Question about Maytag MHWE200XW Washer
Maytag F1 E6 error code
Washer drains ok, lines clear, pump works ok, filter clear. I keep getting this error code, 2.2-2.7 peak pump amps
  • 1 more comment
  • Ernie Myers Jan 10, 2013
    Found the problem to be a stuck pressure switch located above the air trap that senses water level in the washer, when water level drops it creates a vacuum indicating washer is empty.
  • nguyenle
    nguyenle Jan 13, 2013
    I have the same problem... washer will not start. Can you tell me where the pressure switch is? I just brought this washer last week.
  • Ernie Myers Jan 13, 2013
    Remove back panel, as you are faceing the washer from back to front it is located in the top rear left hand corner on the rail. Also make sure the strainer to the pump is clean.
milten1
  • 1304 Answers
SOURCE: Why won't the washer drain? Pump appears to be
if this issue is because you hear water in the machine when the tub spins......
thats normal, its called the balance ring
centrifical force, pushes the water in the lid, outward helping to use the sling weight, as a counter balance
its 100 percent normal to hear sloshing when turning the tub by hand
Posted on Oct 13, 2009
SolutionGuy
  • 331 Answers
SOURCE: LD error code appears on maytag nepune washer
Roz,
You have some kinda something stuck in your drain pump. The computer that controls your washer has detected that it's taking too long to pump out and therefore refuses to spin.
Now this will take alot of work, but it'll save you a couple hundred, OK? First you have to get as much water out of the washer as possible. Fortunately on the Maytags you can do this fairly easily. Use a garden hose and connect it to the end of the drain hose (from the washer)... use duct tape to secure it. Then run the garden hose outside and make sure it's downhill. Now take the corrugated drain from your washer and lower it below the base of the washer. This will drain it completely.
After the water has drained, pull the washer away from the wall... enough for working space. AND DON'T FORGET TO UNPLUG IT! Remove the rear panel (4 screws) and you'll see a big pulley in front of you.To the lower left, you'll see the drain pump. It's mounted to the base of the cabinet. Use a 5/16" to remove the hose clamps then remove the hoses. Then remove the wires that feed the pump. When that is done, you should have the pump in your hand.
Now that you have the pump in hand you'll see the pump housing (it's white). There are three screws holding the pump housing to the motor. Remove them and separate the 2 parts.Now you'll see the cause of the problem. Some trash got pulled into it. Probably a rug bottom or a dog bed....
Remove the stuff and rebuild the unit in reverse order and you're good to go.
Don't forget to rate my solution!
SG
Posted on Apr 10, 2009
  • 12 Answers
SOURCE: Maytag Epic-Z F-28 error code
F28 is a misc error,
most of the time it is because the washer is NOT LEVEL.
1. Unplug waher,
2. Relevel washer. (make sure all legs are equally distributing weight, so as to ensure no shaking). See owner's manual.
3. Plug in, and use.
Hope this helps.
Jay
Posted on Oct 04, 2009
SOURCE: My washer keep showing F1 error and then stop, I
Remove the three screws in the back of the control panel and lift the control panel up. You should see a clear plastic tube to the far right going into a gray plastic box.
There is either a kink or break in this hose or the controller board (the grey box) is bad.
Try removing the hose and blowing in it to check for any resistance (clog).
I just bought a controller and they run about $200
Posted on Jan 10, 2010
Testimonial: "Thank you, I did not see anything wrong with the clear tube, however I forgot to blow into it. I will double check it before ordering the controller. "
SOURCE: We have a front loading 3000 series Maytag washer.
Just had this problem on Sunday. For a FRONT loading 3000 series, remove the front bottom panel (three screws - lay on floor and you can see them). There is a plastic can to the left of the pump. The front cover to this can screws on and off. Be prepared for water to gush out and unscrew the cover to the can. There is a filter/trap in there. Clean this out and it should solve the problem. Not sure why the manual does not cover this.
Posted on Jan 15, 2010
What is the error mean f1 E1 on my may tag front loader washing machine
Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
have E1 and F1 error code fleshing and wate Sears PartsDirect
http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
Appliance Repair Forums
Error code F1E1 null ShopYourWay
Central Control Unit CCU Maytag MHW6000XW Washer
Mar 07, 2016 | Washing Machines
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
My tandem 7300 is giving me the e1f1 code how can I fix this
F1 E1 error fault code - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Mar 20, 2012 - 6 posts - ‎1 author
I also cleared all error codes and the F9E1 error has disappeared but ... to send out a technician and I would prefer to make that my last resort.
Questions and Answers for Whirlpool W10253483 Latch ...
www.appliancepartspros.com/questions-for-whirlpool-latch-w10253483-...
how do I run diagnostic on my washer # wfw8300sw05? Joe M .... Answer Irene, The door lock could very well be the issue with the unit giving the f22 error code.
Maytag , Whirlpool Washer Repair - Drain pump error, no ...
? 4:29
https://www.youtube.com/watch?v=QMRIPmrlAkI
Jul 2, 2013 - Uploaded by ApplianceVideo.com
Service a Maytag Washer suffering from this following dilemmas: Drain pump error f9e1. ... Front Load Washer ...
Amana Fault Codes - Appliance Help Online
Jan 05, 2016 | Washing Machines
I have the maytag series 4000 and got the f2 code. I have cleaned the.hoses and wven replaced the drain pump. Is thete a rest button? It is still not working and.shows the same code
F2 code is water level to high
Washer Error Codes
Below is a list of washer error codes for HE & conventional top load washers and front load washers. As more error codes are found or published, we will add to the list. Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, and Whirlpool. This list might not be complete and should be used for reference only.
Asko Washer Error Codes
• F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
Sep 19, 2014 | Washing Machines
Got F21 on the washer...what do I do?
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Sep 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Have a Maytag washer MAH8700AWW, I keep getting ND messag. Replaced water pump and machine still behave the same.
Hello, You may have not have had to replace the pump in all actuality. The ND error code can be caused by anything caught in the entire drain area which means from the port hole that comes out of the outter tub you would need to remove the hose that connects to this spot and then to the pump. Also you would remove the drain line after the pump as well and assure in both areas that there are no obstructions. If you still have the ND error code after you have assured you have no blockage in either of the above mentioned areas message me back for further diagnosis. Also after you clear the clogged area make sure you unplug the unit for 7-10 minutes this causes the control to reset which is easier then you haveing to go into diagnositic and clear the error code. I await your reply Thanks Rick
Aug 27, 2011 | Maytag MAH8700A Front Load Washer
Hello My Maytag black front loader washer is displaying an error code of F02. Do you know a fix for this error code? Thank you
F02 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Maytag Washing Machines
F21 error on model mhwe300vw13 maytag 3000 it
Kevin
Aug 05, 2011 | Maytag Washing Machines
He2 plus front load washer keeps showing F21 error code. I cleared the drain pump filter. Still displaying F21 how do i check to see if i need a new pump
If you found a blockage in the pump screen restricting the drainage and it now drains fine but F21 is still there,the error code can be cleared by pushing the PAUSE/CANCEL 2 times within 2 seconds.
If after clearing the error code if it returns on the next wash cycle the pump will need to be replaced.
I hope this has helped you resolve your washer troubles,
Gene
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
I keep getting the code F21 & sud.... not draining... any ideas
Kevin
Jul 31, 2011 | Whirlpool Washing Machines
Maytag MHWE200XW Washer Logo
950 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
