Question about Brother HL-2170W Laser Printer
Hl-2170w brother is offline - Brother HL-2170W Laser Printer
  • Anonymous Feb 09, 2009
    I was printing yesterday from my mac and my pc, both connected via a wireless router, and the router, connected wireless to the printer. I was bragging to a friend how great the printer is. Today it says it's "Offline". Great. What the hell made it go offline and why do I have to go through the hell of reinstalling the thing on Vista and Mac OSX? Based on all the posts, this looks like this happens frequently. Where is Brother's tech support when you need them, certainly not "By Your Side".
  • Anonymous Mar 30, 2009
    Zcmst - this might be good if you haven't already installed an MFC420CN printer and it's been working.  I'm using Vista on an HP Pavilion laptop and it works find for awhile, then goes Offline.  I can't seem to get it to go online again and this weekend had to uninstall and reload the drivers from scratch again to get it to work.
    Then this morning, I printed my tax forms and a process manual without a hitch.  Then when attempting to print a one page calendar, it said it was offline.  When looking at the ports, it didn't show up.  When I picked an open port, it showed up, but I can't get it to go online.
    Very frustrating.
    Marshall
I just realized what my problem was with this same situation..."Off line". Do the following:
1. Reset the printer to factory default settings: turn off, turn on holding down blue button; after all LEDs light-up release button; All LEDs with go out then flash once.
2. Hook up the printer to an open port on your wireless HUB.
3. Install Brother software (note: go to programs/brother HL-2170 and select remove software prior to reinstalling)
4. Here is the catch: MAKE sure to select the correct encryption code. I was selecting TKIP instead of AES and two things happened...1) the computer did not pick up the printer on the network scan, and 2) the printer will remain off-line.
Once i selected AES, the computer found the printer on the network and viola' no more problems.
I then added my wireless laptop: installed drivers only, the programs scanned and found the printer on the wireless network and that was it. Now both computers are wireless!
HOPE THIS HELPS!!!
Posted on Jan 25, 2009
  • 5 Answers
SOURCE: Brother HL-2170W Laser Printer is 'offline" wont turn back online
On Windows XP the solution is as follows. Do the install per directions using the network cable method. Install BRAdmin light off the setup disk. ( password=access)Then, get into Printers And Faxes via the the Start->Settings method and DELETE the printer then (you will need the IP address of the printer, it will be something like 192.168.2.3) For Windows® 2000/XP and Windows Server® 2003 8
In Printers.& FAXES
Click Add a printer to start the Add Printer Wizard.
For Windows® 2000: Double click the Add Printer icon to start the Add Printer Wizard.
c Click Next when you see the Welcome to the Add Printer Wizard screen.
d Select Local printer and deselect the Automatically detect and install my Plug and Play printer
option, then click Next.
e You must now select the correct Network printing port. Select Create a new port and select
Standard TCP/IP Port from the pull-down window, then click Next.
f The Add Standard TCP/IP Printer Port Wizard will now appear. Click Next.
g Enter the IP address, or the node name you wish to configure. The Wizard will automatically enter the
Port name information for you, then click Next.
h Windows® 2000/XP and Windows Server® 2003 will now contact the printer that you specified. If you did
not specify the correct IP address or name then an error dialog will appear.
i Click Finish to complete the Wizard.
http://www.brother-usa.com/ModelDocuments/Consumer/Network%20Users%20Manual/NUM_HL_2170W_EN_1292.PDF
Posted on Jan 21, 2009
  • 5 Answers
SOURCE: Brother HL-2170W Laser Printer is 'offline" wpm
Is this the initial install? If so do this.. I finally figured this out. Do the "cable" install. After it discovers the printer etc you will get to a screen during the driver part of the install that will ask you how to find the printer. The "recommended" list method is a deadend!  Instead, check the IP address option and input that.. You can get the IP address of the printer from the test page which should have already printed.(Its probably 192.168.2.3).  I run   XP and it solved the problem. I suspect its also the answer for Macs and Vista as well.
I have also had success by doing the "cable" install, then when its done, deleting the printer in Printers and Faxes, then doing a manual install (you still need the IP address).  I am using two computers to go to this printer and it flies. Great speed.
Posted on Jan 22, 2009
bschilz
  • 2049 Answers
SOURCE: Brother HL-4040CN successfully installed but shows offline
I assume it's turned on and connected to the router.
Sometimes with DHCP, the IP address on the printer will change. I end up going into the router table to see what IP addresses are assigned where. Invariably I'll find my network printer has changed. Find the printer and write it down.
In Windows, Go into Printers> choose the Brother and right click to check Properties. Look for Ports and change the IP address as needed. It will come back online.
Posted on Sep 17, 2009
  • 59 Answers
SOURCE: How to clean brother HL-2170W drum (DR-360)
reve the toner and drum from the machine, seperate the and put the toner aside. slide the tab back and forth about 20 times then blow in the slot. if you need to you can wipe the roller with a clean dry cloth.
Posted on Mar 26, 2010
Jimsta01
  • 405 Answers
SOURCE: Got a paper jammed in my brother hl-2170w
Open the front cover of Printer, remove the drum and toner with force and put aside. Remove the jammed paper slowly so it doesnt rip. If you cannot find the jammed paper check in the back cover and paper tray.
Posted on Apr 03, 2010
Brother HL 3075CW printer is offline and won't print
I am having the same issue. The printer works for a few days, and then the IP address for the printer changes and I cannot print anymore. Any idea as to how to solve that issue?
Oct 21, 2012 | Brother HL-2170W Laser Printer
Cannot remove toner brother hl 2170w
read page 62 of the manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002308/cv_hl2140_usaeng_usr_d.pdf
Apr 04, 2011 | Brother HL-2170W Laser Printer
My printer is offline. How can I get it back online?0 It will not print anything. Everytime I send something to the printer it goes to pending.
Click Start > Go to Control Panel > Printers and faxes or Printers > Right click on the Printer > Select "Use Printer Online"
Oct 19, 2010 | Brother HL-2170W Laser Printer
Under Win 7 i can not install the printer at all. None USB, none Ethernet.On usb reports as being LPT 1 which I don't have on my laptop.
Make sure you have the usb connected on the top slot on your brother printer, otherwise it will keep showing your printer is READY but at the same time it'll show its offline. Hope this helps.
Aug 26, 2010 | Brother HL-2170W Laser Printer
Why is HL 2170W printer saying it is offline. It is wireless and I used Netgear
Go to the computer Control Panel, select Printers, right mouse click on the printer and choose Use Printer Online. See what happens.
Mar 16, 2010 | Brother HL-2170W Laser Printer
Lost cd-rom for brother HL-2170W. I need to connect a new laptop to the printer on my wireless network and can't figure out how to do it! It's running Windows XP Pro.
Download the updated firmware, drivers and software for you printer from here (select 'ALL' as Type, and then select your OS and language, to see all downloads available in one page):
Brother HL-2170W downloads Homepage
Also download the manual and guides for your printer:
Brother HL-2170W manuals
And make sure you also look through the FAQs and Troubleshooting under 'Initial Setup' and 'Software' sections:
Bother HL-2170W FAQs & troubleshooting
Sep 02, 2009 | Brother HL-2170W Laser Printer
Printer shows offline after installing correctly
make sure that the printer is turned on.
if you have the printer settings, you can check the configurations.
but if you have windows xp installed on your system, you can check the control panel, printers and faxes, then right click on the printer, you must set it as a default printer, and uncheck the use printer offline.
Hope this will help you solve your problem .
Aug 09, 2009 | Brother HL-2170W Laser Printer
I can't print anything
Do the install with the network cable, DELETE the printer but not the contol files, do a manual install. The Brother software is screwy. Read the tech manual.
Jan 14, 2009 | Brother HL-2170W Laser Printer
My brother laser printer 2170w is saying it's offline and I have no idea how to get it back online
just right click your printer icon in printer properties.it will pop out some options.in that options it will also pop out the offline option just click that offline option it will turn in to online option.if u find it hard just uninstall the printer drivers and reinstall it again from the printer driver installation cd.it will work properly.
thanks.
Dec 15, 2008 | Brother HL-2170W Laser Printer
Brother HL-2170W Laser Printer Logo
2,387 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
