Question about E-Machines M2350 Notebook
Emachine laptop shut down without warning
My e machine shuts off while operating. the power light stays on and i could hear the fan working. The Hard drive light blinks as if it is still processing.
I am out of ideas Can you help
  • 3 more comments
  • Anonymous Feb 08, 2009
    I have the same problem. I believe it is caused by a fan and overheating but I'm not sure. It probably requires professional service, parts replacement, and it may be more expensive to fix than the cost of the laptop.
  • cortneyculbe Mar 30, 2009
    i have the same problem, if you have any thing at all on the screen try hitting f10 , that should bring up a different way to your desk top
  • nadleen Apr 20, 2009
    I posted the problem with my laptop a few weeks ago and was asked for a little more info.My laptop shuts down while i am working on it . and steps that i have taken to try and solve my problem are posted .
    i used a can of compressed air to clean what i can so there is no cloging of filters ( if any). so the fan seems to be working fine (i guess)
    as for going to sleep . no it does not go to sleep it just stops and the only way to use it is to turn the power off and turn it on again.
    the problem usually comes when i am browsing streaming videos or youtube. and recently it is happening when i use an anti virus software like sypbot or AVG. it is starting to look to me that when the processor is working more that one program it shuts off. ( it has an AMD Athlone XP-M CPU).
    Friends have said that i should be happy that it lastd this long ( being an e-machine and all)
  • achmad baihaqi May 11, 2010
    yes maybe it's sleep or hibernating
  • Randy Hough
    Randy Hough May 11, 2010
    Are you sure it is not asleep or hibernating?
    Novelist:
  • 118 Answers
Test your monitor. To do this, you will need another monitor.
Plug in any desktop monitor to the output port on the back of the laptop. Restart the laptop.
If you are able to use the laptop using this other monitor, then your problem lies in a part called a video power inverter.
It is possible that it could be the lcd backlight, but that is doubtful.
The power inverter is available at many online markets for a relatively small cost. Installation is generally easy enough that any person with reasonable mechanical skills and a set of small screwdrivers can do it.
I once walked an 11 year old boy through the process from 1200 miles away over the telephone.
good luck
tony
Posted on May 23, 2009
2 Suggested Answers
  • 102 Answers
SOURCE: eMachine e627 screen blank
I am assuming you have plugged the screen into a known working power source. You have pressed the 'on' button to turn the screen on and you have hooked up the screen to the back of the computer. What I need to know is if when you power up the computer if you see any text at all from the post AND if you see any lights on the front of the screen itself. (most all screens have lights on the front of them to tell you they are turned on, and most of the time the light is green). If the screen is on but is getting an orange or amber light that means something. Also if you see text or something on the screen initially but not in windows then it could be a resolution or driver issue.
Posted on Jul 07, 2010
My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.And from yestarday it is shetting down after 30seconds after...
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
I decided to use a shop vac to suck the dust out and it worked. I tested it by letting the machine run all night and it worked. It's been a couple of weeks now and I'm glad I did it. I was ready to take the machine apart, now I'm glad I didn't. I'd suggest you use a heavy duty shop vac to clean out the fan and heat sinks first.I agree. Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Toshiba Satellite A15 Clogged Heatsink
Toshiba Satellite A35 Clogged Heatsink
Toshiba Satellite P15 Clogged Heatsink.
Aug 25, 2017 | Toshiba Satellite A205-S5855 Notebook
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
May 04, 2010 | Toshiba Computers & Internet
My laptop gets heat and shutdown
Solution:
Feb 27, 2010 | Compaq Evo N610C Notebook
My laptop, emachine m5312 shuts down by itself despite the power settings to stay on, any ideas?
it may be set to hibernate in the bios. if it's randomly shutting down while you are working then you probably have an overheat issue.
Aug 14, 2009 | E-Machines M5312 Notebook
Laptop Shuts down to black screen without warning.
it may be over heating !!
turn it on and run it till you hear the fan turn on, then check if there is much air coming out of it.
if not use a vacuum to **** air throw it as you blow hard into the slot that the air should come out of
Jun 17, 2009 | Gateway 450ROG Notebook
Emachine t5026 not power on. replaced psu.
I would test the memory. Also I think some computers will shut down if the fan on top of the CPU quits working. Or maybe one of the other fans or the Hard Drive quit and is drawing too much juice causing the PSU to shut down. It sounds like something may be grounding.
Jan 02, 2009 | E-Machines T2642 PC Desktop
Overheating
if fan is working well then it might have processor problem.
Nov 19, 2008 | Toshiba Satellite A105 Notebook
Power failure
your laptop may become overheated and that is why it shuts down, make sure the laptop is on a hard service so that the fan can get air. hot weather can cause problems as well.
May 28, 2008 | Toshiba Qosmio G25-AV513 Notebook
Emachine shut down
No, it's just the USB ports that are still being powered.
Totally normal in most new computers. Same thing with the PS2 ports.
There are jumpers on the motherboard that can change this if you really want. It's designed like that to keep things like you have powered for when you do turn it on and need them.
Apr 16, 2008 | E-Machines eMachines Desktop PC
E-Machines M2350 Notebook Logo
357 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
