Question about Eureka Vacuums
Replace vacumn handle
Model 3281 type az
  • Eureka Master
  • 18,424 Answers
Click this link for the manual, it will give you full instructiona to put handle on..
http://www.eureka.com/FileLibrary/4742d9b4d2d24e39b413c1f61b25271e/82583.pdf
go here for spares > http://www.eureka.com/en-US/Vacuums/Vacuum-Maintenance/Find-the-right-accessory/
Posted on Jan 10, 2013
How do I replace the rocker arm in the off and on switch of the Electrolux canister vacumn model 2100
This is something that can be very difficult to explain, much less perform without prior knowledge of this particular model.
With 30 yrs. experience, I have a legitimate store front business and do service by mail at a reasonable cost if interested.
mickeymackmark1@yahoo.com. Hope that helps! Mick
Mar 09, 2015 | Electrolux Vacuums
I am looking for a service manual for my Kirby G4D vacumn.The number on the vacumn is 7941006690. Sounds like there is something caught in the motor or fan . I am not sure how to take the vacumn apart...
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
http://kirbywhq.powweb.com/manuals/G4/8D4538EC00E93846200D614F7C499B59/G4%20Manual.pdf
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Aug 17, 2011 | Kirby G4 Bagged Upright Vacuum
How can i change belt. model # 4235 az
I've posted the steps below, but I am also going to give you a link to the manual, as it includes pictures that might be helpful. Look for page 4.
http://www.eureka.com/service/manuals/81221.pdf
1) Use handle release to lower handle flat
onto floor (Fig. 1).
2) Remove 4 screws from brush roll cover.
(Fig. 2).
3) Lift off brush roll cover. (Fig. 3).
4) Remove brush roll and belt. Thread new
belt around motor shaft and brush roll
(Fig. 4).
5) Insert left end of brush roll first. Make
sure end cap fits into base. Pull right
side of brush roll to stretch belt and
insert right end cap into base (Fig. 5).
Make sure it slides into position.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover (Fig. 3).
8) Replace 4 screws (Fig. 6).
May 05, 2011 | Eureka 4235AZ Upright Vacuum
My Kenmore vacumn won`t turn on . worked fine one minute then stopped. The light works on the handle but no vacumn
You probably have a sensor that needs attention and is clogged up so unclog and see if that takes care of it
Jan 12, 2011 | Kenmore Vacuums
How do you install the switch for the oreck vacumn properly?
The Orecks I have worked on have a plastic handgrip area surrounding a metal handle rod.
Undo the handle screws and the handle should separate like a **** shell revealing the switch and harness. Pull gently on the wire terminal with a pair of needle nose pliers not behind it.
Be careful not to flex the switch contacts as they may break off. reinstall any insulation around the switch before reasembling.
Sep 08, 2009 | Oreck XL2600 Vacuum
Brush will not turn
The most common problem is the handle isn't screwed in tight enough when the machine was assembled. Try tightening it down all the was and the electrical connections will then seat properly.
Jul 05, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Power brush will only operate on push stroke
If the motor runs, the circuit breaker is working. If it only works on the push stroke, you probably have burnt contacts where the handle and/or wands and/or power head connect. When you push, the contacts are pressed together; when you pull, they are separated and the motor loses power. The only solution is to replace the connector parts.
May 06, 2009 | Vacuums
I have acquired an old Regina Electrik Broom
Hi jmathe, Looking at the back (business side) of the vacumn: Underneath the white plastic dirt cup, please find a cast aluminum latch, that secures the part you will empty. To remove the white plastic part, turn the aluminum latch handle downward, and to your right, while you are holding on to the dirt cup with your left hand. I usually wear a dust mask, and empty the dirt into a small grocery bag, to tie shut, before placing it in the trash. To replace the dirt cup, turn the cast aluminum handle back to where it was before, handle pointing left. The more often you empty the cup, the longer your Regina Electrik Broom will last. Mine is forty-five years old. Allow the motor to cool, often, as well.
Jan 07, 2009 | Regina ElectrikBroom RG100 Vacuum
Bissell Healthy Home Vacumn
On the Healthy Homes Vac, did you check the switch for the vac, there are 2 on the handle, and the one could be open. Check the wiring at the motor, could even be the motor itself. If at the motor there is a thermostat, it could be bad, but comes with the motor.
Jan 06, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
35 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
