Question about Tablets & eReaders
Tablet won't charge unless wiggle cord around some, also connector wobbly
2 Suggested Answers
  • 36 Answers
SOURCE: Motion Computing LE1600 Tablet PC won't charge.
know of similar problems. either the cable and connection end you have or the receiving end in the tablet. can be diagnosed by getting replacement charging cable. if the problem goes away then its the cable if not it is probably the receiving end in the tablet
Posted on Apr 05, 2012
Why want my tablet charge Where do I return my tablet it will not charge anymore
Most common cause of this is faulty charger, the metal connector at end of wire won't connect properly to device charging port.
Test it by putting plug back in Tablet charger port and very very gently wiggle it around very slowly, see if the charging light comes on or flickers. They usually make a beeping noise when successfully charging or the screen lights up. If you get intermittent charging then it's the charger and time to get a new one. Very common, most are USB connectors or small pin types.
If it's still under warranty then send it back to the place you bought it before you try testing it.
Oct 07, 2016 | Tablets & eReaders
How do i fix a battery on a samsung tablet
The problem may be a frayed wire inside the charger cable right at the connector, or the charger jack may be worn or have a cracked solder connection. If it charges reliably with a different cable (such as a USB cable connected to the computer, it is probably the charger cable. If it has to be wiggled to get it to charge with a known good cable, then the charger jack should be replaced. This requires an expert technician; the solder connections are very small, and the circuitry requires special handling because it is easily damaged by static electricity.
Apr 28, 2016 | Samsung Galaxy Tab 2 7.0
Do I need to replace a battery or adaptor for tar us tablet that won't charge unless I move cord plug until .
if you have to "wiggle " the end of the charger where it enters the tablet then its the charging port on the tablet itself that needs re soldering or changed. check the charger by plugging it into some thing else with the same end on ( phone etc ) to make sure its not the charger end. if it works fine then you need to change the port on the table.
May 24, 2015 | Tablets & eReaders
Vizio tablet
new charger or battery or connector is bad
Apr 22, 2015 | Vizio Vtab1008 8" Led Touch Screen Tablet,...
I have a filla tablet and it will not com on help please
I suppose this is some cheap android tablet. If the power button does not turn the tablet on, try plugging in different chargers and cables. Perhaps the battery is not charged. If the tablet has been dead for awhile it might take awhile to charge the device up enough to turn the screen on. So, try cleaning the charge connector with some alcohol and check it for damage and allow port to dry before plugging in any power. Just experiment by moving the power cord around and perhaps the connector is loose pr something. I suggest leaving the cord plugged in even for days or hours because it can take different devices a long time to charge if they are flat.
Aug 20, 2014 | Tablets & eReaders
My acer charger got wet, I thought I dryed it off good. I plugged up my tablet and heard a click now it won't charg up( my tab)
You could go to the place you bought it or another tech store and see if they have another tablet like yours lying around so you could test out and see if it is just your power cord that needs to be replaced. Because most likely it's time to buy a new power cord. Hopefully you didn't fry the tablet's motherboard also that's why you should test out the power cord first.
May 28, 2012 | Acer Tablets & eReaders
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
Apr 05, 2012 | Motion Computing LE1600 Tablet PC
Tablets & eReaders Logo
21 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
