Question about Plumbing
I have a Davey HP45-05 Pump which has a rainbank system connected every time the pump starts water leaks out of the front clamp seal. Can this seal be replaced?
4 Suggested Answers
SOURCE: Water Leak
is the pump gray or white? if it is gray then replace it.look where the pump mounts to the ,otor and see if there is a black line coming from the middle.this is probably where your leak is.
just change the pump.
Posted on Nov 05, 2008
dennymulford
  • 1055 Answers
SOURCE: Lower radiator hose leak at water pump housing
water pump housing is cracked ,replace the water pump
Posted on Apr 11, 2009
  • 3600 Answers
SOURCE: Drain hose seal leak on Kenmore washer
Remove the hose and bend it in circiles see if yo see any cracks in the hose if you do replace it or if it's long enough cut out the bad part and replace it. Alos clamps wear out ver time so try replacing the clamps too.
Posted on Jul 17, 2009
Davey presssure pump when switched on b4 tap is opened the pump does run stop run stop run stop between each cycle small squirt of water escapes from pressure tank at the clamped junction
fix the leak as the pump build pressure switches off , the leak looses pressure pump switches on and so on
fix the leak and the pump will build pressure and switch off until the tap is used
Nov 19, 2016 | Plumbing
Our auto irrigation system wouldn't turn off. We found the Davey XJ70 pressure pump was leaking so replaced the leaking pipe. Now the watering g system won't start. What do we do?
Hi Geralidine
Sounds like your pump is "air bound"...meaning that the impeller housing of the pump is full of air, and it cannot pump water.
Try bleeding the air out of the pump and put a positive pressure (garden hose pressure) and make sure that you shut the airbleed valve off after you start to pump.
Please take time to rate me
Bud
Mar 31, 2013 | Plumbing
Davey HP45-05 with Rainbank will not turn off?
Hi Sam,
Combined Electrical in Fyshwick ACT here. Has your problem been resolved?
We have found that a leaking cistern which can only be a few litres a minute can cause this problem.
Aug 14, 2012 | Plumbing
Replacing water pump.
See the instrucitons below.
Removal
  1. Disconnect battery ground cable (14301) at battery.
  1. Drain cooling system.
  1. Loosen four water pump pulley retaining bolts while drive belt is still tight.
  1. Loosen drive belt tensioner (6B209) and remove drive belt (8620) .
  1. Remove generator (GEN) (10300) wiring connector, remove fasteners, and remove generator .
  1. Remove heater water return hose from water pump (8501) .
  1. Remove drive belt idler pulley and bolt tensioner assembly.
  1. ani_caut.gif CAUTION: If using a prying device to assist in water pump removal, be careful not to damage the mating surfaces.
    Remove water pump pulley fasteners and gently pry between drive belt idler boss and frame rail and remove pulley.
  1. NOTE: Mark bolts so they may be returned to original location.
    Remove water pump retaining bolts and nuts and water pump . Discard used water pump housing gasket (8507) .
Installation
NOTE: Lightly oil all bolt and stud bolt threads before installation except those specifying special sealant.
  1. ani_caut.gif CAUTION: Use care when scraping gasket surfaces as aluminum gouges easily and can cause leaks.
    Clean gasket surfaces on water pump and engine front cover (6019) .
  1. NOTE: The threads of the No. 3 engine front cover retaining stud must be coated with Pipe Sealant with TeflonĀ® D8AZ-19554-A or equivalent meeting Ford specifications ESG-M4G194-A and ESR-M18P7-A before installing.
    NOTE: Gasket and Trim Adhesive D7AZ-19B508-B or equivalent meeting Ford specifications ESR-M11P17-A and ESE-M2G52-A is recommended to hold the water pump housing gasket in position.
    Position a new water pump housing gasket on water pump housing sealing surface.
  1. Install water pump on the engine front cover . Install retaining bolts.
    Item Part Number Description 1 6019 Engine Front Cover 2 8507 Water Pump Housing Gasket 3 8501 Water Pump 4 - Bolt (Part of 8501) (5 Req'd) 5 - Optional Locating Pins (2)
    (Part of 6019) A - Tighten to 8-12 Nm
    (6-9 Lb-Ft)
    FASTENER IDENTIFICATION Fastener and Hole No. Part No. Size Application 1 N804811 M8 x 1.25 x 73 W/P & F/C to Block 2 N804811 M8 x 1.25 x 73 W/P & F/C to Block 3 - Stud N807036 M8 x 1.25 x 94.3 W/P & F/C to Block 4 N804811 M8 x 1.25 x 73 W/P & F/C to Block 5 N804811 M8 x 1.25 x 73 W/P & F/C to Block 6 N804811 M8 x 1.25 x 73 W/P & F/C to Block 7 N804576 M6 x 1 x 28.5 W/P to F/C 8 N804576 M6 x 1 x 28.5 W/P to F/C 9 N804576 M6 x 1 x 28.5 W/P to F/C 10 N804576 M6 x 1 x 28.5 W/P to F/C 11 N804576 M6 x 1 x 28.5 W/P to F/C A. Tighten to 20-30 Nm (15-22 Lb-Ft)
    B. Tighten to 8-12 Nm (71-106 Lb-In)
  1. ani_caut.gif CAUTION: Be sure that the hose clamps are beyond the bead and placed in the center of the clamping surface of the connection. Any used hose clamps must be replaced with a new clamp to ensure proper sealing at the connection.
    Connect heater water outlet tube (18663) to water pump and position the hose clamps between the alignment marks on both ends of the hose. Slide hose on connections. Tighten screw clamps to 2.2-3.4 Nm (20-30 lb-in).
  1. NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
    Connect battery ground cable .
  1. Install idler pulley, drive belt tensioner, generator and generator wiring.
  1. Position drive belt over drive belt tensioner and release drive belt tensioner .
  1. Fill and bleed cooling system with specified coolant.
  1. Fill power steering pump reservoir with specified fluid.
  1. Start engine and check for coolant leaks.
Hope this helps.
Zeppelinx12
Feb 23, 2011 | 1995 Ford Windstar
How to change water and timing belt on my 2005 subaru legacy gt turbo, pump is leak or stains below the centre of the eng. near and alen key eng, plug?
Unless you have really high milage on this vehicle the pump is not likely to go. Pump on front of engine and if it leaked would run down front and sprinkle towards center. However a weak heater hose or cooling hose clamp could give you the same results.
Before you spens a fortune ( cause this job is basically a timing belt job with a water pump, and eng seals ) Have the vehicles cooling system pressure tested for leaks. The techn will know how to check pump if he thinks its bad.
Apr 29, 2010 | 2005 Subaru Legacy
Jul 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Water leaking from under washer
Hi
You'll need to open the machine and check for the leaks in the hose connected to the drain pump. Also check if the clamp connecting the drain filter and hose is tight. Also check these things for leaks---
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you'll need to replace it.
Please do rate this solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Changing the water pump on 2000 Jeep Grand Cherokee V6
WATER PUMP
The water pump is bolted directly to the engine timing chain case/cover.
A gasket is used as a seal between the water pump and timing chain case/cover.
If water pump is replaced because of bearing/shaft damage, or leaking shaft seal, the mechanical cooling fan assembly should also be inspected. Inspect for fatigue cracks, loose blades, or loose rivets that could have resulted from excessive vibration. Replace fan if any of these conditions are found. Also check condition of the thermal viscous fan drive. Refer to Viscous Fan Drive in this group.
The water pump can be removed without discharging the air conditioning system (if equipped)
REMOVAL
Disconnect negative battery cable from battery.
Drain cooling system. Refer to Draining Cooling System in this group.
Do not waste reusable coolant. If solution is clean, drain coolant into a clean container for reuse.
The thermal viscous fan drive is attached (threaded) to the water pump hub shaft. Remove fan/viscous fan drive assembly from water pump by turning mounting nut counterclockwise as viewed from front. Threads on viscous fan drive are RIGHT HAND. Using special tool spanner wrench 6958 with adapter pins 8346 and a suitable fan wrench loosen the fan drive Viscous Fan and Fan Drive Do not attempt to remove fan/viscous fan drive assembly from vehicle at this time.
WARNING: CONSTANT TENSION HOSE CLAMPS ARE USED ON MOST COOLING SYSTEM HOSES. WHEN REMOVING OR INSTALLING, USE ONLY TOOLS DESIGNED FOR SERVICING THIS TYPE OF CLAMP, SUCH AS SPECIAL CLAMP TOOL (NUMBER 6094) SNAP-ON CLAMP TOOL (NUMBER HPC-20) MAY BE USED FOR LARGER CLAMPS. ALWAYS WEAR SAFETY GLASSES WHEN SERVICING CONSTANT TENSION CLAMPS.
CAUTION: A number or letter is stamped into the tongue of constant tension clamps. If replacement is necessary, use only an original equipment clamp with matching number or letter.
If water pump is being replaced, do not unbolt fan blade assembly from thermal viscous fan drive.
Remove two fan shroud-to-radiator nuts Fan Shroud Mounting Hardware Do not attempt to remove fan shroud at this time.
Remove fan shroud and fan blade/viscous fan drive assembly from vehicle as a complete unit.
After removing fan blade/viscous fan drive assembly, do not place thermal viscous fan drive in horizontal position. If stored horizontally, silicone fluid in viscous fan drive could drain into its bearing assembly and contaminate lubricant.
Remove accessory drive belt as follows: The drive belt is equipped with a spring loaded automatic belt tensioner. Relax tension from belt by rotating tensioner clockwise (as viewed from front) Automatic Belt Tensioner - When all belt tension has been relaxed, remove accessory drive belt.
Remove lower radiator hose clamp and remove lower hose at water pump.
Remove seven water pump mounting bolts and one stud bolt
CAUTION: Do not pry water pump at timing chain case/cover. The machined surfaces may be damaged resulting in leaks.
Remove water pump and gasket. Discard gasket.
INSTALLATION
Clean gasket mating surfaces.
Using a new gasket, position water pump and install mounting bolts as shown. Water Pump Installation - Tighten water pump mounting bolts to 54 N·m (40 ft. lbs.) torque.
Spin water pump to be sure that pump impeller does not rub against timing chain case/cover.
Connect radiator lower hose to water pump.
Relax tension from belt tensioner Automatic Belt Tensioner - Install drive belt
CAUTION: When installing the serpentine accessory drive belt, belt must be routed correctly. If not, engine may overheat due to water pump rotating in wrong direction. Refer to Belt Routing for correct belt routing. Or, refer to the Belt Routing Label located in the engine compartment. The correct belt with correct length must be used.
Position fan shroud and fan blade/viscous fan drive assembly to vehicle as a complete unit.
Be sure the upper and lower portions of the fan shroud are firmly connected. All air must flow through the radiator.
Install two fan shroud-to-radiator nuts Fan Shroud Mounting Hardware
Be sure of at least 25 mm (1.0 inches) between tips of fan blades and fan shroud.
Install fan blade/viscous fan drive assembly to water pump shaft.
Fill cooling system. Refer to Refilling the Cooling System in this group.
Connect negative battery cable.
Start and warm the engine. Check for leaks
Jan 10, 2009 | 2000 Jeep Grand Cherokee
GE WJSR 1070A Leaking
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Jan 24, 2008 | GE WJSR1070A Top Load Washer
Plumbing Logo
97 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
