Question about Speed Queen Coin Operated Topload Washer
Washer won't start
My speed queen coin-op top load model swt910wn almost always works great but sometimes won't start after money goes in.It's about 4 years old, and has a mother board instead of a analog timer. I have checked all the obvious things, has good elec. cord, power is on, lid is closed, coin slide works smooth, extension pieces on end of slide are all aligned right and are attached to each other properly. When it malfunctions, the coin slide goes in, the quarters drop, the slide comes back out, but nothing happens. The controls don't light up, and water doesn't come on. No lights, No action, Nothing. What's the most likely cause?
  • 177 Answers
SOURCE: Draining water from inside through center.
The tub seal kit is $85 USD, You will also need a drive bell kit$23 USD, you should replace the upper bearing $?, for a complete rebuilt I would also replace the brake pads all three, and the belt, maybe the pump if it doesnt come off easily. Plus what you break taking it apart, so we are looking @ least $150.
Yes you can do it yourself, you dont need the tub wrench if you can borrow a deep socket, its the drive bell seal tool you really need.
Please let me know if you have additional questions. the serial number will tell you the age first two digits are year next two are month, starts with and R, built in Ripon WI.
Posted on Aug 22, 2008
  • 1214 Answers
SOURCE: SPEED QUEEN TOP LOAD WASHER HA4011W. Motor trips at SPIN start
I would call whoever repaired the washer back out and have them diagnose.
Posted on Jan 23, 2009
  • 12 Answers
SOURCE: At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Posted on Apr 09, 2009
mhamlin63
  • 138 Answers
SOURCE: What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
Posted on Jun 29, 2009
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
Posted on Jan 13, 2010
Washer motor overheating
Check the drum for ease of rotation, bearing noise. Make sure all support springs are good and at the same position.
Nov 27, 2013 | Speed Queen SWT921 Top Load Washer
Speed Queen Front Load Coin operated # SWFT71.. The coin changer keeps getting stuck. Any ideas on how to resolve this?? How do I remove the coin changer from inside the machine??
I have not fixed any of these front loaders for a while, but the top cover should come off (usually with a key), which will give you access to the coin mechanism and timer. There you usually need a 5/16 wrench or a flat screwdriver to remove the screw at the top of the mechanism.
Dec 04, 2012 | Speed Queen SWFT71 27" Coin Operated...
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
I have a Speed Queen top loader(older model). It let's water in but does not wash or let water out. I have checked the control pannel and motor. All seems to be ok. The reset used to work but now it does...
Make sure that the lid switch is working as it can make the program from advancing forward. So check the continuity of the switch that goes to trigger the main board.
If Ok then the program controller is not functioning, if you can try to change manually then the control board is faulty.
Jan 13, 2011 | Speed Queen AWS17NW Top Load Washer
I have an old speed Queen coin operated dryer and I would like to remove the coin function. Can this be doneMachine detail on request.
you can get it to run by installing coin plugs in the slide are assembly or leave the top lock panel open and push the spring arm before each load for personal use.
May 22, 2009 | Dryers
Lost coin op washer keys
you need a locksmith.  Because of the key design
Mar 11, 2009 | Maytag MAT12CS Top Load Washer
Jan 23, 2009 | Speed Queen AWS52NW Top Load Washer
Maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
Speed Queen Coin Operated Topload Washer Logo
35 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
