Question about 2005 Dodge Dakota - Quad cab, 5 3" short bed - ProCap Bed Caps
To replace oil pan gasket, lift with hoist (cherry picker) or jack from under
Not sure if I should try to find a hook-up for a chain on top, or floor-jack from transmission area to get oil pan gasket replaced
  • BAK Master
  • 15,739 Answers
Lift it from the top. You can chain from the exhaust manifold if no hooks are present on the block.
Posted on Apr 06, 2013
How do I get my oil pan down
loosen motor mounts and jack engine up some
Feb 10, 2015 | 2006 Pontiac Grand Prix
Do I need to remove the engine from my 2001 4.3 V6 blazer in order to get the oil pan off?
Two ways no need to pull engine
One lets start with cherry picker engine hoist unbolt mounts slide bolts
Lift to desired height of two inches 4x4 accross inner tire wells now chain down to 4x4 pull pan off 10 minutes done
The other way is mobile home jack stands under motor mounts and mounted 4x4 at top chained down never on the front clip but on inner tire well
They make a specific engine lift on wheel wells for this your not lifting engine high enough but enough to get the pan off safely
Oct 24, 2014 | 2001 Chevrolet Blazer
How to remove oilpan on 97 firebird 3.8 liter
The Engine needs to be lifted up 5" so the pan can be slid out around the crossmember.
Nov 07, 2013 | 2000 Pontiac Firebird - 3.8 L V6, with...
Removing an oil pan
If you just can't get to that last bolt (have you tried a universal joint or wobbly?), then you will have to hang the engine up to remove the motor mount. Lay a heavy board across the fenders with blankets between board and fender to protect the paint. Chain up or tie up the engine to the board so it won't drop when mount is removed. Of course, if you have a "cherry picker" hoist you could hold the engine up with that. It won't be a great weight to hold with the other mounts still secure. If the radiator won't let you get to the mount, take it off too.
When you are done, and oil pan back on, just use a jack under the oil pan with a piece of wood between jack and oil pan, to raise engine for installing the mount back together.
Jun 03, 2012 | 1998 Plymouth Neon
How do you remove a oil pan from a 1984 z28 camero
Drain the oil completely, remove all the bolts and drop the pan. On 84 I don't believe you have to remove the tranny. Just remove the bolts.
You can go to autozone.com and signup for a free account. Then login to the account, choose your vehicle year, make, model, and engine size. Finally click on view repair manual. Now you have a free repair manual for your vehicle.
Apr 28, 2011 | Chevrolet Camaro Cars & Trucks
How do i lift the engine soas to change motor mounts
Usually the best way is to use a jack with a piece of wood under the oil pan. You should be able to jack up the motor far enough to remove the mounts. Or a engine hoist (cherry picker) can be used.
Apr 28, 2010 | 1988 Cadillac Sedan DeVille
Need to replace the oil pump on a 95 park avenue
You shouldn't have to for head gaskets, makes it easier but not necessary.
For oil pan, you may have too. Depending on how much room there is between pan and crossmember and if pan is in tranny. Some cars the oil pan is 1/4" behind tranny but don't think that is the deal on your car.
You can go to auzone.com and register for free. and you will have an AWESOME Full Free Online Repair Manual with everything you could need plus much more!
Aug 26, 2009 | 1995 Buick Park Avenue
On a 1997 chevy astro to pull out the engine does it come out under the van? theres no way to bring out thru the front with out haviing to cut,
Comes up and out of the 'Dogbox' with a cherry picker. (Can you say No Fun?)
You go through the side sliding door with a cherry picker.
Take the engine cover loose, and remove it. Now attach your lifting cradle, (Or chain with bolts so that the chain doesn't slide in the lifting hook), to the top of the engine. Lift up and back. Keep working it up, and out, of that small compartment. Use three people, and BE CAREFUL! Always have an exit planned in case something goes wrong. Stand away from the engine, not crowded down in there as you remove it.
Jul 12, 2009 | 1996 Chevrolet Astro
Easiest way to remove bed on 1988 s-10
pull all bolts get a engine puller or as i call it a cherry picker and hook one chain to the hook by the passenger side closest to the cab and the other side to the driverside by the tailgate.then get another chain and do exactly the opposite so that you make an X the hook the cherry picker/engine puller to the center and lift slowly..
Dec 01, 2008 | Chevrolet S 10 Cars & Trucks
2005 Dodge Dakota - Quad cab, 5 3" short bed - ProCap Bed Caps Logo
53 people viewed this question
Top BAK Vehicle Parts & Accessories Experts
Leighton Hurry
Level 1 Expert
Lawrence Oravetz
Are you a BAK Vehicle Part and Accessory Expert? Answer questions, earn points and help others
