Question about Refrigerators
My fridge freezer is making a vibrating noise
    Genius:
  • Refrigerators Master
  • 1,669 Answers
Try touching the vents that are in the freezer to see if that is the cause. Also check any metal ice cube trays to see if they are touching.
Posted on Jan 10, 2013
  • 1314 Answers
SOURCE: vibrating noise from freezer/fridge?
take the cover off the fan in the freezer section and see if the fan blade is loose or hitting ice the blade just pushes on make sure the mountings are tight its probably the blade but you might need to replace the motor if i reamber correctly on the cover there is a screw at the bottom you remove then slide the cover up and its on hooks plastic hooks built on the cover ok
Posted on Mar 28, 2008
ngfam1
  • 639 Answers
SOURCE: Samsung frost free fridge freezer - RL39WBSW
Dear friend,
ngfam at you service! happy to assist!
Sounds like two separate problems!!!
Do not delay!
Call service before you have bigger problems and a bigger expense!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
philbran
  • 242 Answers
SOURCE: panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Posted on Dec 30, 2008
jmgldsmth
  • 1889 Answers
the evaporator fan has become off balance and is vibrating
most likely the fan motor bearings have failed
Posted on May 02, 2009
  • 103 Answers
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
Posted on May 31, 2009
Why does my engel MT45F-U1 fridge and freezer vibrate and make so much noise?
have u checked the groumets on the compressor? more than like are bad
Apr 20, 2015 | Engel Refrigerators
Our Samsung fridge srs757dw is making weird noises(it hums loudly). When the Freezer door is open it stops but as soon as it closes the noise begins again. What do you think is the problem?
Sometimes this can be due to vibrations within the duct , possible that the ventillating fan is frosted and so makes the noise with the door closed. So shut down fridge for few hours to defrost and check.Also make sure there are no loose screws or clips on the back panel and the evporator section that can cause vibration.
Aug 30, 2011 | Samsung Televison & Video
Massive noise on my samsung fridge freezer
samsung fridge freezer problems
check this guy out on youtube
Dec 29, 2010 | Freezers
Westinghouse virtuoso fridge is noisy after leaving the freezer door open several hours
First analyze from where you are getting the sound.
1)Check the fan at the back side of the freezer.Is it making noise.Remove it and put some oil so it will rotate without sound.Check for the bending and straighten it and see it
doesn't hit on body.
2)compressor motor may vibrating a lot making noise to the condenser coils.It makes the full fridge to vibrate and makes noise.Adhesive stickers will soften them.If still problem persist coil could be damaged.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 06, 2010 | Refrigerators
My fridge has become very noisy? Could you advise?
The fault can be the vibration of the compressor motor radiating the noise to the condenser coils. So it may be hitting against the walls of the fridge and you are getting this noise. Also tthe compressor makes tteh vibration that transmits to plastics, trays at the bottom of fridge and the rear mounting. Use good adhesive stickers to soften them.
Aug 30, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
GE top freezer refrigerator: motor has become very loud and refrigerator vibrates. However, when I move the cold control to a lower number, it gets slightly quieter and vibrates slightly less.
Please make sure it is level, the compressor is designed to run on level ground. Also check the fans. if the fan is bad or the bearings are shot, it'll vibrate and make a loud humming noise.
Find out where the noise is loudest. if it's under the fridge, it's the compressor.You have to check the coil for the compressor and if it's inside the freezer, it's the fan bearing.
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Oct 20, 2009 | Refrigerators
Freezer LFFH21F7HW upright is making to much noise when it runs. Is this an ongoing problem?
Hi, What kind of noise is it making?
Also have you tried moving the fridge slightly incase its up against a unit or sitting uneven as this can cause a noise if after this you still have the noise their isnt much you can do about it as its not worth replacing parts that are working fine.
I would move the fridge slightly or adjust the legs so its sitting even as this can cause a vibrating noise.
Let me know how you get on or if you need further assistance ok
Aug 11, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer Noise. Water leaking in Fridge.
you need a repair man.you have a defrost problem and your drain is clogged.
Mar 09, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
