Question about Bosch 2400ES LP AquaStar 6.4 GPM Indoor Tankless Liquid Propane Water Heate
Rinnai r70e warm not hot
Worked perfect for a year and half. After some cold weather it will only get warm now, faucet on full hot is barely warm enough for a shower maybe 80- 90 deg. could something have frozen that is replaceable. I did lose power for about 10 hours. Please help i want my hot water back
  • 350 Answers
This's been a cold year!
Is this an instantaneous water heater?
If it's outside or on an un-insulated wall in an unheated area this could very well be all that's wrong with it!
Is your heater well insulated?
Are your pipes well insulated?
Is it in a heated area?
If not I would insulated it real good and try moving it to an area that's heated!
Has this been helpful?
Posted on Jan 21, 2009
Rennai
TAKE OUT THE ELECTRODES AND EMERY CLOTH THEM TO A SHINE. THEY GET A BUILD UP ON THEM NOT LETTING THE BURNERS RUN AT THEIR FULL CAPACIATY.
Sep 09, 2014 | Water Heaters
No hot water from kitchen tap
The hot side of the faucet is most likely plugged with something that came up thru the water system. The average thankless waterheater requires at least 1/2 to 3/4 gpm flow rate for the unit to sense flow and turn on. If there is not enough flow it will not fire and heat the water. Not sure about this particular unit but a few require at least one full gallon per minute flow. So chances are that if you fix the faucet, you fix the hot water issue at the same time
Jan 09, 2014 | Rinnai Water Heaters
I have a Rinnai Continuum Model 2532 natural gas tankless water heater in my home. It takes about 45 - 60 seconds for the water to get hot at the faucet which is closes to the heater. This thing is...
clean filter on the cold side coming in and clean or replace the aerator at the sink, rinnai works on water flow, common problem if your water hardness to high or if you have iron in your water
Oct 04, 2010 | Rinnai Webstone The isolator EXP tankless...
Want to change water faucets
Centre tap of the rinnai will turn off hot water supply only.
Easiest way is to turn off your mains water supply. This will isolate both hot and cold, no need to turn off anything else
Jul 11, 2010 | Rinnai Digital Remote Water Heater Control...
I have a problem with my Rinnai hot water heater giving me intermitant hot and cold. The water gets hot and I get in the shower. A few minutes later the hot water stops and I have to shut of the hot water...
We had the same problem - the hot water would only be hot for 3 -5 minutes and shut off, then we had to turn the water off, wait a few minutes, and do it again. VERY FRUSTRATING.
Solution: The Rinnai serviceman showed me the heat-exchanger blower/fan: It was clogged with dust and moths.
Another clue: Our Rinnai was extremely noisy when the heat came on. After the fan was cleaned and replaced, it is nearly silent.
If you are reasonably mechanically inclined:
TURN THE BREAKER / POWER OFF to the unit.
The blower-fan is located in the lower central area of the unit (at least on our unit). If you draw imaginary north-south, east-west lines through the center of the unit, the fan is in the lower-left quadrant. There is a spring clamp securing the black rubber accordian-like tube to the fan. There are two screws that secure the fan to the unit. there are two plugs that connect to the fan, as well as a third air-flow sensor that should be removed. then you can look at the fan unit, as well as the grill on the underside of the heat-exchanger that should be cleaned.
My thought was to go out and get a simple bug-screen, and place it over the air-input outlet vent going outside, but the repair guy said that although it may sound good, if that screen ever gets clogged, or reduces airflow to the Rinnai, then the unit will work harder, or even shut off, giving the same problem.
May 24, 2010 | Rinnai Webstone The isolator EXP tankless...
My Rinnai tankless water heater cycles up and down when we turn on the hot water. The water gets hot and then cold, hot and then cold. What is the problem?
You need to first make sure is the tankless who do the “up and down”! . If the problem manifest on more then one faucet then the problem is the unit. Have a thermometer (we use a infrared gun wich we train on Hot water pipe !) and see if actually the unit is the culprit.
If the problem is only on one shower It is possible also to be a “antyscalding valve” If the trigger valve on your shower is being adjusted too low then it trigger a splash of cold water now and then on regulate intervals. Try to adjust the temperature lower at the unit (say 110F ) and see if the problem change. If it does, then the problem is for sure in the faucet. If it does not change , then you have a problem with the water flow sensor . It is simply getting stuck. Bad bearing or even a piece of Teflon tape. I believe you will need a certified technician for that so no issues with your warranty will appear.
Dec 29, 2009 | Rinnai Water Heaters
No water flow from hot water tap with a rinnai tankless water hea
Its A Possibility The Left Over Water In The Hot Is Frozen. If Your Line Is Exposed Outside Somewhere It Can Easily Freeze Up. Turn On The Hot Water Everywhere In The House And If Accessible Check The Lines To See Where The Warmth Ends. You Can Leave One Off Over Night In Hopes That It Will Eventually Defrost.
Jan 16, 2009 | Rinnai Webstone The isolator EXP tankless...
Bosch 125 Tankless Water Heater - Water not hot enough
sounds like your mixing valve or tempering valve not unit.Somewhere there is a unit that prevents scalding temperatures- I expect this is your issue find and adjust this first- there are directions on it when you find it.
Nov 30, 2008 | Bosch AquaStar Indoor Natural Gas Tankless...
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Bosch 2400ES LP AquaStar 6.4 GPM Indoor Tankless Liquid Propane Water Heate Logo
232 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
