Question about Sanyo DP46848 LCD TV
I have a 46" sanyo lcd and its dark on the right side about a third of it. After about 30 mins to a hour it will either go away or shift to the left side. If it shifts to the left side I can tap the s
  • Sanyo Master
  • 933 Answers
I would suggest you take it to a shop, but I had a 46" Sanyo with this same problem, turned out to be a defective panel
Posted on Jan 10, 2013
  • 131 Answers
SOURCE: Our sanyo lcd tv is a couple of years old and
Hello; I am John at J. D. Electronics, Poland Maine. This problem is caused by a defective LCD panel. This part is very expensive! Aprox $ 1000.00 from Sanyo and less than $400.00 from Encompass Parts Inc.
Posted on Oct 09, 2010
SOURCE: Wanted: 32" Sanyo LCD replacement screen (compatible)
take apart the lcd and find the lcd panel number then email patel150@gmail.com to buy a new panel from a factory in china
then put it all together
Posted on Apr 17, 2009
toolkits
  • 1099 Answers
SOURCE: Sanyo LCD no power
Hello, the problem could arise from one or two faulty components, but you have to open the back cover of the television and check for the fuse if it is blown up , and if blown up replace with the same rating. Since you have no ideas on television you can contact the manufacturer, but likely component that may go bad are the capacitors, power transistors and regulators...
Posted on May 20, 2010
  • 130 Answers
SOURCE: sanyo dp32746 32in.... is making
hi
the common procedure is to replace 1 or 2
capacitor on the board i would suggest to take the board out and take it to your local repair shop and they'll know what to do
Posted on Sep 30, 2010
SOURCE: I have a Sanyo 46
There is no solution this has happened to me 3 times in 13 months each time they replaced the screen panel (basicly the whole TV) I have a 2 year service contract, the next time it does it they will not bring it back but will write me a check for the price I payed for this peice of ****.!!! Do not bother fixing it.
Posted on Oct 22, 2010
Our sanyo lcd tv is a couple of years old and recently when the tv is on for the first couple of hours the screen will flicker and get progressivly darker from the center of the screen to the left....
Oct 09, 2010 | Sanyo DP46849 46 in. HDTV
Right side of screen becomes discolored and fuzzy after 15min
if its an lcd, it could be a bad lcd panel
does the menu or volume get distorted or dark too?
yes - likely lcd panel
no - video board (main board) problem
a technician would use a can of "freeze spray" to find the issue inside, by cooling down the parts until the problem goes away.. the part you froze to reverse the issue is the bad part.
Jun 06, 2010 | Televison & Video
When I trun on TV (Samsung LN-T4661F 46 In), it start with half scrren dark from Right Side, time goes by being normal screen. I want to know what the problem is.
Samsung made a bad TV, the new part is $1200 I have the same issue. it is a blurred picture from left to right after about 10 min it goes away. (18 month old tv) it is only going to get worse.
Jun 05, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
The screen is dark on the left side
The fluorescent tube behind the LCD panel has failed, a quick fix for an engineer.
Apr 19, 2010 | Sanyo DP46849 46 in. HDTV
Black shadow boxes on 46 in Samsung 46 in LCD HDTV.
Ur backlight video board is dying,must replaced to solved this problem.Part and labors about $500.
Dec 15, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Sanyo 46 IN. tv DP46848. The left 1/3 of screen is dark
It is a common problem for this model of a Sanyo TV, it uses a Samsung or Chime LCD panel.
The problem is the data buffer IC soldered on the flat flex cable between the LCD panel & the buffer board that gets damaged or loose soldering. If you be able to fix yourself, you may find some videos on YouTube, it will show you how to fix the buffer problem.
Jun 01, 2017 | Sanyo Televison & Video
I have a Sanyo 46 inch flat screen hdtv purchased from walmart aug. 31rst, 2008. Sure enough, 13 months later my tv is having picture problems and getting worse. It started having portions of the screen...
I have the same problem, my television is faded black on the left side with lines on the left top side. I have had the 46 inch unit for 1 year and 7 months. I am planning to write a demand letter to Sanyo and then taking them to small claims court woth evidence that this is a common problem with their units that they know about and is not trying to remedy. Also the Attorney general in Texas should have an interest in them (Walmart and Sanyo) selling these defective proucts in the state.
Nov 01, 2009 | Sanyo DP46848 LCD TV
Vertical line on my 46" toshiba lcd tv
The only logical solution for the problems people are having for the toshiba regza's tv's is to get into a class action law suite..., they contiue to sell tv's with defective parts and refuse to help the customer that spent large cash to find out they last if your lucky 2.5 years, they are junk and anyone with one will soon find out./.......
Apr 03, 2009 | Toshiba Regza 46RV525U 46 in. LCD HDTV
Sanyo DP46848 LCD TV Logo
313 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
