Question about Konica Minolta bizhub Office Equipment & Supplies
Error code 960 in bizhub c350 - bizhub Konica Minolta Office Equipment & Supplies
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
jmassengill
  • 345 Answers
SOURCE: Bizhub C350 - Print spooler not running after power outage
I would print out a copy of the network configuation of that printer and ensure it has the proper network settings (I.E. IP address, Subnet mask and Default Gateway. I just worked on a printer that I accidently pull the plug on and it lost it's network settings and wouldn't print until I changed them back to the correct settings.
Good luck
Posted on Nov 11, 2008
  • 24 Answers
SOURCE: Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Posted on Jun 25, 2009
  • 158 Answers
SOURCE: volume track (e.k.c.) error on Minolta C350 Bizhub.
go to the properties of the driver and click on printing preferences and click on authentication/account track and the user name and password that you use to make a copy will have to be enter in this area to to print
Posted on Dec 02, 2009
SOURCE: How do you clear error code on a bizhub C350. A
while powering up machine hold down utility/counter key until trouble reset appears on screen. select it and ok should apper under it. power down machine for atleast 10 sec and turn machine back on.
Posted on Jul 22, 2011
C0991 error on bizhub c350
check the gear assy behind the front cover of the bottom draw
Dec 30, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
I ave problem on c350 error code 2160
BIZHUB C350 SHOWING ERROR CODE C-0900 AND
NOW C-0950
Sep 30, 2013 | Konica Minolta Bizhub C350 Digital Copier,...
Error code 960 in konica bizhub350
Bizhub errors are 4 digits (with a letter in front in the manual). Is this a 350 or a C350 (black and white or color?)
Jan 10, 2013 | Konica Minolta Office Equipment & Supplies
Error c-0200
konica minolta bizhub malfunction detected error code c-0200
Sep 01, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
How do you clear error code on a bizhub C350. A piece of paper was fused on the fuser unit and we were able to get the paper off. Now we have no access because the panel is locked.
Jul 22, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub c350 -cobao code
finisher elevator drive error. Check the finisher tray for blockage or something under the tray. If all else fails, unplug and disconnect the finisher
Jan 20, 2009 | Office Equipment & Supplies
Konica Minolta Bizhub c350 error code c-0510. What is it? How do I fix it?
C0510 Upper fusing roller abnormally low temp
replace the thermistor in the fuser
Sep 25, 2008 | Office Equipment & Supplies
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
80 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
