Question about Daewoo DTQ-29S1FCN 27" TV
The TV and Cable box both continue to shut down; Please Help!!!
Hi, I am hoping you will be able to add some relief to a frustrating problem. My husband and I have a Daewoo t.v. and recently got digital cable. Now, before we added the cable the t.v. was hooked to our vcr and dvd player and we had no problems. The t.v. would stay on and it was not at the time connected to any type of surge protecter just our wall outlet. So we then decided to get the cable added. It was installed and that's when the problems begin to happen. Do you think it's the t.V., the cable or both? When the t.v. is on it will remain on for a time and then this electrical static noise comes on and the picture starts warping and fuzzing out until the t.v. and the cable goes out. It does turn back on once we click on and off the surge protector. After this was happening for a time we took these intial steps: 1. We returned the cable box for a brand new one. 2. We bought a surgeprotector for Satellite/Home Theatre use 3. When the t.v. and cable goes out the lamps stay on they are not affected. They are also hooked into the surge protector.
  • kesha blackmon Jul 04, 2007
    Thanks Mike for your suggestion. First let me answer your questions, and then I'll tell you the results. 1. The t.v. shuts off and the cable box resets itself and stays on. 2. The the t.v. was originally plugged into the cable box. So this is what we tried: A. We to the t.v chord and unplugged it from the cable box into the outlet wall: Result. The t.v. continued to shut down. B. We kept the t.v. plugged directly into the outlet wall, unplugged the coaxial cable attached to it, to see what would happen. Result: The t.v. shut down. Therefore showing the t.v. (over 10 years old) had the problem.
    So your suggestion showed that it was the t.v. that is defective. Thanks again. As we speak my husband just walked in with a new t.v. :)
  • Anonymous Dec 15, 2008
    Newly installed charter cable, tv and cable box randomly powers off and back on, sometimes every 30 seconds, sometimes not for hours
I was just wondering if you have the original remote for that tv or if you are using a universal. I have the same tv but dont have the remote and i cant find a universal that works.
Posted on Jan 07, 2010
  • 398 Answers
Do you mean that the TV shuts off and the cable box also shuts off? Is the TV plugged into the back of the cable box? This sounds to me as if the cable box is defective and the TV is plugged into the cable box instead of the power strip. To prove whether or not the cable box is defective, plug the cable directly into the TV, plug the TV directly into the wall outlet and watch one of the lower channels. If the TV acts up and shuts off, have the TV serviced. If the TV plays fine, replace the cable box.
Posted on Jul 03, 2007
SOURCE:
Need radio code for 2001 daewoo lanos
Hi Palmspringsv,
I recently had a Lanos towed into my repair facility with a dead battery. After replacing it we had the same problem,radio displays the word code. I found a website that posted the following codes as the most common for the US models. I entered them until I got down to 13th one and it unlocked it. Good luck,hope they help,Chuck.
4316 2152 4513 4362 1156 2145 3451 6361 5624 5241 3346 1165 3241 4524 5436
Sep 16, 2011 | 2001 Daewoo Lanos
I have a Kodak DC290 which has not been used for a while. Put new AA's in it but it won't turn on. Camera belonged to my husband, who recently passed away. Also can't find the manual. Can you...
If it sat a long time with old batteries, make sure they did not leak and corrode the contacts in the camera. Look at them and clean if necessary.
Jul 24, 2011 | Kodak DC290 Zoom Digital Camera
My tv remote quit working. I would like the code for Daewoo TV, model No. DTQ-13P2FC to enter in another remote.
For Time Warner Cable TV Remote Codes for DAEWOO-TV's - Go to Time Warner Cable web site to PROGRAM REMOTE -- Site URL is http://www.timewarnercable.com/en/residential-home/support/pyr.html Then select TW Cable remote model. Under Control a Device -- first select type of device (TV) Then select Brand Name (DAEWOO). TW Cable lists several codes to cover different models. Choose a code and input into remote to see which code works. Try all codes. There were several codes to choose from and to try inputting into my TW Cable remote. Finally, the next to last code worked on my TW Cable remote -The Atlas OCAP 5-Device Remote Control by Universal Electronics. The code for this remote for Daewoo TV Model DTQ-13P2FC is 1661. Hope this helps. Otherwise, try checking the site of your cable or satellite provider & you should be able to get their add device codes for free.
Jun 21, 2011 | Daewoo DTQ-13P2FC 13" TV
Cant find code sheet need code for a deawoo tv for remote sru3006wm/17
Code Search Results--> --> Code For Model RCU300T
Code 004 for Daewoo TV Code 005 for Daewoo TV Code 006 for Daewoo TV Code 016 for Daewoo TV Code 017 for Daewoo TV Code 082 for Daewoo TV Code 171 for Daewoo TV Code 190 for Daewoo TV This is a basic set of codes for the TV, I am not sure of the model on the remote so I can only give you what I have. If these won't work, add a 1 in front of these 3 digit codes to make a 4 digit code, this should work. Good luck
Nov 15, 2010 | Universal Remote Control 6-Device...
My car radio won't come on.
hi
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
hi please check the above mentioned wires are in place. if all in place then check weather power is coming to these lines. if power is also coming the problem lies with the system itself. please service it and it wil be ok.
if the information was usefull then vote me
Jul 12, 2010 | 2000 Daewoo Leganza
I NEED TO KNOW HOW TO ALLIGN A 2003 DAEWOO NUBIRA TIMING BELT.
If you have the 2.0 L engine, then the two cam marks should point upward to match the notches in the valve cover. The crankshaft notch should point downwards to match the V notch in the lip of the oil pan. Hope this helps...
Nov 16, 2008 | 2002 Daewoo Lanos
Wii Delay on new Insignia TV
We just upgraded from a 32" LG tube tv to a 46" Insignia LCD and had the same problem with our Wii and PS3. For us, we just switched the TV settings DCM (digital clear motion) function. We keep it on high for movies and TV shows and turn it completely off when playing Wii and PS3 games. Hope this helps!!
May 09, 2008 | Televison & Video
Problem with Dolby Digital mode
If it is a new DVD that may be a problem, as signal changes may be frustrating this old machine... but it is likely the cabling from the DVD player to the reciever. Are you on the right channels/settings? is the optical cable and digital cable recieving digital output from your DVD player? Try changing those settings and you should be in good shape Thanks! good luck!
Jul 22, 2007 | Yamaha RX-V3300 Receiver
Daewoo DTQ-29S1FCN 27" TV Logo
796 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
