Question about ASUS Computers & Internet
Where is the bios chip located on asus x401a mother board
SOURCE: bios chip location on mother board
no,, reinstalll the vista,, the problem will not occur again
Posted on Jan 08, 2010
emallari27
  • 86 Answers
SOURCE: fujitsu amilo simens Pi1536 and Pi1556 bios password chip locatio
Hi ,
Replacing the existing BIOS chip with a new one you can buy from your specialized electronic shop or your computer supplier. It's a quick operation if the chip is inserted on a base and not soldered to the motherboard, otherwise you'll have to unsolder it and then put the new one. In this case would be more convenient to solder a base on which you'll then plug the new chip, in the eventuality that you'll have to change it again. If you can't find the BIOS chip specifically made for your motherboard, you should buy one of the same type (probably one of the ones shown above) and look in your motherboard manufacturer's website to see if there's the BIOS image to download. Then you should copy that image on the chip you bought with an EPROM programmer.
Important
Whether is the method you use, when you flash the BIOS not only the password, but also all the other configuration data will be reset to the factory defaults, so when you are booting for the first time after a BIOS flash, you should enter the CMOS configuration menu (as explained before) and fix up some things.
Also, when you boot Windows, it may happen that it finds some new device, because of the new configuration of the BIOS, in this case you'll probably need the Windows installation CD because Windows may ask you for some external files. If Windows doesn't see the CD-ROM try to eject and re-insert the CD-ROM again. If Windows can't find the CD-ROM drive and you set it properly from the BIOS config, just reboot with the reset key, and in the next run Windows should find it. However most files needed by the system while installing new hardware could also be found in C:WINDOWS, C:WINDOWSSYSTEM, or C:WINDOWSINF .
ERNZ
Posted on Feb 03, 2010
blnewlandjr
  • 54 Answers
SOURCE: where is the clock battery
You will see the battery on the lower left corner. It is silver, and looks like a button. CR-2032 is the model.
Bruce
Posted on May 05, 2011
bayyagg
  • 1672 Answers
SOURCE: sony vgn viao tz mother board - where is bios
The battery for CMOS is under the touch pad.
Remove the screws under the laptop and remove the lid cover on the touch. You will see the battery you were looking for.
Hope that helped you out!
Posted on Sep 13, 2011
  • 564 Answers
SOURCE: vertical display
if you Ctrl Alt and the up arrow key to get it back to normal.
Posted on Nov 10, 2012
Manual for asus-x401a-bcl0705y
There is a lot more on the Asus website than just the book named Manuel. He is from Spain.
The manuAl is here
https://www.asus.com/Notebooks/X401A/HelpDesk_Manual/
One the link below, read the impressive specs and then click on Support on the right hand side.
Jan 02, 2016 | ASUS Computers & Internet
Where is the jumper on my ASUS X401A motherboard
You need to take the covers off the bottom of the machine and look in those areas for the jumper. It could be under the ram, near the hdd or the battery and the wireless cards. They don't publish the location because it is an anti-theft feature.
Aug 01, 2014 | ASUS X401a 14.1-Inch Laptop Black Intel...
Asus bios reset password on x401a
Check the manual that is on the laptop or type the name of the laptop and the number brand, click enter and your manual will show up, scroll down to find the BIOS of your laptop.
Dec 30, 2013 | ASUS X401a 14.1-Inch Laptop Black Intel...
Motherboard schematic asus x401a
Sorry, not available due to the type of PCB design using multilayer boards and copyright infringement issues.
Dec 05, 2012 | ASUS Computers & Internet
New sata harddisk not detected
The mother boards from that time you had to install the RAID drivers to use SATA drives. The drive disc which came with the mother board should have the drive, but I would suggest going to ASUS's web site and download the latest drivers. Click the link below, Select which OS (Operating System) you are using, Next click the little + box next to "IDE" and the drivers needed will be listed.
http://www.asus.com/product.aspx?P_ID=xCBogxJhh6yWBQRi&content=download
Jan 26, 2010 | ASUS P4V8X-MX Motherboard
Hardware Detection problem with ASUS K8VMX Mother Board
Firstly, Put a new battery on your motherboard(usually a cr2032).
Unplug everything except the ram and try to boot up.
Switch off and gradually attach one component at a time and reboot.
Remember to turn off every time you add a component.
This happens because your bios chip is getting mixed up because you are changing the configuration all the time.
Hope this helps
Jan 19, 2009 | ASUS K8V-MX Motherboard
How to solve the asus K8V-Mx mother board
SANDEEPDATAS
try resetting bios first if that doesnt work check for dust around the first ram chip and slot
remove the dust and retry if that doesnt work try another psu if you have one
let me know if we need to go further
rhodnhelm
go to the asus site
support
downloads
select from right hand side motherboards skt754 k8v-mx hit search
select o/s and there are your drivers
Oct 30, 2008 | ASUS K8V-MX Motherboard
Intel upu ucode loading error
While starting computer a msg appear " intel upu ucode loading error" after pushing F1 computer get start my computer having ASUS mother board P5BMX/WIFI-AP and intel core2duo procesor Please help
May 19, 2008 | Computers & Internet
Computers & Internet Logo
195 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
