Aiwa nsx vc43 stk amplifier ic number - Audio Players & Recorders
  • 298 Answers
SOURCE: Aiwa NSX-KT9
Try replacing the Carousel belt.
Posted on Feb 29, 2008
Grubhead
  • 5484 Answers
SOURCE: i have a nsx-9000 cassette deck will not play.
Make a note of how the belt fits, then remove it and measure the diameter. Then buy a replacement, belts do go bad from time to time, so a new one might cure the problem. Put the diameter size (to the nearest mm result, IE: 50 or 55mm, not 52mm! Into google and "cassette belt" and you should find one for the job.
Posted on Feb 27, 2010
sonicboomele
  • 1557 Answers
SOURCE: i has a aiwa nsx -999 component set it has a burnt
if the part number is not on the pcb bord then you need to get a sqmatic diagram and find it there
Posted on Apr 24, 2010
dunnbiker
  • 8546 Answers
SOURCE: It is possible to connect a "AIWA NSX V70" as a
Use VIDEO/AUX instead. MIC is for the smaller input signal that a microphone would typically produce.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-NSX-V70-manual/id/1076ci461/t/2/
Use your PC soundcard controls to adjust the output to something useable (max?).
Posted on Apr 30, 2011
  • 7 Answers
SOURCE: AIWA shelf system volume button
hi there if u want fix volume botton,u need open total aiwa set,but very hard job need a bit pasion,it was happned to me too!>Wht u gona doo u need open central part where screen connected there aiwa wolume boton system,u need open that all,befreo u need take it out botton control plastic front set,but be gentely because if bottons fall down u can put them back then same pose,So u need the volume panel open,u will see small controler siting on the micro chip i can take it that out from panel of volume,then clean it tootbarash,Possible can be dirty or oily.i did also that same clean and put everything same back,it cost me 5 our fix that alll,hope will help!
Posted on Oct 09, 2012
Aiwa NSX-A-J800 Manual
Retrevo has the manual for the Aiwa NSX-AJ800 Stereo System here: http://www.retrevo.com/support/Aiwa-NSX-AJ800-manual/id/1076dj383/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
(note you will need Adobe Reader or a similar program to read the file)
Dec 23, 2011 | Aiwa NSX-DS55 CD Shelf System
Apr 30, 2011 | Aiwa NSX-AJ300 CD Shelf System
Power indicator open but no function audio,as well as selector my unit is an aiwa nsx k880 stereo
To start with you will have to check on the power supply for the fuses, the fusible resistors on the various sub power section near the main transformer. If OK proceed to see the recitifed DC , the supply to the main controller IC the microprocessor in the front panel. You will need some basic electronics to check for the +5 volt to the mP and confirrm if it is working. replace only if confident or get help. If this section is OK then proceed to the mode selector IC to the output IC. This may require some good technical support to prevent further damage by tampering so please check this out. Good day
Jul 26, 2010 | Audio Players & Recorders
NEED MANUAL
Hi
Just follow this link
http://www.retrevo.com/support/Aiwa-NSX-AJ20-manual/id/1076ci366/t/2/
and click GET MANUAL
scroll down and type your email address and number showing in that box below...click DOWNLOAD
thats all..
-- Rajkumar
Oct 01, 2009 | Aiwa NSX-AJ20 CD Shelf System
Need a replacement belt for Aiwa NSX-A777
CONTACT ANDREWS ELECTRONICS AT WWW.ANDREWSELECTRONICS.COM, THEN CALL THE CUSTOMER SERVICE LINE THEN TELL THEM WHAT YOU NEED.
Feb 24, 2009 | Aiwa NSX-A777 Shelf System
AIWA products
Download User Manual for Aiwa NSX-AJ50 Hi-Fi system.
Sony owned Aiwa few years back and you can see NSX-AJ50 page on Sony Support.
If you have Aiwa part Query, please contact nearest Sony Service center.
Oct 04, 2008 | Aiwa NSX-AJ50 Shelf System
No Sound
Tienes que remplazar los IC de audio que esten dañados o enviarlo a un centro de reparaciones.
Mar 26, 2008 | Audio Players & Recorders
71 people viewed this question
 Grubhead
Grubhead
