Question about Teac Audio Players & Recorders
HDB850 DIGITAL RECEIVER. I get unwanted subtitles when I record a program??
On my TV I don't have subtitles yet when I record a program I end up with subtitles - which I don't want. How can I prevent tnis??
  • 5 Answers
SOURCE: I cannot turn the subtitles off on recorded programs
Try Turning Subtitle Option Off Before Recoding.
Posted on Apr 07, 2009
SOURCE: We have a RH397D digital
Easy Menu
Setup
A – DTV Closed Caption - OFF (Make sure it is turned off) I am not sure what activates this to ENGLISH but it can be switched off.
Posted on Jul 22, 2009
  • 8457 Answers
SOURCE: subtitles do not appear
Want subtitles must pick at the movie menu.
Posted on Jan 23, 2010
Testimonial: "It worked. Thank you!"
  • 909 Answers
SOURCE: how do i delete unwanted tv channels
I am not sure what features are on this model, but you may have a favotites setting to mark the favourite channels and skip the rest.
Posted on Apr 08, 2010
  • 4 Answers
SOURCE: my receiver wont stop recording
My name is Anthony Thomas with DISH Network Customer Service. This issue is usually due to a faulty program guide with "No Information Available" or incorrect information as to when the programming ends. This can be caused by a faulty Electronic Program Guide (EPG) download, a faulty box, or by signal loss. By pressing the guide button to bring up the guide, and then pressing the numbers 999 and then browse (the right arrow by select) it should give a message that says "The guide information is outdated, download from satellite now?" or something similar. Try it and see if that helps.
If not, that means there is likely a signal issue or an issue with the DVR. To check signal, Press Menu (top left corner of remote under SAT, has three horizontal lines on it), and then press 6-1-1 like you are changing the channels. That should get you to Point Dish. Check Switch will be an option on the right side. Select it and then select TEST at the bottom of the Install Summary screen that will show up. Select YES if there is a warning about TV2, otherwise it will bring up a 058 message saying to wait while test is done. The message 058 will disappear by itself. If a warning 836 message appears, your issue may require a technician due to signal loss. If not, select done to exit Install Summary, Done again to exit Point Dish, and then press the 0 button three times to select the cancel option. This should put you to an "Acquiring Satellite" Message(Attention 015/535 message) and then download the guide (Attention 330). Check it then. If it still doesn't work, the box may need replacing. If it works, you are all done! Hope this helps!
Posted on Dec 27, 2010
Subtitles not working on humax recorder
Try switching subtitles Off, then On again. Otherwise a factory reset will normally restore the function. Note that a factory reset will not delete recordings, but you will need to retune and re-program timers
Apr 08, 2014 | Humax Televison & Video
How do i record tv programs on digital stations. Only option is analogue.
On the EPG (of the DMRs channels) press OK on the remote at the program you want to record. After that you can choose HDD or DVD-RAM and the quality Ep-Xp and possible subtitles (STTL). Press OK and the recording settings are saved. Note that to record 16:9 or 4:3 aspect ratio, you have to have that setting made from setup.
Nov 09, 2013 | Televison & Video
How do I turn on the closed captioning on my Toshiba SD 5000 DVD player
What happens when you press the "Subtitle" button on the DVD remote control several times after you insert a subtitle-enabled DVD?
If you don't have the manual handy for your DVD player, I've added a link for the Toshiba SD-5000KU. The Subtitle button is described on page 13, but the description only tells how to turn subtitles on. However if the programming is typical, pressing the button repeatedly cycles through a series of language options with "Off" at the beginning or end of the list. Otherwise, it may be programmed to enter a subtitle menu that you navigate with the direction arrows (page 14).
Toshiba SD 5000KU Owner Manual
Jul 03, 2017 | Toshiba SD-5000
Where can I get an owner's manual for a RCA ATSC11 digital tuner?
On the RCA ATSC11 you can see the menu if you switch to 480i resolution and connect a video cable to the monitor output. Otherwise the menu is visible only on the digital output.
Dec 23, 2011 | RCA ATSC11 DTV Receiver
We just dvrs hooked up a few weeks ago.when I am recording somthing down and my daughter goes upstairs to watch her tv and tries to change her channel to watch somthing a message comes up on the tv that...
Hi, poog_23350, I caught your post! How a Duo DVR receiver works is that the TV you have it set to record on will not allow you to change the channel while the recording is in progress. The other TV, that isn't recording anything, can be used freely to flip through channels.
In this case, it's TV2, the one upstairs in your daughter's room, that's currently set to record on while the downstairs TV is free to use. This can be adjusted by pulling up the Main Menu with the Menu button on the remote, selecting option 8, then option 5, and changing the TV1/TV2 setting there on the Record Plus screen.
If you'd like a receiver capable of allowing channel changing while recording a program, our VIP 612 receiver is a Solo receiver that acts like a Duo. What this means is that it has one TV output and two tuners. Along with being able to change channels while a recording is in progress with this type of receiver, you can also record two programs on two different channels simultaneously.
Hope that helps!
Aug 29, 2011 | DISH Network DVR-625 DTV Receiver /...
How Can I record a TV program using my SD-V295KU. Where Can I chose the chanel number? Can You hepl me please? This is a DVD Video Player & Video Cassette Recorder.
The SD-V295KU has no tuner. You will need to connect it to a set top tuner, a cable or satellite receiver box. One of the digital-to-analog converters would work for OTA programs from a digital station. The basic ones that were available with the government coupon give SD output; this is sufficient since composite video is limited to SD.
Then connect the composite (audio and video) out from that box to the DVD/VCR composite in (the rightmost jacks). Then set the channel on the box and record content on Line 1 (Press Input Select on the DVD/VCR's remote to get to that input after you set the recording speed.)
Most TVs do not have a composite out option so the tuner in the TV can't be used to feed the program to the DVD/VCR.
I wish that I had better news for you.
Jun 04, 2011 | Televison & Video
How can i remove unwanted subtitles the movie is in english and the sub titles ate very distracting
Usually, if the subtitles are from your dvd player, you can go to the main menu, select "languages" or "setup" (depending on the dvd), and find the subtitle option. You should be able to shut them off there in the menu. If the subtitles are there because of your tv, there should be a button labeled "cc" on your remote. If you press this key a few times, it should eventually read something like "cc off" on the tv screen. I hope this helps, and good luck! Sincerely, Der Strom
May 10, 2010 | LG DR-4912 DVD Recorder
I would like to be able to record TV shows WITH subtitles/closed captions. I have a Hisense HD LCD TV with built in HD tuner. I would like to be able to record onto a DVD/VCR. I'm getting conflicting...
Hey, I have a deaf brother with this issue. What I done was route the AV output of the TV to the AV input of the recorder. Set your recorders source to AV1 (or whichever you use) and set your TV to the program you want to record, also turn subtitles on. Because you wont have your TV set to the input your DVD recorder is on, you won't be able to see the DVD recorders output, but thats fine. Just press record on the unit - you have to leave the TV on the channel it's recording. Now you should be recording TV with subtitles with no problem :D
Apr 27, 2009 | Televison & Video
47 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
