Question about HP DESIGNJET T1120 44 Printer
Designjet t1100 keeps initializing
Replaced PS - noisy fan. Now machine keeps initializing - cannot shut off on face plate switch. Cannot get into diagnostics. Ideas appreciated. Power Supply is good. Thanks CIB
  • 12 Answers
SOURCE: Designjet 110 plus not turn on
do you change formater board ?or try use firmware utilit you can find it here
http://h10088.www1.hp.com/cda/gap/display/main/gap_home.jsp?cp=1_4011_100&zn=gap
Posted on Sep 30, 2008
  • 34 Answers
SOURCE: designjet T1100 error 47.01 when start on
YOU INSTALL THE DRIVERShttp://cluetechnologies.com/index.php?board=16.0
Posted on Jul 01, 2010
LoneGunman89
  • 131 Answers
SOURCE: how to resolve eror code 47.01 hp designjet T1100
this error code is Starwheel Motor failure.
Posted on Feb 25, 2011
  • 304 Answers
SOURCE: 08:11 error in hp designjet t1100
System Error: 08:YZ
Problem Description: Problem with the Front Panel.
Corrective Action: Try the following:
  • Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
  • Check that the Front Panel interface cable is not damaged and is correctly connected between the Main PCA and the Front Panel.
  • Check that the memory module in the Formatter is installed correctly.
  • Check that the connections between the Formatter, the Formatter and the Formatter are not damaged and are correctly connected.
  • Check that the Printer has the latest Firmware version. If not, update the Firmware to the latest version.
  • If the System Error continues, replace the Main PCA
  • If the System Error continues, replace the Formatter
  • If the System Error continues, replace the Front Panel
Posted on Jul 27, 2011
vinay229229
  • 1121 Answers
SOURCE: Hi I need the last version
Your mean latest version?.. Down load from hp site.
Posted on Sep 08, 2011
I just replaced the ink tube system in my HP T1100 Ps, an i get to the point to prime the system by letting the ink flow with no air bobbles. how can I set that option to do so? i have 3 orange prime
The priming option should be in the service menu. Typically you start the priming operation and the plotter will prompt you to install the startup heads (orange). Make sure you have no low cartridges or the operation might fail, although I believe the system will tell you if any ink tanks are too low to prime.
Oct 09, 2014 | HP Designjet T1100ps Printer
HP DesignJet Z6100 Error 43:10
Hello. The error message indicates a vacuum fan failure. The problem can be solved by replacing the Vacuum Fan Assembly.
Q6651 60286 HP Designjet Z6100 Vacuum Fan Assembly
The service manual with instructions can be downloaded from: http://www.lpscomputer.com/collections/designjet-z6100-parts
Jul 22, 2014 | HP Designjet Z6100 InkJet Printer
Installing a new blank hard drive in a DesignJet T1100,T610
The T610 hard drive is the formatter and has a special operating system software installed on if from HP. You can't format a hard drive and install it...so the whole formatter assembly needs to be replaced when the hard drive goes bad...
Mar 15, 2014 | HP Designjet T610 InkJet Printer
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
My HP Designjet T1100 says "Ink Cartridge Faulty Replace Ink Cartridge". But the cartridge in brand new. Any suggestions?
The most common cause I've seen is that when people put the new cartridge, they forget to remove the seal which makes the ink stay in the cartridge. It is typically a strip that covers the hole where the ink comes out, or else a strip that is located far from the hole, but that needs to get removed or else the ink will not flow from the cartridge
Feb 27, 2013 | HP Designjet T1100ps Printer
Hi ! can you tel me how to resolve eror code 47.1 for hp designjet t1100
I have this error with my Designjet T1110. I followed the instructions in the service manual 2-14 for troubleshooting.
questions:
- instructions say :"Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA." but I could not locate any cable from the starwheel assembly to the main PCA. I could see only cable from the starwheel motor assembly to the main PCA.
Feb 25, 2011 | HP Designjet T1100 Photo Printer
I am faceing the problem hp dj t1100 inkjet printer. No connectivity avaiable.
For a single computer you can install a JetDirect card and assign an IP address. Then connect the computer to the plotter directly through the ethernet connection on the computer using a cross-over cable (standard ethernet cable will not work unless you use a hub). Another option is to simply use a USB cable connection. Drivers are available from HP.com, Support, Downloads.
Mar 02, 2010 | HP Designjet T1100 Photo Printer
HP DESIGNJET T1120 44  Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
