Question about Samsung Cell Phones
My samsung gt-e2530 shuts down of its own accord.
The battery is charged and ok, but the phone closes down without me realising. What do I need to do to fix it?
SOURCE: P168 - shut down
try wiping off the connections n hold button down for a min.
Posted on Oct 20, 2008
Guaranteed
  • 3 Answers
SOURCE: My Samsung Omnia keeps shutting off on its own
Before you go and try and update the software on the phone it is always best to try the easiest soloution first.
The problem may just simply be a power management problem so try this.
1. On the main screen at the bottom task bar you should see phone on the left and main menu on the right. Now click main menu.
2. Now click settings
3. Now you see 3 tabs at the bottom. Personal, System and connections. Press the system tab.
4. On the new screen scroll down to the bottom and you should see power with a battery icon. Click it.
5. Now on this screen you see another 3 tabs at the bottom (there are actual 7 which are obtain through scroll), battery, battery power and external power. Click battery power.
6. On this screen you will see that it can be set to turn of if not used after so many minutes so changing these settings may solve your problem.
I hope this is useful??
Posted on Jan 16, 2009
  • 42 Answers
SOURCE: Battery won't take a charge - says "overheating"
HI,
change your battery is the best solution before your nit will be damage.
thanks,
Posted on Jul 02, 2009
  • 7 Answers
SOURCE: LG lotus shutting down
It sounds like its a software problem and if you have only had it for about 5 months it should still be under warinty. Try calling your provider and tell them whats going on and see if they can send you a new phone.
Posted on Oct 26, 2009
  • 1696 Answers
SOURCE: How can I unlock my
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Posted on Jul 23, 2011
How do I fix my samsung from slow charging
Before you try any of the steps / Methods provided below try this: Turn OFF power saving mode when charging. This is not mentioned anywhere online or in the user manual but works like a magic to resolve slow charging issues. If you still face the issue try various solutions here under.
________________________ Solutions for Slow Charging Problem on SamsungGalaxy S3 Method 1-System Dump System mode is a debugging panel where you can test, debug and execute different functions. There are also useful functions to give a boost to your network speed
>Open Up Dialer
>Dial *#9900#
>Scroll down, and Click "Low Battery Dump"
>Tap to Turn On
Method 2 Sometime slow charging issue on android devices occurs because of some software. So uninstall theunwanted software from your phone and then see if the problem is resolved or not. Another thing youcan do is master reset.
To master reset your phone, the steps you need to perform are Cache partition, Master reset and Safemode.
Cache partition- When you are facing slow charging issue on your Samsung Galaxy S3 you need to clearthe cache partition. It will clear different parts of your phone storage but will not delete any personaldata. To clean cache partition, turn off your phone and press the home key, power key and volume upkey altogether. When the phone starts vibrating, release the power key but keep holding volume up andhome keys. When you see the Android System Recovery screen, release both the keys. Now forhighlighting "wipe cache partition" press the volume down key. Select the option by holding power keyand wipe the cache. Highlight "Reboot system now" and press power key to restart the phone.
Method 3 Master Reset from Setting Menu- Master Reset may delete data from your phone's internal storage suchas images, content, apps, etc. But the data on SD or SIM remains saved. Back up all the data on internalstorage.
Then Tap the menu key> Settings> Accounts> Back Up and Reset> if desired, tap Automatic restore andBack up my data > Factory data reset> Reset device. If the screen is locked, then enter password and tapContinue> Delete all.
Safe Mode- Safe mode allows you to turn on your Samsung Galaxy S3 by disabling the third party apps.Then you can uninstall the apps that may be creating the Slow Charging Problem. To turn on the safe mode turn off your phone, then hold the power key. When you see "Samsung GalaxyIII" on the screen, release the power key and hold the volume down key.Keep on holding the key untilthe phone restarts. At the bottom corner of the screen, "safe mode" will appear and now release thekey.
Then uninstall the third party apps by going Menu> Settings> More> Application managers,Downloaded> tap the preferred application, then tap uninstall> Ok.
Then turn off safe mode by pressing and holding the power key> restart> Ok.
Method 4 Download and Install Greenify
Greenify is battery saving app that works best with battery boaster lite. Greenify places your appsin hibernation when not in used, this stop your phone from lagging and leeching the battery.
The Battery Boaster Lite is a power battery tuner application.It gives you full control of your battery andCpu. This app shows what is draining your battery and how to fix it.
Method 5 Sometimes slow charging problem occurs because of the apps that keep running in the background. So,though you charge the phone for hours after hours, it shows only 35% or less charge in the battery. Toclose those apps:
> Hold the home button and release it when you see the recently used apps screen.
> At the bottom, you will find the task manager button. Tap on it, then touch End all applications.
> At the top, you will find an option RAM, tap on it and clear memory.
These steps will close all the apps that are running in the background when the phone is charging, andthis is why it is slowing down the charging process.
Method 6 - Fix slow charging on android - Re-calibrate
How to Re-calibrating your android?
Remove the Battery from your Android
  1. Plug in original charger into your android without the battery inserted, VIA Power Supply .
  2. Leave it there plugged in for 30 Mins.
  3. After, insert the battery without removing the charger
  4. Let it charge to 100%
  5. When the battery is fully charged. Remove the charger
  6. Let your phone drains to 0%(Discharge) ( Do intensive CPU usage tasks, Playing games, streaming videos etc.)
  7. Repeat these step twice.
  8. The battery will subsequently receives it's charging cycle.
  9. By performing this every 3 times in per 6 months will keep your battery in good standing.
Thank n Regards
Laxman / Fixya
Mar 27, 2016 | Samsung Galaxy S3 16 GB White Smartphone -...
How can i unlock my Samsung GT-E2530 B.IMEI 35188405182498/7
Do you mean the network unlock?You can approach Wickedunlock.com and get the required unlock code for your Samsung GT E2530.You need to specify the country,locked network and based on the availability get the unlock code along with free unlock instructions.
Sep 06, 2013 | Xell Battery for Samsung GT-N7100,...
Samsung gt e 2350b
Aug 09, 2013 | Cell Phones
Samsung e2530 unlock code please
Hi. You can unlock your Samsung E2530 safer and easier using unlock code. You can get the unlock code for a Samsung e2530 from www.mobile-unlocker.com at affordable cost with easy unlocking guide. Good luck.
Jun 22, 2013 | Cell Phones
My Samsung Galaxy Note 10.1 battery not charging can you please tell me why
Same problem on my Samsung Galaxy Note 10.1 (GT-N8013) w/ OS 4.1.2
It just boots up and shuts down.
Dec 06, 2012 | Samsung Metallic Gray Galaxy Note 10.1in...
Samsung gt-e2530 master reset codes
lo use * 2767 * 3855 # a este codigo en un samsung gt e 2530 y me quedo todo ***** no se que hacer cual es la solucion
Sep 23, 2012 | Samsung Cell Phones
Phone powers up and immediately shuts down
Normally it is battery problem. First check your batter by charging fully. If your battery is ok but same problem then you need to reflash the phone, I mean reprogram the phone.
May 18, 2008 | Samsung SGH-X700 Cellular Phone
Cell Phones Logo
66 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
