Question about Maytag Performance MHWE500V Front Load Washer / Dryer
Maytag front load washer error f35 and f21
Had 'sud' error f35 error, changed the water level pressure sensor. Now, the error code changed to f21
4 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: What causes the SUDS error code What sensor is
Hi Ron,
I found most of this on another site, and am including it here for your enjoyment. The problems are listed sort of in progression; try step 1 before 2, etc. It sounds like the tech gave you the most common cause and solution, but it sounds like two cycles may be necessary to rule out the detergent solution.....it usually is though. But WAIT! There's MORE!
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If “Sud” is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Replace failed component.
I hope you found this to be of help, and at least mildly entertaining!
Best regards, --W/D-- please feel free to rate his solution!
Posted on Jul 30, 2009
  • 8 Answers
SOURCE: error code
Press Chime and Extra rinse keys for three seconds or until the control beeps. You are now in service mode and your machine should say a new error code. Depending on what that code is, you might be able to reset your machine by unplugging it, and replugging it in. if your codes are now clear, try running machine on spin only or rinse cycle. DO NOT add more soap!!! If this corrects your problem, try running a load with out soap. You may have a lot of extra soap in your machine.
Posted on Mar 28, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a Maytag front load Washer Model
Hi
There is only one Analog Pressure Sensor Switch Part no. W10156252, another one that it has is the water level switch (part no W10415587). I believe you are talking about the first one as that is what error code F35 means (ANALOG PRESSURE SENSOR FAILURE). Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 17, 2011
I have a Whirlpool Duet Washer, washer starts and then stops code F35
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Nov 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam WFW9600TW00 code F35
Kevin
Oct 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Maytag front load Washer Model MHWE500VW10 (5000 Series) . The dreaded F35 / SUD error code keeps coming up. I have checked the tubing and electrical connections to the Water Level Pressure...
Hi
Daniel
Sep 17, 2011 | Maytag MAH21PDD Commercial Front-Load...
Washer displays F35
F35 indicates a water level pressure sensor failure. The SUD is normally displayed when there is excessive detergent suds in the tub. Make sure you are only using the recommended amount of HE detergent. Then run the washer without clothes on a drain and spin cycle. If the tub is empty and you do not see any suds please continue with the following trouble shooting tips. A loose wire harness connection could be causing this problem if there is no water or suds in the tub.
I recommend unplugging the washer and removing the top panel. Screws at the very back of the top panel secure it to the washer frame. Remove the screws and then pull the top panel slightly back and then up and off of the washer. The analog water level pressure sensor is shown in the first image below. The second image shows a clear picture of this component. Check the wire harness connection on this sensor. If you find a loose connection, secure the wire harness properly on the component then reassemble and test the washer. If you continue to get the F35 code, then the pressure switch will need to be replaced.
You can order a new analog water level pressure sensor from the Sears PartsDirect website.
Hope this helps.
Jul 31, 2011 | Maytag EPIC MFW9700S Front Load Washer
I am getting a Sud code and then an F35 error on my Maytag frontload washing machine. I have unplugged it...to reset and sometimes it works. Other times it doesn't. How can I fix it?
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor. This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem.
Jul 31, 2011 | Maytag Washing Machines
My whirlpool duet washing machine displays code F35 and won't complete the washing cycle.
Kevin
Apr 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code f35 and sud on washer machine/whirlpool duet front loader
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
May 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Model: wfw9500tw01 f35 error
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 and suds it turns off after 5 mins and whenever I put it on rince only it still cuts off.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
May 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 code
Dec 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Performance MHWE500V Front Load Washer / Dryer Logo
57 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
