Question about Panasonic KX-TGA510 Cordless Phone
How do I set the ring tone for a 510
The phone does not ring
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
Mar 14, 2011 | Nokia 2310 Cellular Phone
The ringer of my phone is off. How do I turn it on?
flip open your phone -then increase volume with side ^ button...this toggles ringer on/off
no need to go into phone settings...
Aug 05, 2010 | Cell Phones
Cannot set Ringing tone ... unit will power off
which data cable should i use to keep new ring tone on my mobile nokia 1661
Apr 04, 2010 | Nokia 1661 Cell Phone
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
Nokia 1661 my phone not ringing why ?
Mar 22, 2010 | Nokia 1661 Cell Phone
No ring tone on my Sony Ericsson 580i
to set a ring tone in your phone, you must first go to any profile, open it, then select the ring tone option. from there you can select the ring tone you like.
Dec 08, 2009 | Sony Ericsson w580i Cellular Phone
M7310 - 3 phone set system - line 3 on one set does no ring tone
Feature * 6 is for the ring tone of the set, it doesn't change the cadence (ring tone) on a line...
The only way to change the ring tone on a line... it would require everyone that has that number to change.
You need to go into the programming
-> look for LINE and enter
-> put in 003 for line 3 and enter
-> under TRUNK/LINE DATA find DISTINCT RING and change
-> REL to end programming...
Now that line 3 will ring differently. But it will ring differently on everyone's sets that has line 3 on their phone
Mar 04, 2009 | NorStar Meridian M7310 Phone
Ring tone
1. to set mp3 ring tones...
copy any mp3 file to phone ( via cable or bluetooth )
go to multimedia = go to mp3 = now play the song you want as tone,
when song is playing, select options, and select = set as ring tone
DONE and smile......
2. to set Default sound ring tones...
go to menu = my stuff = sounds =
browse the sound files when you like one , select options, and set as ring tone.....
Done and smile again... hope this helped...
May 13, 2008 | LG KG800 Cellular Phone
Panasonic KX-TGA510 Cordless Phone Logo
22 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
