Question about Panasonic Microwave Ovens
My panisonic microwave dosent heat up wut do i do?
We changed the fusin olb and it still dosent heat up
  • Panasonic Master
  • 17,130 Answers
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Posted on Jan 10, 2013
Hamilton Beach microwave will not heat or cook anything HELP ME PLEASE
bad diode or inverter board or magnetron itself---diode fails first and inverter is power board for magnetron which does the heating.
Nov 06, 2012 | Microwave Ovens
Micro wave stops working after 30 secs
Replace the door interlockswitches - or try re-positioning the existing set. They wear after time
Jun 08, 2012 | Neff H5470 Microwave Oven
Microwave makes loud sound and dosent heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Jun 09, 2011 | Microwave Ovens
Panisonic microwave model NN s952wf Problem; has power (lights. clock and touch pad function), microwave and turn table do not work?
heatman101
Oct 16, 2010 | Panasonic Microwave Ovens
The microwave runs but dosent heat the food--do i fix this or buy a new one--micro is @13 yrs old--ge spacemake built in over stove--thanks
Hi, I would not fix a 13 year old microwave...
heatman101
Sep 22, 2010 | Microwave Ovens
The fan make loud noisesit spark first and it dosent heat at all help
do not try to fix it yourself !!!!
microwave can hit you with 4200v !!!
you have internal problem that only tec' can help you with :( sorry but your life worth more then the microwave.
Dec 19, 2009 | Maytag Over-the-Range Microwave
Replacement Magnetron needed? Where to buy - how to un/install?
I highly reccomend going too a trained microwave repair place too have it replaced, i will warn you if your microwave is not a expensive one, you are better off buying a new one, generaly a mag tube runs starting at $70.00 and up depending on the tube and model of your microwave.......the better microwaves on the market are litton, panisonic, and amanna
May 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Not working
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician, as repairing microwaves is a pretty risky job.
Oct 05, 2008 | Microwave Ovens
Panisonic oven NN9854P
I suspect a door switch or mount.
Usually a unit with a bad door switch or switch mount will still count down when you press Start, but will not heat.
The fan, turntable, and inside light may or not run, depending on how the unit is made.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 12, 2008 | Microwave Ovens
Microwave Ovens Logo
29 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
