Question about Kenneth Cole KC3485 Wrist Watch
How do I shorten watch bracelet?
I have received a Kenneth Cole Reaction stainless steel watch, model KC3436. How do I remove some of the links to make the bracelet smaller? A few of the links have arrows on them.
Thanks.
Mark
  • Anonymous Mar 19, 2014
    the stainless steel bracelet is broken with a missing link at the watch end. what is the easiest replacement method
  • 2,334 Answers
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 21, 2009
How do i set time for Kenneth Cole Reaction New York Digital Chronograph Men's Watch # KC1494
How do i set time for Kenneth Cole Reaction New York Digital Chronograph Men's Watch # KC1170
Jan 09, 2015 | Kenneth Cole Watches
The Genuine brown leather strap with polyurethane edges and stainless steel bucklehas fallen apart. How can I replace it?
mcdevito75 here, You should be able to get a replacement ******** ebay, search watches / Jewelery then watch bands.
Jun 26, 2010 | Kenneth Cole Reaction KC1267 Watch for Men
What battery is needed for this watch wen it goes out
mcdevito75 here, Possibly a 377 or 364, look for a small watch repair shop, they can tell for sure as I would need the watch here with me in Florida to tell for sure.
Jun 20, 2010 | Kenneth Cole Black Face with Stainless...
Kenneth Cole Wrist Watch unable to remove link
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
Job done!
Hope it'll help.
Regards
Arthur
Dec 15, 2008 | Kenneth Cole 1213 Wrist Watch
Unable to remove link from wristband of kenneth cole wrist watch
I am unable to remove extra links in kenneth cole reaction wrist watch
Oct 18, 2008 | Kenneth Cole 1213 Wrist Watch
I bought a kenneth cole reaction watch kc1292 A126-06 Solid Stainless Steel, (Digital Watch)(with a fat watch black leather bracelet) from Las Vegas JUly 26, 2008 and said carries a lifetime warranty. My...
Hi Junell ,you can't pulled out the crown,because it is threaded.First unthreaded it before you pull,first pull is for DAY/DATE adjustment.Second or full pull is for Hour / Minute setting,that's all.Feel free to ask and post a message,so i can assist..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Jul 30, 2008 | Watches
Leather watch band
I might have the solution. Is it a rectangular watch with a leather strap? It sounds weird, but I have a watch with no brand name on it (bought yesterday from K-Mart at $9.99) with the model #A126-06. The package insert said "Advance Watch Group." I googled them, and they manufacture watches for Kenneth Cole, Tommy Bahama and a bunch of other designers.
I was really surprised because K-Mart is the last place I'd buy a watch, except that it looked like my broken Raymond Weil tank watch.
I suggest you go to K-Mart and see if you find a watch that looks like yours.
The back of this watch is marked as follows:
V377
Stainless Steel Caseback
2035 Movement
Base Metal
Bezel
20279knx
A126-06
Jun 08, 2008 | Kenneth Cole Reaction - REACTION WIDE...
Kenneth Cole KC3485 Wrist Watch Logo
3,202 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
