Question about Kenmore 88732 Top Load Stacked Washer / Dryer
Washer won't drain or spin
I have a stackable Kenmore laundry center and the washer will fill, aggitate but won't drain, before going to the rinse cycle and then won't drain or spin.
  • 1 more comment
  • s_riggins Jan 21, 2009
    That was it! I stuck a pencil into the slot where the plastic stem on the door went in and it went into the spin cycle. There are two little screws right above the slot and I tightned them, one would tighten but the other wouldn't so I slid my fingers under the slot and felt a washer or nut land on my fingers. I tried to slide my fingers out slowly but the nut slid off them and of course I can't find it. But I'm pretty sure that I have to remove the top rim off the washer to replace the nut onto the screw anyway. Any ideas how I can do that? Thanks for telling me about the lid, I was sure it was going to be the timer.
  • Anonymous Feb 13, 2009
    Genius. The switch at the lid was broken - entire plastic casing split. This apparently disables the spin cycle. Ordered new switch. THANK YOU SOOO MUCH for this extremely helpful help!
  • Anonymous Mar 12, 2014
    WAsher fills/washes will not advance to spin and rinse. Was abl to do it manually but now will not do it at all
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Posted on Jan 21, 2009
MY LG MODEL F1403FDS5 IS SWITCHING OFF AFTER 6MINUTES WHEN ON 30MINUTE CYCLE BUT IF YOU SELECT RINSE AND SPIN IT FINISHES THE CYCLE.
check the ibnlet screens for the water valve,they may be plugged, also make sure the drain hose is above the washer so it dont siphon out as it fills
May 06, 2014 | LG WM2077CW Laundry XL Front Load...
Washer won't drain and spin
Drain pump is cloged. What kind of washer is it . and you said stacked and laundry center. stacked is 2 seperate units and laundry center is one whole unit with both so whatcha got?
Feb 17, 2013 | Frigidaire Washing Machines
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
I have a MAYTAG washer that was having trouble in the spin cycle it would drain but would spin slower like the brake was coming on. Now it rinses and spins fine but during the wash cycle it fills then once...
More than likely it has a broken wire underneath that controls the spin. and agitation. I had an old Kenmore that the wire that controls these functions would break about every 6 months.
Apr 28, 2010 | Maytag Washer Timer - 22004015
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
My washer will not pump out water or spin . it will fill, and aggitate. drain hose is not kinked
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 28, 2010 | Kenmore Washing Machines
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 88732 Top Load Stacked Washer / Dryer Logo
554 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
