a OLE object that is available in VB as standard object. Drag the tools to your form that your creating and it will ask for create or link existing object. so now browse to the excel sheet and embed it into the VB form or use run time for manuplating the cells and other info in excel.
Mar 25, 2008 | Computers & Internet
Visual Basic 6.0
1. IDE is Integrated Development Environment
2.With VB 6, one can develop applications with feature rich GUIs (Graphical User Interface). Many varieties of general purpose software can be created with little effort, including, but not limited to, image editing software, text editor and database applications.
3.Windows Application Template
Used to create Windows-based applications that run locally on users' machines. You can build anything from a simple single-window tool like Windows Calculator to a complete application with multiple windows and advanced capabilities.
Class Library Template
Used to create reusable classes or components that can be shared with other projects.
Console Application Template
Used to create command-line applications, programs that run from a Windows command prompt and have no visual interface.
My Movie Collection Starter Kit Template
Used to create the pre-built My Movie Collection sample application, which you can customize to meet your own needs. For more information, see Starter Kits: Getting Up and Running Quickly.
Screen Saver Starter Kit Template
Used to create the pre-built Screen Saver sample application, which you can customize to meet your own needs. For more information, see Starter Kits: Getting Up and Running Quickly.
4.FormShaper lets you change the shape that windows draws your forms. You can have rectangles, rounded rectangles, ellipses, polygons and any combination of the above! Even save the shapes to a file for use in other projects! See readme.txt in the zip file for more details
5.Description
Used at script level to force explicit declaration of all variables in that script.
Syntax
Option Explicit
Remarks
If used, the Option Explicit statement must appear in a script before any procedures.
When you use the Option Explicit statement, you must explicitly declare all variables using the Dim, Private, Public, or ReDim statements. If you attempt to use an undeclared variable name, an error occurs.
Use Option Explicit to avoid incorrectly typing the name of an existing variable or to avoid confusion in code where the scope of the variable is not clear.
Feb 20, 2008 | Computers & Internet
Microsoft Visual Basic 6.0 for PC Logo
98 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
