Question about Frigidaire Microwave Ovens
Can you deactivate the beeper at the end of the cook cycle
  • Frigidaire Master
  • 17,130 Answers
Yes it can be done, Either you can cut off the buzzer connection from the control panel if this is an electronic type. If this is mechanical you can remove the gong or bell from the timer switch
Posted on Jan 10, 2013
How can I stop the three beeps the microwave makes at the end of a cook cycle?
the 3 beeps is to let you know the cycle is done, no that is for your good, can't be stopped
Dec 02, 2015 | Microwave Ovens
How do i disable the beeper
Hello Friend, thank you for allowing me to assist you!
I see that your question is listed under Frigidaire microwave FFCE2238LW. Typically you will hear a series of beep once your food is done heating or defrosting has finished. For this purpose, the beeping signal cannot be deactivated and I show that the volume is not adjustable for your model. Most microwaves are preset to do this. Best regards! - Z
Aug 26, 2014 | Frigidaire FFCE2238LW Microwave Ovens
Beeper problem
wither it fell out of place or needs replacement
Apr 17, 2014 | Amana MVH230 Microwave Oven
How can I turn off the beeper on my microwave?
On some models, yes. Simply refer to your owner's manual to see if that feature is available on your model.
Otherwise, see this YouTube video.
Jan 16, 2013 | Sunbeam Save price on SGS90701W 0.7-Cubic...
Microwave timer makes no sound
I would need a full model number and more detail to help you on this.
I'm wondering if you mean that the keypad is not responding to input, or the beeper is not working when you press a key or when it's done cooking.
If the former, then you have a failed membrane keypad. We can help you with more information with the full model number and detailed symptoms.
If the latter, the beeper may be turned off via the control panel. You'd have to consult your owner's manual for information on whether it ahs that feature, and how to activate and deactivate it.
Feel free to contact me for a free estimate or DIY info, including part help.
Oct 02, 2011 | Amana MVH230 Microwave Oven
I currently own a CFMT148GPB2 Frigidaire Pro Series Microwave/fan. It stopped working instantly i.e. was cooking vegetable, it went to the end of its cooking cycle...then 2 minutes later I re-openned the...
I would think the main fuse may have gotten hot due to a bad fuse holder. If the fuse holder gets old and doesn't grab the fuse tightly it is an opposition to current flow, which is a resistance, and any resistance will produce heat, heat will make a fuse melt in its end and go bad. So, either that or something else just shorted out and blew the fuse inside. Need to call a technician. But the fact it finished its cycle then was dead when you went back makes me think the overheated fuse thing.
Aug 23, 2017 | Microwave Ovens
Spacemaker xl (1999)low volume beep
According to the owner's manual (available here), there is a beeper volume on some models in this series. If yours has one, press it and then press 0 to 3 to control the volume (0 mutes the beeper and 3 is loudest).
If your model doesn't have the beeper volume control it's just that the beeper is going bad. They sometimes do that, getting faint or quitting entirely. You can't get a replacement beeper from GE, only the entire control circuit board.
The beeper is a piezoelectric type. Radio Shack sells a variety of beepers. If you know someone who can replace electronic components, they may have one that could be used on the board. Changing the beeper for one not the same as the original would not affect the oven's operation or safety, so that's an option. I'd do that myself if I were repairing this for a friend. But you might not be able to get a professional service shop to do this because of liability concerns. They would most likely replace the entire board.
With luck, your oven just has the volume down. Hope this has helped, and thanks for using Fixya!
Feb 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I turn off Kenmore Microwave Beeping?
I've got a Honda Civic hybrid with the same noisy beeper. I can't have the parking lights on and the door open. I can't leave the key in the switch while making a phone call etc. I think we have to presume that like the Honda, there is no software controlled override on you microwave beeper... they know best and want you to feel safe and secure that no burglar will be able to make a cup-o-soup in your kitchen without waking you. A few screws and you should be able to expose the main circuit board and apply a layer of bubble gum or silicone caulk or JB Weld to the beeping device. Most have a small hole in a black plastic cylinder... so cover the hole and then test for loudness. For absolute silence, desolder the device from the circuit board and replace with a resistor matching the amount you measure across the beeper contacts with an ohm meter.
Dec 12, 2009 | Kenmore 80809 Microwave Oven
How to stop it beeping
Is it beeping as the normal end of cycle beeping or Continuous faulty beeping? If you know a bit about electronics, you could locate the beeper and by using a soldering iron, remove it. Or to mute the sound by quite a bit, place a strip of thick insulation tape over the beeper. Otherwise if faulty, you could buy a new board.
Sep 27, 2009 | Microwave Ovens
Microwave Ovens Logo
49 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
