Question about Car Audio & Video
Time change on radio
Can't change the time on my stereo, and i need help please?
  • 21 Answers
Need a little more information on your car radio, what Model and Brand is it?
Posted on Jan 10, 2013
I bought a new battery and still wont start
Have you had the alternator checked? may not be charging the battery.
Oct 30, 2012 | 2004 Mercury Mountaineer
How can i replace 1991 maxima radio system?
The original radio is a BOSE system and it has a buit in amp. So if you replaced the deck you need to replace the speakers all so. Don't cut the wires to hook-up the deck buy an addapter KIT. It's not just the stereo that runs though that harness the factory alarm does all so and that will cause you problems. Anyway back to the stereo you need to add an amplifier and problem sovled.
Jul 23, 2012 | 1991 Nissan Maxima
What is the headphone jack size of the fender sp-10 10 watt amp
Call your local stereo store. These items are very standardized.
There are 2 standard sizes for headphones. the one for PCs and phones is the smaller size. An amp or receiver probably take the next size up. If you screw up and get the wrong size someone like Radio Shack or the like will have an adapter that sells for a buck or 2.
Jul 03, 2012 | Fender Sp-10 Electric Guitar Amp 10 Watt
Need to know the wires for the radio in a galant
2001 Mitsubishi Galant Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Black
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
Jun 06, 2012 | 2001 Mitsubishi Galant
Hi, i have a lexus is200 se 2002 reg, have no sound from front speakers. Can i change cd plyer for aftermarket and bypass the amp, or is the amp broke? Geoff
Good question, but unfortunately not that easy to find out. Although it is possible. If you have access to the amp and are handy with a multimeter, then this will be a simple find. If you aren't handy with electronics, then I recommend taking it to the local stereo shop. You can replace any radio. It's the harness that will make or break you on this. You will need to specify that you want to bypass the amplifier. This will put deck power to the speakers, instead of going through the amp. Now that we have established that you CAN change the radio, what if it's the speakers. They too can be replaced, but will have to be tested. Again, the local shop can help.
Happy Hunting
Aug 13, 2011 | Car Audio & Video
Please help, My battery went flat & now I've lost my Code for My stereo. Ford Puma 2001 Radio 6000 RDS M003714
get in touch with a ford dealership with your chassis number and they should be able to give you the code for your stereo
Jul 26, 2011 | 2001 Ford Focus
HOW DO I CHANGE THE TIME
    • 1
      Refer to the section of your owner's manual that addresses the car radio. Each car radio is different in the way you set the clock. If you've installed a car radio other than the one that was manufactured with the car, consult the manual for that radio.
    • 2
      Know that if this is the first time you're setting the clock or are setting the clock after installing a new battery in your car, you have to set the hour and the minute of time. Often, you set the clock with either the radio station up or down arrows. On some car stereos, you use the CD track selector buttons for setting the clock.
    • 3
      Using either the CD or radio selector buttons, set the hour first. Push the button labeled "Set" or "Clock" and then set the minute with the same procedure. When setting the minute, some manufacturers allow you to move through in increments of five by pressing and holding the button. If the time of day were 2:49 p.m., for example, you would push the button 13 times, including nine times to display :45, then four additional times incremented by one to display :49. Push the "Set" button or the "Clock" button.
    • 4
      Determine whether your car stereo is equipped to automatically change when Daylight Saving Time begins and ends. If it hasn't changed at 2 a.m. of the time-changing date, you know it isn't equipped for this. In that case, set the hour either forward or backward and the appropriate time of the year.
    • 5
      If you can't figure out how to set the clock on your car stereo, wait until noon on any given day, disconnect your car battery and reconnect it.
Read more: How to Set the Time on a Car Stereo ' eHow.com http://www.ehow.com/how_5003245_set-time-car-stereo.html#ixzz1MlfuX6eT
May 19, 2011 | Car Audio & Video
What is the color code for the radio ? we are changing the radio and need the wire codeing for the factory radio
For 2001 Buick Century Car Radio Stereo Audio Wiring Diagram...
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope helps (remember to rate this answer).
Dec 30, 2010 | 2001 Buick Century
No power
It sounds like your charging system may be causing the problem. The voltage may be too high or the stereo may be too sensitive to high voltage. You need to connect a voltmeter to your system to make sure it's not charging over 14.5v. A normal charging system wii charge at 13.5-13.8v.
Have someone connect a digital multimeter to the B+ and ground wires of the head unit. Have a passenger monitor the voltage while driving. If the head unit cuts out at the same voltage each time and the voltage isn't excessive, the head unit needs to be repaired. If the voltage goes up above ~14.5v, the charging system needs to be checked.
Oct 17, 2007 | Car Audio & Video
Car Audio & Video Logo
273 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
