Question about Sony Playstation 3 (PS3) Console
80010514 error code
I was in the middle of a game it froze i took the disk out put it back in worked for a while then stoped reading the disk. i shut the system down then tried agian it wouldnt read the game anymore or any game that was blue-ray. i reformated the playstation wich took 4 hrs, and then it started the game after but only lasted for a little while and now im back to were i was 4 hours ago. ohhh and i also have the new updated version to. 2.01. thnax. I have error message 80010514 on my playstation 3 screen .. machine started to load up when it was restarted.. however it went back to not reading ANY discs at all .. blu ray or not.. ive gone inside and cleaned the lens but still no disc will play... it starts to play but then idles at a blank screen..
i need it fixed
  • beamo82 Jan 21, 2009
    I have exactly the same problem, I have contacted sony and they are sending me a reconditioned one, this might be your best bet I've had mine for 18 months and no problems until now. I suspect a download has coursed this fault
    President:
  • 2,559 Answers
The error code is actually one of two things, a) a faulty sector on the internal hard drive, or b) a faulty installation of software/firmware, both iterations actually coincide with eachother. If the hard drive suffers a faulty sector ( a section of damaged space on the drive that data may have been written to that no longer is readable), an installation may still be processed, and even work, but the error can cause some serious side effects, such as option b. If your PS3 has installed an item incorrectly, including firmware, it is in high risk of receiving this error.
Basically, what is occuring is the corruption of game disc recognition and execution. If you will notice, in 90% of all cases, the drive will still play DVD and even Blu Ray movies with no problems. When trying to start a game however, the title, sooner or later, will receive the error.
1) Ensure that your internet connection is stable. If you are using a wireless connection, make sure your signal is at least a solid 80%. If not, make the proper adjustments until it is.
2) Dust your machine regularly. Any PS3 owner will tell you that the Playstation 3 is a dust magnet. Just run a dry cloth over it every couple days, and you should be fine. This will help prevent heat issues and shorts that may occur.
3) When installing firmware and/or software, make sure you follow the instructions. Even if you have installed 6 versions prior, each one is different, and may require additional steps. Save yourself the headache and just follow them, it only takes a minute or so longer to do it right.
The error is not hardware related and is caused due to corruption of firmware. Restoring you PS3 will not roll back the firmware, and unfortunately will not fix the issue 9 times out of 10. If you are receiving this error, contact Sony for a replacement unit.
Posted on Jan 24, 2009
FIFA 11 game wont start (PS3) gives me error code 80010514. All other games work fine. Game works fine in brothers PS3. Never had this problem before. PS3 support says they have had a lot of calls with...
It's eiyther one of two problems:
The first is that FIFA 11 is screwed up due to an EA Sports programming glitch within the game - (see http://www.community.eu.playstation.com/t5/Technical-Help/FIFA-11-Error-80010514/m-p/11614173))
OR
The second is that your PS3 is dying and the laser won't read discs. Which gets progressively worse, or so i've read. - (see http://www.ps3blog.co.za/2008/04/10/ps3-error-80010514-explained/)
I'm getting the same error but my PS3 isn't yet 12 months old, so is going back to the store.
P*ssed that I can't play the new FIFA though!!!!
Oct 02, 2010 | Video Game Consoles & Games
Playstation 3 error code (80010514) what does this mean
If your PS3 is reading DVD's and CD's, but NOT any type of BLUE-RAY media.....95% sure it's a faulty laser. The Backwards compatible units are equipped with a RED laser for DVD and CD reading. The Blue Ray Diodes are faulty..especially in the earlier production models. This was due to the shortage of parts during production, so SONY out sourced from multiple producers of BR laser units.
My 80gb , 4 usb, Backwards combatibility unit started doing this. The game froze, system became unresponsive, wouldn't show the the Disc ICON in the XMB for PS3 games. When the games did load they would play for a few mins then freeze, or error code 80010514 would appear.
I got the laser replaced by a reputable repairman, now the system works without fault. It's been running for hours with no problems.
Get the lens replaced by either SONY or someone who knows what they are doing....also give your PS3 a good dusting everyday. When the Laser unit gets too hot the diodes malfuction and eventually fail.
Jun 01, 2010 | Sony Playstation 3 (PS3) Console
Ps3 error code 80010514 and wont read the disc
Hi, if your PS3 is reading DVD's and CD's, but NOT any type of BLUE-RAY media.....95% sure it's a faulty laser. The Backwards compatible units are equipped with a RED laser for DVD and CD reading. The Blue Ray Diodes are faulty..especially in the earlier production models. This was due to the shortage of parts during production, so SONY out sourced from multiple producers of BR laser units.
Get the lens replaced by either SONY or someone who knows what they are doing....also give your PS3 a good dusting everyday. When the Laser unit gets too hot the diodes malfunction and eventually fail.
Take care
Apr 30, 2010 | Sony Playstation 3 (PS3) Console
Got error code 80010514 after trying play COD online, screen froze now no other games will play
hi,
this error code (80010514) is indeed a hardware failure, to be more specific, the Blueray drive has failed and the system will not run like this. If you can still avail the warranty, then sent it back for replacement under warranty. I hope this may help you,
best regards,
kaybicks
Feb 27, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont read disk,when it does will play for a few minutes then freez up.it reads error 80010514
does not sound good. do any other disk have that problem? if so its your system and i recommend calling sony for custumer support, if not you may have a fualty disk due to perhaps incorrect area codes within the disk
Dec 31, 2009 | Sony Video Game Consoles & Games
It says error 80010514
Hi
This ia a known error with the ps3 and unfortunately is not that easy to fix. Sony simply have the following to say about this error
"Error 80010514 - Issue reading Disks"
If this error is showing on more than one disk then the problem lies in the blueray drive itself which has become faulty. Sony are advising that these ps3's which are showing this persistant error need to be returned for service. Expected cost is around $150 if your unit is outside warranty.
For information on how to return your unit see this link
http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=106&p_sid=9cqPaKMj
Many thanks for using FixYa.
Nov 11, 2009 | Sony Playstation 3 (PS3) Console
PS3 error Code 80010514
there might be 2 things wrong with it. 1 the laser is broken or not working right. and 2 the code files that are supposed to read the disk are corrupted either way if you still have warranty on it i would go back and get a new one as long as its not your fault there would be no problem replacing it
Jul 10, 2009 | Sony Playstation 3 (PS3) Console
Error code 80010514
Unfortunately, from what I have read, it looks like you should call Sony. This is a hardware failure code and has nothing to do with firmware. Hopefully the system is still under warranty.
Jun 25, 2009 | Sony Playstation 3 (PS3) Console
Error Code: 80010514
it could be that you have something turned off in your Home Ps3 settings like under BD settings or any other settings that have to do with the disks or disk speed.
Oct 10, 2008 | Sony Playstation 3 (PS3) Console
Error code
Return under warranty, ps3 uses a high powered blu ray laser that can melt the lens after extensive use, sony is working on a fix and will repair this for you for free unless you have opened the case.
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
115 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
