I Have Edurite advance English CD , once i had formatted my PC.After the re-installation the error code will appear ....
Please re-set the cd-key
  • Computers & ... Master
  • 5,660 Answers
Usually when the program comes up, there is an About, you can click on. This shows the product key.
You may also want to use Magic Jellybean Keyfinder, and find the product key.
Weird name I know, but it DOES work.
Have used many times.
http://www.magicaljellybean.com/keyfinder/
It is FREE.
Regards,
joecoolvette
Posted on Jan 10, 2013
SOURCE: CD rom can't read CD XP
TAKE THE CD-ROM DRIVE OUT AND REBOOT THE SYSTEM. WHEN THE SYSTEM ARRIVES AT THE GUI SCREEN, GO TO SETTINGS FROM THE START MENU, MAKE SURE THAT IT HAS BEEN REMOVED FROM THE SYSTEM DEVICE MANAGER OR AT LEASE DISABLED. REBOOT SYSTEM AGAIN. CHECK MY COMPUTER ICON TO SEE IF IT IS MISSING. IF IT IS GOOD. NEXT PHYSICALLY REINSTALL THE DEVICE AS THOUGH IT IS A NEW DEVICE. REBOOT THE SYSTEM LET THE OPERATING SYSTEM DETECT THE DEVICE AND INSTALL THE SOFTWARE FOR IT. GO BACK TO MY COMPUTER AND SEE IF IT IS BACK IN THE CONFIGURATION. IF IT IS GOOD. OPEN CD ROM DRIVE PLACE THE DISK YOU ARE TRYING TO READ AND SEE IF IT DOES. IF IT DOES GOOD IF IT DOESN'T THEN YOU CD ROM IS BAD AND YOU NEED TO REPLACE IT.
Posted on Aug 15, 2008
SOURCE: Got following error: Load Error! Press any key to reboot
This problem is indeed caused by a faulty MBR but there are solutions other than zero-filling the drive.
If you can get access to a RipLinux CD there is a little utility called Testdisk that will write a new MBR code to the first block of the drive. I just did this on a Sony PCG-K15 this morning (after cloning the drive just to be safe) that was giving the same error of "LOAD ERROR- Press any key to reboot" and it worked like a charm. The machine booted right up.
Hope this helps...
Posted on Nov 19, 2008
  • 477 Answers
SOURCE: HP compaq nx6310 pc
download the drivers here and try to install them.
Posted on Nov 26, 2008
patemi
  • 366 Answers
SOURCE: How to set up wireless router without using installation cd.
select your version here at this CISCO page.
Download setup wizard.
Posted on Jan 12, 2009
  • 51 Answers
SOURCE: how to change lenovo chinese to english vista without english cd
my dear, the user guide in any language will also have multi lingual options. and now your's is chineese. seek help of any language translator in your place. he can easily do it. or in other end,
you should be knowing the process of removing a operating system from a system . if you want genuine software you have to spend money. if not, then just get back me @ deepuunni1985@gmail.com so that i can send you the vista pack. its even available with small dealers. servicible charge or some 100 rs will be charged by them. can't you afford that??
Posted on Aug 22, 2009
In doing a system restore i managed to wipe out windows in my el1852w ..now the screen says,install windows..X Windowscould not complete the installation.to install windows on this computer restart...
As PC starts watch screen for message "to enter setup press del" or similar. (press F!, press F2, press F12).Power down the PC and then power it back up. Be ready to press the KEY to enter setup while message is on screen. If you do not see the "enter setup" try holding the delete key as machine powers up.
Then repeat while holding F1 key etc. Once you enter setup (CMOS SETUP) find the boot settings and select CD as first boot drive. Put your full install CD in the CD drive have the license code ready. Example; AB123-1RD5C-XP94D-MN47G-LRIPQ. Your key will be on the CD sleeve or license sticker on PC. With install CD in drive power PC up. The PC should boot from the install CD. Do a full install on C drive. This should format your C drive erasing everything on drive C. Format with NTFS (new technology file system). During install the PC will restart a few times. At one point it will require you to type in license code. About half way thru install you will be instructed to remove all disks from drives, at this point you enter setup (CMOS) again and change from boot from CD as first choice TO boot from HD and second choice boot from CD. If you can not complete install you may have a hardware problem. GIVE plenty of time for each install step. Install may appear to have stopped but it will continue when it has completed that step.
Oct 19, 2013 | eMachines Recertified - EL1852G-52W...
I cant install window 7 in lenovo laptop having no os at all.
Put in the Windows 7 DVD in the DVD ROM.
Turn off the laptop completely.
Turn on the laptop again and start hitting the F12 key continuously until you see the boot menu.
Highlight CD/DVD option using the arrow keys.
Press enter.
As soon as you get the message "press any key to boot from CD" then quickly press any key on the keyboard.
(Recommended when highlight CD/DVD then keep on tapping the enter key)
Stop pressing any key when get the message windows setup or loading files.
Select the English language and the country.
Click install now.
Click custom advanced.
Highlight the partition which should have the max size for ex: 320GB or so.
Click on the drive options at the bottom.
Click on format and the hour glass would come up for few seconds.
Then click on Next.
It will install complete Windows 7 in the computer and while installation computer will restart automatically.
Idle time of Windows installation is 39mins but it can get complete in more or less time depending upon the hardware configuration of the computer.
Then once the installation will be done just follow the instructions on the screen to create new user account and choose recommended settings.
Jun 13, 2011 | Computers & Internet
I WANT TO FORMAT MY TOSHIBA PORTEGE 7200CT LAPTOP TO WINDOW XP.HOWEVER,I DO NOT KNOW TO TO FORMAT
The instructions for this procedure are quite involved if you are talking about formatting and reinstalling the laptop operating system software. You need to have these things:
A Legitimate copy of the Operating system software on an official microsoft release CD that is bootable. Then you go to the bios in the startup usually by pressing the delete key while laptop is booting. then go to the boot proiority list and make sure the cd drawer is in the first option. Reboot the computer and then when the option to boot from cd comes up, press any key and it will boot from the cd.
Once the installation options appear, you need to select the hard disk to use and then select the format and install Windows XP. Select format using NTFS filing system and then the process starts to format the drive and install the file need to complete setup.
Once the GUI portion of set up installs and you have logged in for the first time, don't forget to change the boot priority back to the hard disk!
Hope this helps :D
Nov 23, 2010 | Toshiba Portege 7200CT Notebook
I just bought an little Hannspree SN10E288 with Linux. I can not install XP because all the partitions are unknown for Windows.What can I do for it.
Try the following, You need a bootable Windows CD/DVD for this
(1)Set your BIOS setting to boot from CD/DVD ROM first (before the Hard Disk or any other media)
(2)In order to set this priority resart your computer and as the first any information appears on screen start pressing "F2" and "DEL" keys swiftly and alternatively. A new screen appears....
(3)Look for "boot priority" and take the CD/DVD drive on top of the list. You need to experiment this a little because every PC BIOS has a different format to make these settings
(4) Insert your bootable Windows CD/DVD in your computer and boot from it.
(5)You will be asked to Press any key to boot from CD.......
(6)Press any key
(7)The Windows installation screen will appear.
(8)In the setup carefully select delete and select the partition where you want to install Windows.
You should have adequate space for Windows.
(9) Be careful do not touch the partition where the Linux is installed
(10) Once you have deleted the partition carefully Format it or make a Quick format.
(11)After that your Windows installation should start.
The rest is very intuitive......
Oct 06, 2010 | Computers & Internet
I want to reset my bios aspire 4730z.. please help me... i want to downgrade my laptop from win7 to xp...when i refomat to xp blue screen appear and some saying error.. please help
  1. Press the F2 key to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed). You can set the bios to default if needed.
  2. Using the keyboard arrow keys, arrow over to Boot.
  3. Refer to on screen instructions to set the first device to CDROM.
  4. Press the CD-ROM drive eject button and insert the System CD.
  5. Close the CD-ROM tray.
  6. Press the F10 key, and then the Enter key to save the changes and reboot the system.
  7. The computer will boot from the installation disk, follow the prompts to press any key to boot from cd.
  8. When you get to the screen that shows the partitions you should delete all of them, and then create new one. format and install your os. I hope this helps you good luck
Sep 24, 2010 | Acer Aspire 4730-4947 Notebook
NB100 fatal error while upgrading xp home to xp pro - pls. help
Hi
Try to go into System BIOS. Once you are in use the option Load Defalut settings.
And if any external device is connected other than CD-ROM, please disconnect it.
THEN TRY AGAIN TO INSTALL
Aug 03, 2009 | Computers & Internet
How to reinstall windows xp if files are missing??
actually you can reinstall your xp system but this you can't, why:
the reason
your windows xp system are being updated every month...
the version from original system are being extracted to a new version....
by this time reformat you hard disk...
Jun 18, 2009 | Gateway 310 Series (158920) PC Desktop
Sathish_pmssld
  1. You have to go to your bios settings by Pressing Delete key while booting and change your boot sequence to cd, floppy, hdd. Save and Exit.
  2. Insert your Windows XP SP2 disc.
  3. Press any key to boot from cd...
  4. Wait while Windows is setting up.
  5. When a TOA appears, Agree with their agreement by pressing F8.
  6. Install a fresh copy of Windows XP by pressing ESC key.
  7. Install on the selected Partition and Press Enter Key.
  8. Choose Format it to NTFS file quick.
  9. Wait until it reboots your computer automatically.
  10. This time after rebooting, the message "Press any key to boot from cd" shows up again. *DON'T Press any key to continue to Windows Installation.
  11. The Windows Installation is approximately 39mins. On 33mins, a message box will appear. Set your Time and Regional Settings and then click OK.
  12. Wait again 'til the box appears to Enter your Product Key.
  13. When you successfully entered the right key, wait 'til it completes your installation.
  14. Just click Next,Next, then Finished.
  15. After Clicking the Finished button, your installation finishes and loads through your desktop.
*Your vote is highly appreciated. Thanks in advance. Feel free to ask me anything. I would be happy helping and assisting you.
Best regards
Dec 26, 2008 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Reformatting pc
what you need to do is put the XP cd in the cd or dvd drive first,then, when the pc is booting up press either F2 or Del depending on bios and the cmos setting screen will appear. Go to advanced cmos settings and the top line normal reads 'first boot device, this will be set at HDD or hard disk, this needs to be changed to cdrom. When you have changed it, save settings and exit, the system will now reboot and an option to boot from cd screen will appear, you then press Enter to boot from cd then follow the instructions to format or install windows.
Aug 27, 2007 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
