Question about Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep
I have an ingersoll rand ssr-ep50 with intellisys always air end temperature
Everytime we run from 2 -4 hours it always automatically shutoff (tripped) we already search for leaks and tested thermostat valve on air end and seems we dont have any clue to solve it. we have also replace its oil on its desired level
  • 98 Answers
SOURCE: what is the amt of oil ingersoll-rand 242-5n air compressor need
Fill to the top of fill spout
Posted on Jul 21, 2009
SOURCE: I have an ingersoll rand ssr-ep60 with intellisys
There have a hidden button to turn on to do setting
Posted on Mar 31, 2010
  • 205 Answers
SOURCE: I HAVE AN INGERSOLL RAND
I know you have checked voltage. However please remove the fuses for control power and check,also check fu4 and 5 16volt fuses. next check power on the controller input. Don't remember terminal # but if you look in electrical cover removed to gain access, a wiring schematic will be affixed to it. I think it's on j5 terminal 36 110volts. But please check the schematic first. If you have power at the input terminal I suspect the controller is bad but continue with the following checks. If no power at terminal 36 check the hat (High Air Temperature) switch. Its located on the end of the airend and about 1/2 inch flex connected.If the hat switch is good check the emergency stop contacts. Note the power lite picks up voltage before the emergency stop and hat switch. So even though the lite is on one of these switches may be bad.
Posted on Mar 28, 2011
  • 54 Answers
SOURCE: What does alarm start fault
I use to start up a 25 HP Ingersol screw type compressor. The only alarms I got were from power spikes which just needed the reset button to be pushed, then the on button - and the low oil sensor would shut it down and give an alarm when the tank was about half way down. They will blow up with no oil so there is a saftey margin on oil level.
Posted on Mar 29, 2011
heatman101
  • 43501 Answers
SOURCE: I have a Ingersoll rand
Start with the simple things first... had a fellow a couple of montha ago that did not realize that there is an air filter....cleaned that and the air compressor worked great a again....
So... check your air filter...
Also does that model have oil in the crankcase??? is so check that you are part way up in the site glass with oil...if the unit has been used heavily, has the oil every been drained and changed???
This could contribute to rings getting sticky and hanging up...
If none of these things work then start going deeper into things...
heatman101
Posted on Mar 31, 2011
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
I have a ssr ep 100 and the intellisys says no control power ive tryed to clear it but it wont
Probably have a bad High air temp. switch located in the end of the compressor air end. It has control power run thru the switch. If the switch opens on temp or just goes bad you lose control power which will come up on screen as control power loss. Replace HAT switch.
Apr 02, 2013 | Ingersoll Rand Rotary Screw Compressor ...
I'm working on a Ingersoll rand 100HP stationary compressor with an intellisys 39875158 controller.
Make sure the model of your compressor is design for 160psi if not the main motor trip off and safe valve pop. Goto Main Menu, Operator setpoint+select, Offline/Online+select, arrow up and down to change value.
Jul 04, 2012 | Ingersoll Rand Stationary Air Cooled...
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep Logo
94 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
